Inject tracer within the simulation volume via fvOptions |
February 9, 2017, 09:31 |
Sebastian Trunk
Rep Power: 11 |
Hello everybody,
I am struggeling with fvOptions in OF2.3.x . I want to use a cellZone as a source of tracer T and solve the equations with scalarTransportFoam on a steady simpleFoam velocity field. I have tube and an obstacle, so I do not want to inject the tracer at the beginning of the tube but right before the obstacle. I want to use the source more or less as a internal "inlet-patch" for the tracer. Values should be 1 in the source and after a while in the whole domain after the source (just like with the fixedValue inlet BC for scalarTransportFoam). I made the cellZone, set up the fvOptions file like this: Code:
tracer { type scalarSemiImplicitSource ; active on; timeStart 0; duration 10000; selectionMode cellZone; cellZone Tracer; scalarSemiImplicitSourceCoeffs { volumeMode absolute; //implicit injectionRateSuSp { T (1 0); } } } Is the source of 1 mole / itteration added to the domain every time step? Can I set a fixedValue BC for fvOption like in inletBC? Every help is thankfully appreciated. Thank you Best regards, Sebastian Last edited by sisetrun; February 10, 2017 at 02:06. |
February 10, 2017, 03:27 |
Sebastian Trunk
Rep Power: 11 |
FYI:
I managed the problem in a different way... Copied the scalarTransportFoam and added the following: Code:
// Reading from the tracerInletDict from constant folder Info<< "\n*** Detecting injection Plane from tracerInletDict in control directory***\n" << endl; Info<< "Z position is " << z_position << endl; Info<< "Deviation is " << deviation << endl; // List to store the indices of the matching mesh.C() DynamicList<label> tracer_location(0); // Extract all Cells which are in the proper range forAll(mesh.C(), idx) { if (mesh.C()[idx].component(2) >= (z_position.value() - deviation.value())) if (mesh.C()[idx].component(2) <= (z_position.value() + deviation.value())) { tracer_location.append(idx); } } // solver loop while (simple.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; while (simple.correctNonOrthogonal()) { // set the T value of proper cells to 1 forAll(tracer_location,tracer_idx) { T[tracer_location(tracer_idx)] = 1; } solve ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) == fvOptions(T) ); |
February 16, 2017, 03:42 |
Sebastian Trunk
Rep Power: 11 |
I have to open the question again...
My proposed solution worked fine on one core. When I run the simulation on a HPC, I can not use my approach. Does anybody have an idea how to run the code in parallel? Or an idea of a different solution? Thanks a lot, Best regards |
August 16, 2021, 05:20 |
Injecting a tracer from a patch inside a geometry
Luckmore Kadzungura
Rep Power: 4 |
Hallo Foamers, i am new to OpenFoam, i am trying to calculate the RTD over a small section of porous media. This means that i have ti inject my tracer at some plane inside the geometry, to do this, i created an inside patch using topoSet and createBaffles, when i then impose the tracer inlet boundary condition on that boundary condition, my scalarTransportFoam simulation diverges within the first two timesteps. i read one thread mentioning the use of fvOptions, i have never used that before, i need help. While i am still at that. I am using OF9 and it got rid of fvOptions and introduced fvModels and fvConstraints instead. i need help on how i can set up my ksimulation to be able to inject this pulse tracer at an inside zone or patch
Best regards Lucky |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
Simulation crashed shortly after it started | ce73stargazer | OpenFOAM Running, Solving & CFD | 0 | September 2, 2016 00:16 |
Air flow simulation in volume with fan and opening | koziymf | FLUENT | 0 | November 14, 2011 17:44 |
Tracer gas simulation with CFX4.3 | CFX 4.3 users | CFX | 3 | August 15, 2003 05:38 |
tidal flow simulation using finite volume method | Jason Qiu | Main CFD Forum | 0 | October 20, 2002 02:34 |
