February 28, 2022, 05:09 |
Solver pimpleFoam dumped
Boucetta Lahcene
Rep Power: 4 |
Good morning,
When I try to run the PimpleFoam solver my code crashes, I don't know why, as you can see in photos the dt goes from a value of 1e-8 to 1e-104. Could you help me please I am new in CFD. Thanks Capture du 2022-02-28 10-53-47.jpg Capture du 2022-02-28 10-54-13.png |
March 2, 2022, 18:01 |
MNM
Rep Power: 8 |
Hi Boucetta, I hope that you have already solved ur issue.
If not, please provide more info to the users about your test case. Can you attach the output of checkMesh command. Also, details about fvSchemes, fvSolution and controldict would be helpful along with ur initial & boundary conditions. |
March 3, 2022, 07:12 |
Boucetta Lahcene
Rep Power: 4 |
Hello SHUBHAM, Thanks for your replay.
controlDict.png CheckMesh8.png fvschemes.jpg fvsolution_.png fvsolution2.png Thas it my fiels, it take a lote of time, and after it's damped. my Re= 50000 Thanks a lot i apreciate. |
March 3, 2022, 07:22 |
Boucetta Lahcene
Rep Power: 4 |
Hello again
I forgot initial condition, I wonder if in the fvscheme folder i can use the 2nd order schema? I don't want to use a wall law because my y+=0,3 Thanks k.png nut.png omega.jpg U.jpg |
March 3, 2022, 16:08 |
MNM
Rep Power: 8 |
Now, we have a better idea about your test case .
Few Comments 1) Try with Euler first or maybe Crank - Nicolson 0.5 & then shift to backwards 2) You can definitely opt for one non - orthogonal correctors. Try going for higher number of outerCorrectors like 50 with the residual control options... Code:
PIMPLE { momentumPredictor true; transonic false; consistent true;// no need to use urf with consistent nOuterCorrectors 50;//50 nCorrectors 3; nNonOrthogonalCorrectors 1; residualControl { "(p|p_rgh)" { // If this INITIAL tolerance is reached , leave outer corrector tolerance 1e-03; relTol 0; } U { // If this INITIAL tolerance is reached , leave outer corrector tolerance 1e-03; relTol 0; } } } 4) I've no idea about your geometry, but based on the naming conventions....inletOutlet for BOTH ymin & ymax might not be correct... P.S. No expertise in turbulence so cant comment on the k, omega, & nut. I presume that aspect ratio of 700 is not the culprit for divergence while simulating turbulence |
New solver and Segmentation fault (core dumped) | MinShin | OpenFOAM Running, Solving & CFD | 3 | September 4, 2021 05:00 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 12:31 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
