SLURM job submission steps!
Like Tree16Likes
Old   January 24, 2017, 16:22
Default SLURM job submission steps!
Bashar
Bashar is on a distinguished road
sorry to ask a general question, but I need some advice regarding job submission for oepnFoam. My university have Linux cluster ,and I need to start working on it to run my case in parallel. I have no idea about this kind of work , and I am the first student to use openFoam on this cluster. I managed to know that I need to use "SLURM job submission".I already searched the forums and I couldn't find something that is clear to me.
Any idea about the steps to do that?
Bashar
Bashar is offline   Reply With Quote
Old   January 26, 2017, 13:57
Bashar
I searched a lot and I found that the best way will be to see some old example using PBS then migrating the command to SLURM. I will update you if I managed to get it the right way!
Attached is a cheat sheet for migrating between different systems for anyone interested.
Best wishes
Bashar
PonchO, Sparsh and SHUBHAM9595 like this.
Old   February 8, 2017, 12:47
clapointe is on a distinguished road
Hi Bashar,
I copied the snippet included below from one of my job submission scripts. You can change requested time, nodes, and cores (depending on the cluster) by editing the --time, -N, and --ntasks-per-node lines, respectively. Place this at the top of your batch script.
#!/bin/bash
# Set up submit to ....
#SBATCH -J Test
#SBATCH --time=12:00:00
#SBATCH -N 1
#SBATCH --ntasks-per-node 24
#SBATCH -o test-%j.out
Hope this helps,
-C
Bashar and TomasWhite like this.
clapointe is offline   Reply With Quote
Old   February 8, 2017, 12:56
Bashar
Originally Posted by clapointe View Post
Hi Bashar,
#!/bin/bash
#SBATCH -J Test
#SBATCH -N 1
Hope this helps,
-C
Thank you C . Do you have full script file? It will be very helpful .Thank you again
Sent from my iPhone using CFD Online Forum mobile app
Old   February 8, 2017, 13:03
Sure, it's included below. You might have different protocol for loading the openfoam environment, though.
#!/bin/bash
#SBATCH -J Test
#SBATCH -N 1
nodes=$SLURM_JOB_NUM_NODES            # Number of nodes
cores=24                      # number of cores
# LOAD THE OPENFOAM MODULE
ml load gcc openmpi/2.0.1
ml load openfoam/4.1
sed -i "/numberOfSubdomains/c\\numberOfSubdomains    $(($nodes*$cores));" system/decomposeParDict
# Decompose solution (serial)
echo "DECOMPOSE MESH WITH decomposePar..."
decomposePar -cellDist > log.decomposeParDict 2>&1
# Run the solution (parallel)
echo "RUNNING THE SOLVER WITH fireFoam..."
mpirun -np $(($nodes*$cores)) fireFoam -parallel > log.fireFoam 2>&1
-C
Old   February 8, 2017, 13:11
Bashar
#!/bin/bash
#SBATCH -J Test
#SBATCH -N 1
-C
Thanks a lot! Yes , I have different protocol , but this is very helpful. I built my own script and I will compare it against yours to see if there is any thing that I didn't take care of.
Thank you .
Bashar
Old   July 13, 2017, 11:56
Default OpenFOAM with SLURM batch system
SP
SymplPilot is on a distinguished road
Hi everyone,
Our cluster uses the SLURM batch system also. However, the "srun" command is recommended to run all jobs. For example, to run a Foam application on 16 cores one has to use something like:
srun -n 16 xxxFoam -parallel
This is a problem, since OpenFOAM expects to see:
mpirun -np 16 xxxFoam -parallel
I wonder if anybody knows how to fix OpenFOAM to run with "srun" and "-n" as opposed to "mpirun" and "-np" ? Thanks for the help.
-SP
gabrielfelix and CorbinMG like this.
SymplPilot is offline   Reply With Quote
Old   July 13, 2017, 12:02
I think I've used srun for interactive jobs before -- it's a way to ask for resources so that you can then run commands yourself.
Submitting a job on a slurm-managed cluster, though, requires a submission script similar to the one I've posted previously.
Caelan
Old   July 13, 2017, 12:37
SP
Hi Caelan,
Thanks, for a quick reply. I understand that all #SBATCH commands to allocate the required resources should be specified properly in a script. My question is about the last command in a script - the run command itself. Note, in the script you posted you used "mpirun" with "-np ".
For interactive jobs, one usually allocates the resources with "salloc" first, then uses "srun" to run a job, like in "srun -n 16 ./jobname". Not sure if "srun" will recognize "-np", it is "-n" only.
-SP
Old   July 13, 2017, 13:12
srun automatically allocates the resources. If you want to work via an interactive job, use this command:
srun -N <insert number of nodes here> --ntasks-per-node=<insert number of cores here> --pty bash
this will get you an interactive job on N*ntasks cores. then, you can use mpirun as normal:
mpirun -np N*ntasks <insert solver here> -parallel
Caelan
Arsal likes this.
Old   July 13, 2017, 18:33
SP
Thanks for the suggestions. I agree "srun" can be used to allocate resources (under circumstances). However, its main purpose to launch parallel jobs in SLURM. I wonder if OF would work with "srun" as opposed to "mpirun". For example, is this command OK ? :
srun -n #cores Foam_Solver -parallel ?
Note, in your "allocation" example "srun" is still launching a parallel job -- bash. Perhaps, it is not a good way to allocate resources for interactive jobs in comparison with "salloc".
