Dimensionless equations, variables, mesh etc
Like Tree1Likes
  • 1 Post By henrik
Old   July 10, 2009, 09:56
Default Dimensionless equations, variables, mesh etc
bhh
Bjorn H. Hjertager
bhh is on a distinguished road
All my equations, variables and coordinates etc. are dimensionless. OF require dimensions on all variables, coordinates etc.. How can I do my modelling in OF without dimensions?
Regards
Bjorn
bhh is offline   Reply With Quote
Old   July 10, 2009, 11:33
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
bhh,
Even with normalized dimensions, you still have the points relative position. From there you create the mesh. Concerning the variables, it is a question of defining dimensioned scalar, or volVectorField, or equivalent, in the createFields.H fil.
Regards,
Titio
titio is offline   Reply With Quote
Old   July 12, 2009, 23:56
bhh
Bjorn H. Hjertager
How and where may I turn off the dimension checking?
Bjørn
Old   July 13, 2009, 04:14
isabel
isabel is on a distinguished road
I need to turn off the dimension checking. Does anybody know how to do it in OpenFOAM?
isabel is offline   Reply With Quote
Old   July 13, 2009, 09:22
Henrik Rusche
henrik is on a distinguished road
Dear All,
google("dimension checking openfoam") yields
http://openfoamwiki.net/index.php/Ma...al_checking.3F
as the first hit - not that I think it's a good idea to switch it off!
Henrik
henrik is offline   Reply With Quote
Old   July 13, 2009, 10:41
bhh
Bjorn H. Hjertager
Henrik,
Thanks for the info!
I agree that the dimension checking should generally not be turned off. However, when doing a non-dimensional problem it should be OK, or?
Bjorn
Old   July 13, 2009, 11:31
Henrik Rusche
Dear Bjorn,
Why do you want to implement the equation set in dimensionless-form in the first place? You loose one of the best features of OpenFOAM while you need it most, i.e. while implementing a new set of equations and solution algorithmn.
Without knowing you and your skills, my bet is that you will make mistakes which could have been easily flagged through dimension checking. I cannot tell you how much I hated the void fraction for being dimensionless, but that one cannot be helped ;-)
I would rather read the dimensionless parameters from dictionary and set the properties in the code. Post-processing can do the reverse and everybody is happy.
Henrik
Old   August 5, 2009, 12:21
Sven Winkler
sven is on a distinguished road
Hey henrik,
where can I set dimensions, when I implement new equations, that means in which file can I set the dimensions of constants that come with the implementation of a new equation? Thank you!
sven is offline   Reply With Quote
Old   August 5, 2009, 12:41
Henrik Rusche
Dear Sven,
the only dimensions that are not read in from file are those that arise from the discretisation (fvc::* and fvm::* methods). Those can not be changed - only the errors can be switched off.
Not sure this answers your question ...
Henrik
6863523 likes this.
Old   August 5, 2009, 13:09
Sven Winkler
Hey Henrik,
thanks for your answer. If I understand you right, you say that the dimensions of constants (for example Cmu in some turbulence models) are read in from file. I agree with that. But in the files where these constants are defined, there is no information about the dimensions of these constants. Thus, I guess there must be another file in which the dimensions of these constants are set.
I also tried to switch of the dimensions checking of OF. Unfortunately I can not find the controlDict file. According to the user Guide it should be located in $WM_PROJECT_DIR/OpenFOAM-1.5/.OpenFOAM-1.5. But in WM_PROJECT_DIR/OpenFOAM-1.5 there is no hidden folder named .OpenFOAM-1.5.
Thanks for your help!
Old   August 5, 2009, 14:01
Henrik Rusche
Sven,
Cmu, C1, C2, alphaEps are dimensionless.
The guide is outdated: The controlDict is now in $WM_PROJECT_DIR/etc
Please file a bug on this or make a note on the Wiki.
Henrik
Old   December 10, 2016, 11:25
Smile How to use the dimensionless N-S equations in OpenFOAM
  #12
Bill Wang
6863523 is on a distinguished road
Dear All,
I wonder if you guys have found a solution to this problem?
I also want to use the dimentionless equations in OpenFOAM. I have copied the controlDict out and changed the dimensionSet from 1 to 0, since I have no priviledge to modify the original file. But there is still dimension checking. It seems that the dimension chekcing was not turned off at all.
I wonder if there is any other solution, or did I miss something? Details could be been at How to use the dimensionless N-S equations in OpenFOAM
Thank you in advance.
Best Regards,
Bill
6863523 is offline   Reply With Quote
[Other] vtk mesh or Abaqus mesh to OpenFOAM bigphil OpenFOAM Meshing & Mesh Conversion 27 November 23, 2015 17:31
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Actual drag force from dimensionless equations slaxmi CFX 10 September 14, 2007 19:20
How to do Geometry from 3D mesh in ICEM San24 Main CFD Forum 4 August 8, 2005 02:49
mesh refinement on top of existent mesh? jx FLUENT 10 January 11, 2004 04:32
