Floating point error on 3D Bump-In Channel Flow |
CHUNG Ching Chun
Rep Power: 9 ![]() |
Dear Foamers,
I am a beginner of OpenFOAM. I am now doing validation of 3D Bump-In Channel from NASA Turbulence Modelling Resources. The mesh is 9 by y-points, 89 by x-points and 41 by z-points.I am using the SpalartAllmaras model and pimpleFoam for solving. I have been getting floating point error and I know the Co increases rapidly at the 10th time step. The following is the print stack that I have got: Code:
Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 ? at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? If you need the log file, I can attach it to the next thread. I will be glad if anyone can help me. Last edited by richard.chung.jones; March 2, 2017 at 22:26. Reason: Question |
2D flow over a Bump in channel | bgraves | OpenFOAM Running, Solving & CFD | 6 | March 23, 2017 14:41 |
Simulating a Laminar Isothermal Flow in a 2D rectangular Channel | HectorRedal | Main CFD Forum | 1 | December 18, 2016 11:41 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 03:24 |
Non-steady flow simplified for use in Vissim | steamerandy | Main CFD Forum | 0 | October 31, 2011 21:08 |