-SF
Old   July 13, 2017, 18:44
I tested the previous series of commands and was successful in submitting the job/getting the resources and running openFoam in parallel. The "--pty bash" is intentional, giving you the opportunity to use "mpirun" in the form of an interactive job.
If this is not your intention, srun is not required and the script included in a previous post will work.
Old   July 18, 2018, 07:30
Default srun and mpirun commands in SLURM
  #13
Asha Egreck
AshaEgreck is on a distinguished road
-SF
Thanks for the help. Following the guidance from https://www.open-mpi.org/faq/?catego...slurm-run-jobs I made a file called my_mpi_application with the following :
#!/bin/sh
caseName=${PWD##*/}
mpirun --oversubscribe -np 4 buoyantBoussinesqPimpleFoam -parallel > log.out_$caseName
Then I made a submit.sh file with the following :
#!/bin/bash
# Submission script for Cluster
#SBATCH --job-name=boussForooz
#SBATCH --time=01:00:00 # hh:mm:ss
#SBATCH --ntasks=1
#SBATCH --cpus-per-task=4
#SBATCH --mem-per-cpu=2625 # megabytes
#SBATCH --partition=debug
#SBATCH --comment=openFOAM
export OMP_NUM_THREADS=4
export MKL_NUM_THREADS=4
blockMesh
setFields
decomposePar
srun -n 1 my_mpi_application
Then I run the following from the terminal
sbatch submit.sh
I needed to add the --oversubscribe after mpirun (NB I don't really know the implications of this but it worked).
Hopefully that will help someone some day.
dduque and CorbinMG like this.
AshaEgreck is offline   Reply With Quote
Old   May 29, 2019, 07:54
Os
losiola is on a distinguished road
I am having an issue runing my jobs in slurm ,
once i submit my script using (sbatch job.sh ) i get a message that my job is submitted and by using squeue i can see that my job is runing on the cluster but unfortunatlly i cant find any results once the job is done , my case file is always still like on the begining and i dont find any of time directories (I use openFoam ).
Can you please help me with this issue?
this is the script i submit
#!/bin/bash
#SBATCH --partition=A
#SBATCH --account=AA
#SBATCH -N 1
#SBATCH --tasks-per-node=12
#SBATCH --job-name=losiola
#SBATCH -t 00:30:00
#SBATCH --mem=18GB
#SBATCH --output=log-%j.out
#SBATCH --error=log-%j.err
nodes=$SLURM_JOB_NEM_NODES
cores=12
module load openfoam/4.1
module load openmpi/1.6.5
module load gcc/4.7.2
export OMP_NUM_THREADS=12
export MKL_NUM_THREADS=12
mpirun -np 12 simpleFoam -parallel>log.simpleFoam 2>&1
losiola is offline   Reply With Quote
Old   May 29, 2019, 09:09
Fair warning -- I have not used slurm in a long while. That said, I have two immediate thoughts : are you sure the job is running (not just submitted and in the queue), and unless you have already made the mesh, you will need to run e.g. blockMesh before decomposePar.
Caelan
Old   May 29, 2019, 09:44
Os
Caelan
Yeah i am sure that the job is runing because it's status is R and i can see runTime increase
Old   July 17, 2019, 11:50
Default how to run multiple .sbatch scripts sequentially
  #17
Sumathigokul
Sgvaa is on a distinguished road
Hi, I have to run multiple sbatch slurm scripts for cluster. Say, I have 50 sbatch files and I am running them sequentially in terminal (am using Ubundu) as follows.
sbatch file1.sbatch
sbatch file2.sbatch .
sbatch file50.sbatch
I want to simplify this 50 different commands to run in single command. As I am new working with terminal as well as cluster, I really donno how to approach this problem. Kindly, suggest me some solution to perform this action (I guess that I need to use some for loop statements, but of which syntax is my doubt). Am completely confused, some relevant documents might also be helpful.
Thank you.
Sgvaa is offline   Reply With Quote
Old   July 17, 2019, 12:48
If they are to be run sequentially, then you can combine them to form one (long) script. Or write a script that calls the others. In pseudo code :
slurm stuff here
load modules
source script 1
source script 2
source script 3
source script 50
Caelan
Old   July 17, 2019, 20:23
Obi
obiscolly50 is on a distinguished road
sbatch file1.sbatch
Thank you.
Try this in a script:
#!/bin/bash
for i in {1..50}
do
   sbatch file$i.sbatch
done
obiscolly50 is offline   Reply With Quote
Old   July 19, 2019, 17:47
Sumathigokul
#!/bin/bash
for i in {1..50}
do
done
I tried this code as follows for just three files..
#!/bin/bash
for i in {1..3}
do
sbatch layer$i.sbatch
done
But, it didn't create as separate jobs I guess..Only single job is submitted as whole. So, this dint work for me.
$ ~/Marabou% sbatch call_sbatch.sbatch
Submitted batch job 4576049
Thanks.
HPC manager job submission in powershell ACmate Siemens 0 January 30, 2015 04:11
OpenFOAM Job Submission dancfd OpenFOAM Running, Solving & CFD 2 August 29, 2011 20:46
fluent job submission Sisir FLUENT 0 March 22, 2007 00:13
submission of Fluent job in parallel processor Sisir Kumar Nayak FLUENT 0 February 6, 2007 09:06
cfd job Dr. Don I anyanwu Main CFD Forum 20 May 17, 1999 15:13
