Symmetry boundary condition in a heating pipe
Old   December 29, 2016, 11:13
Talking Symmetry boundary condition in a heating pipe
Alberto Karkour
albertokarkour is on a distinguished road
Hello! Me and a friend are solving an example from Victor's Pozzobon tutorials, example 8 to be specific and we are having troubles setting the 'symmetry' boundary condition, when we set it in the Temperature file like this:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 20;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 20;
    outlet
        type            zeroGradient;
    wall
        type            convectiveHeatFlux;
    axis
        type            symmetry;
    back
        type            wedge;
    front
        type            wedge;
We keep getting this message after running the solver:
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|* OpenFOAM for Windows 16.06 (v1)                                           *|
|* Built by CFD Support, www.cfdsupport.com (based on Symscape).             *|
Build  : 3.0.x-ac3f6c67e02f
Exec   : C:\OpenFOAM\ALBERTO-3.0.x\platforms\cygwin64mingw-w64DPInt32Opt\bin\simpleThermFoam.exe
Date   : Dec 29 2016
Time   : 15:52:54
Host   : "ALBERTOKARKOUR"
PID    : 1660
Case   : C:/OpenFOAM/ALBERTO-3.0.x/run/simpleThermFoam
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p      tolerance 1e-006
    field U      tolerance 0.01
    field T      tolerance 1e-006
Reading field p
--> FOAM Warning :
    From function polyBoundaryMesh::groupPatchIDs() const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 461
    Patch wall specifies a group wall which is also a patch name. This might give problems later on.
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading field T
--> FOAM FATAL IO ERROR:
    patch type 'patch' not constraint type 'symmetry'
    for patch axis of field T in file "C:/OpenFOAM/ALBERTO-3.0.x/run/simpleThermFoam/0/T"
file: C:/OpenFOAM/ALBERTO-3.0.x/run/simpleThermFoam/0/T.boundaryField.axis from line 41 to line 41.
    From function symmetryFvPatchField<Type>::symmetryFvPatchField
    const fvPatch& p,
    const Field<Type>& field,
    const dictionary& dict
    in file fields/fvPatchFields/constraint/symmetry/symmetryFvPatchField.C at line 99.
FOAM exiting
What can we do to solve the error?
Many Thanks!
albertokarkour is offline   Reply With Quote
Old   December 29, 2016, 12:51
Arvind Jay
arvindpj is on a distinguished road
Based on your 0/T file, I am seeing that you are trying to run a 2D axisymmetric simulation.
Place the createPatchDict file in "system" directory and run "createPatch".
This will remove the patches with no faces in them namely the pathch: axis
Below are the contents of createPatchDict
|  \\    /   O peration     | Version:  4.0                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations (i.e. cyclics).
pointSync false;
// Patches to create. An empty patch list just removes patches with zero
// faces from $FOAM_CASE/constant/polyMesh/boundary.
patches
Cheers
arvindpj is offline   Reply With Quote
several fields modified by single boundary condition schröder OpenFOAM Programming & Development 3 April 21, 2015 05:09
rotating pipe flow wall boundary condition problem preetam69 FLUENT 0 October 8, 2013 11:16
symmetry boundary condition icemaniac178 CFX 3 March 13, 2011 05:40
farfield Vs symmetry boundary condition Rajat FLUENT 1 October 21, 2005 13:53
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
