rhoCentralFoam not starting after changing thermophysicalProperties to polynomial
Old   August 11, 2021, 05:53
Default rhoCentralFoam not starting after changing thermophysicalProperties to polynomial
Niklas Boehnke
janibo is on a distinguished road
Dear Foamers,
I am able to run a cd-nozzle case with the fluid air with the following thermophysicalProperties
successfully and with good results:
original thermophysicalProperties-file:
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo         	hConst;
    equationOfState PengRobinsonGas;
    specie          specie;
    energy          sensibleEnthalpy;
mixture	//Air
    specie
	nMoles			1;		//mol
        molWeight       28.96; // g/mol // kg/kmol
    thermodynamics
        Cp              1004.5;
        Hf              2.544e+06;
    transport
	As  		1.4584e-6;
	Ts  		110.33;
        mu           1.8e-5;
        Pr             0.71;
	equationOfState
		Tc  132.52; 	//K
		Vc  0.08443;	//m^3/kmol
		Pc  37.56e05;	//Pa
		omega  0.038;	//dimensionless
I changed the thermodynamics and transport to
the polynomial options and everything else stayed the same:
thermophysicalProperties-file changed to polynomial:
thermoType
    type            hePsiThermo;
    transport       polynomial;
    thermo         	hPolynomial;
    specie          specie;
mixture	//Air
    specie
	nMoles	      1;		//mol
    thermodynamics
	//Cv				718;	//	J/g*K
        //Cp                         1004.5;	//	J/g*K
        Hf                             0; //2.544e+06;
	Sf				0.0;
	CpCoeffs<8>		(1.3211 -0.0047 3e-5 -8e-8 1e-10 -1e-13 4e-17 0); //based on [J/kg*K]
    transport
	//As  			1.4584e-6;
	//Ts  			110.33;
        //mu                         1.8e-5;
        //Pr                           0.71;
	muCoeffs<8>     ( 6e-7 7e-8 -4e-11 8e-15 8e-18 0 0 0 ); //based on [Pa s]
        kappaCoeffs<8>  ( -0.0018 0.0001 -1e-7 9e-11 -3e-14 0 0 0 ); // based on [W/mk]
	equationOfState
		Tc  132.52; 	//K
		Pc  37.56e05;	//Pa
After the change I have the issue that rhoCentralFoam does not start at all,
although all information are read and no error occurs:
log-file:
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    thermo          hPolynomial;
    specie          specie;
Reading field U
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
RAS
    RASModel        kOmegaSST;
    turbulence      on;
    printCoeffs     on;
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
    decayControl    false;
    kInf            0;
    omegaInf        0;
fluxScheme: Kurganov
Starting time loop
I took the handbook as guidance for the declaration of variables. The coefficients are taken from the VDI heat atlas.
Does anyone have a clue or might point me in the right dircetion?
Thanks in advance. Niklas
janibo is offline   Reply With Quote
Old   August 11, 2021, 09:29
Domenico Lahaye
dlahaye is on a distinguished road
1/ Does rhoCentralFoam use the constant/thermoPhysicalProperties file at all? That is, do you observe any any changes in the convergence and/or final solution when making changes in the constant/thermoPhysicalProperties file?
2/ What exactly do you mean by rhoCentralFoam not starting. Does rhoCentralFoam print message that we can learn from?
dlahaye is offline   Reply With Quote
Old   August 11, 2021, 09:53
Niklas Boehnke
Hi Domenico,
thanks for the reply.
1) Yes, rhoCentralFoam uses the thermophysicalProperty file as shown
in the first file code, that one worls like a charm with nice results.
2) No unfortunetly not. The posted log-file is all I get. rhoCentralFoam
just exits the simulation after "Starting time loop", but does not yield
an error message.
Old   August 11, 2021, 10:12
Domenico Lahaye
Does it help to increase the verbose by increasing the value of the debug switches? See e.g. line 87 to line 96 of https://github.com/OpenFOAM/OpenFOAM...tc/controlDict ?
Old   August 11, 2021, 10:33
Niklas Boehnke
So interestingly my etc\controlDict file yields around 1000 DebugSwitches,
i'm using v2012, unlike the controlDict from the docs you linked.
I am able to find entries in the etc\controlDict like
pureMixture<constTransport<thermo<hConstThermo<perfectGas>>>> 0;
but i cannot find an entry fitting the selection I have.
If I would have choosen a wrong combination of options,
OpenFOAM would have yield an error accordingly.
I picked my options from the list of valid thermoTypes.
If I had declared a varaible wrong OpenFOAM would yield an error accordingly, too.
So that is what really confuses me.
Old   August 16, 2021, 05:32
Niklas Boehnke
So I played a little bit around with the DebugSwitches, namely those
for the thermoTypes.
log-file:
Create time
Overriding DebugSwitches according to controlDict
    dimensionSet    2;
    fileName (unregistered)
    GAMGAgglomeration 2;
    level (unregistered)
    lduMatrix       2;
    SolverPerformance 2;
    vtkUnstructuredReader 2;
    type            hePsiThermo;
    thermo          hPolynomial;
    specie          specie;
Reading field U
RAS
    RASModel        kOmegaSST;
    turbulence      on;
    printCoeffs     on;
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
    decayControl    false;
    kInf            0;
    omegaInf        0;
Starting time loop
The only thing that changed is the overwriting of the DebugSwitches according to the controlDict, but other than that nothing changed.
rhocentralfoam, thermophysical properties
How to apply a turbulence model to the rhoCentralFoam solver? arussell92 OpenFOAM Pre-Processing 18 July 25, 2022 04:26
Modify rhoCentralFoam: other equations of state fivos OpenFOAM Programming & Development 5 July 29, 2020 13:17
big difference between clockTime and executionTime LM4112 OpenFOAM Running, Solving & CFD 21 February 15, 2019 03:05
[OpenFOAM] XYZ starting points of streamtraces in Paraview deniggo ParaView 3 May 22, 2013 03:02
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 08:00
