What is difference between dev2(T(grad(U)) Gauss linear; and dev(T(grad(U))
Like Tree31Likes
  • 1 Post By Mirage
  • 30 Post By zarox
Old   September 29, 2016, 18:42
Default What is difference between dev2(T(grad(U)) Gauss linear; and dev(T(grad(U))
Mirage
Mirage is on a distinguished road
Hello Foamers
I am running a case in OF3.0.1, already solved in OF2.3.
I just noticed that the syntax for some schemes changed in the fvSchemes.
The fvSchemes has be to be edited to start the simulation.
The old fvSchemes file (OF.2.3) :
divSchemes
    div((nuEff*dev(T(grad(U))))) Gauss linear;
In the new OF version (OF3.0.1) the change must be look like this to run the case:
divSchemes
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
I was wondering, if someone could explain this changes.
Could this change effect the results? What are the difference between the using of dev2 and dev.
Thanks in advance for your help.
Dipsomaniac likes this.
Mirage is offline   Reply With Quote
Old   September 30, 2016, 07:35
Vyssion's Avatar
Vyssion
Vyssion is on a distinguished road
As far as I have found, it is literally just a naming convention to more accurately reflect what is actually happening to the variables/constants when calculating the effective viscous stress.
Optimism, pessimism, f*ck that: We're going make it happen. As God is my bloody witness, I'm hell-bent on making it work.
- Elon Musk in 2008, after three unsuccessful Falcon launches.
Vyssion is offline   Reply With Quote
Old   February 23, 2017, 08:40
Default dev and dev2 difference and implication in equation solved
Emeline Noel
zarox is on a distinguished road
Diffrence between OF2.x and OF3.x and later is the Change of the structure for turbulence model that have been unified between Compressible and incompressible flow. That lead to a Change in the additional "stabilization" term in incompressible flow with dev2 instead of dev.
Would you find here some calculation that explain dev and dev2 difference and their implication in the equation solved.
My simple calculation is for the stress Tensor, with stokes hypothesis:
\tau = \nu (\nabla u +(\nabla u)^{T})- \nu \frac{2}{3} ( \nabla . u) I
with \nabla . (\nabla u) = \Delta u and \nabla . (\nabla u)^{T} = \nabla (\nabla . u) and \nabla . ((\nabla . u) I) = \nabla (\nabla . u)
\nabla . \tau = \nu \Delta u +\nu \nabla (\nabla . u) - \nu \frac{2}{3} \nabla (\nabla . u) = \nu \Delta u + \nu \frac{1}{3} \nabla (\nabla . u)
we retrieve the compressible Navier Stoke equation.
Recalling tr((\nabla u)^{T})I=tr(\nabla u)I=(\nabla . u) I
dev2((\nabla u)^{T})=(\nabla u)^{T} - \frac{2}{3}tr((\nabla u)^{T})I = (\nabla u)^{T} - \frac{2}{3}(\nabla . u) I
\nabla . \tau = \nu \Delta u + \nu \nabla . (dev2((\nabla u)^{T})) = \nu \Delta u + \nu \nabla . (\nabla u)^{T} - \nu \frac{2}{3} \nabla . ((\nabla . u) I)
\nabla . \tau = \nu \Delta u + \nu \nabla (\nabla . u) - \nu \frac{2}{3} \nabla (\nabla . u)= \nu \Delta u+ \nu \frac{1}{3} \nabla (\nabla . u)
For incompressible and compressible flow formulation in OF3.x and OF4.x.
\nabla . \tau = \nu \Delta u+ \nu \frac{1}{3} \nabla (\nabla . u)
The dev2 use 2/3 factor but it is to lead to 1/3 factor in the stress Tensor for the part with the \nabla . u
Before,
dev((\nabla u)^{T})=(\nabla u)^{T} - \frac{1}{3}tr((\nabla u)^{T})I = (\nabla u)^{T} - \frac{1}{3}(\nabla . u) I
with
\nabla . dev((\nabla u)^{T})= \nabla(\nabla . u) - \frac{1}{3}\nabla (\nabla . u) = \frac{2}{3} \nabla (\nabla . u)
So \nabla . \tau = \nu \Delta u + \nu \frac{2}{3} \nabla (\nabla . u)
As I said, the previous implementation for incompressible flow we had
But the \nabla . u = 0 in converged flow, so as you said it would be a stabilization term
and for compressible flow as expected for Navier stoke equation for compressible
Now Incompressible and compressible flow have been write to use dev2 in the turbulence model so
But we don't get how is impacted the stability/accurancy by the formulation for incompressible with 1/3 instead of the previous 2/3
By the way, don't be worry if your old case file with the new OpenFOAM3.x and OpenFOAM4.x says
keyword div((nuEff*dev2(T(grad(U))))) is undefined in dictionary
It is because of the Change of the numerical structure explain with the use of dev2 now instead of dev even for incompressible flow. Mystery remove!
zarox is offline   Reply With Quote
