Error with "multiple regions", simpleFoam, complex mesh |
January 27, 2017, 12:45 |
Error: "multiple regions" in checkMesh, simpleFoam
Matthias H
Hi community,
Asked Google, tried for hours, and didn't find any solution. Newbie to CFD, so give me a chance At first, could you kindly look at my checkMesh: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : checkMesh -allTopology Date : Jan 27 2017 Time : 18:04:47 Host : "osboxes" PID : 4257 Case : /home/osboxes/OpenFOAM/osboxes-4.1/run/Fluent/v34_OF_2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Time = 0 Mesh stats points: 2928432 faces: 8437381 internal faces: 8090609 cells: 2754665 faces per cell: 6 boundary patches: 4 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 2754665 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. <<Writing 29 cells with zero or one non-boundary face to set oneInternalFaceCells <<Writing 582 cells with two non-boundary faces to set twoInternalFacesCells *Number of regions: 12 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 (fully disconnected) with 2754654 cells to cellSet region0 <<Writing region 1 (fully disconnected) with 1 cells to cellSet region1 <<Writing region 2 (fully disconnected) with 1 cells to cellSet region2 <<Writing region 3 (fully disconnected) with 1 cells to cellSet region3 <<Writing region 4 (fully disconnected) with 1 cells to cellSet region4 <<Writing region 5 (fully disconnected) with 1 cells to cellSet region5 <<Writing region 6 (fully disconnected) with 1 cells to cellSet region6 <<Writing region 7 (fully disconnected) with 1 cells to cellSet region7 <<Writing region 8 (fully disconnected) with 1 cells to cellSet region8 <<Writing region 9 (fully disconnected) with 1 cells to cellSet region9 <<Writing region 10 (fully disconnected) with 1 cells to cellSet region10 <<Writing region 11 (fully disconnected) with 1 cells to cellSet region11 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 8991 9390 ok (non-closed singly connected) outlet 9923 11912 ok (non-closed singly connected) wall1 273270 275342 ok (non-closed singly connected) wall2 54588 54300 multiply connected (shared edge) <<Writing 328 conflicting points to set nonManifoldPoints Checking geometry... Overall domain bounding box (-0.0041 -0.0025 -5e-05) (0.01555 0.01395 0.0011) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (3.65153e-18 6.74917e-18 -5.68701e-16) OK. Max cell openness = 1.65436e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 2.5e-09. Maximum face area = 2.5e-09. Face area magnitudes OK. Min volume = 1.25e-13. Max volume = 1.25e-13. Total volume = 3.44333e-07. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.46945e-13 OK. Coupled point location match (average 0) OK. Mesh OK. End I just don't understand what that means: "multiple regions[...]not connected by any face". These consist of single points, so are these really 'regions' ?? Whats wrong with my mesh?! simpleFoam calculated the velocities, thereafter the p-solver explodes (divison by 0). Case running well, when I do have only ONE region (easier setup / mesh). Technical stuff: simpleFoam, incompressible, laminar. Mesh prepared with Altair Hypermesh. Would be so great, if you could help me. Trying since weeks with efforts, but without reasonable results. Last edited by slayengine; January 27, 2017 at 16:18. |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 19:34 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Complex Mesh In Gambit. | Ranjeet | Main CFD Forum | 9 | April 29, 1999 17:18 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
