Changing the solver (from rhoSimpleFoam to rhoCentralFoam)
Like Tree1Likes
  • 1 Post By Tobi
Old   April 12, 2017, 09:47
Default Changing the solver (from rhoSimpleFoam to rhoCentralFoam)
nitw.deepak@gmail.com
DeepIndia is on a distinguished road
I want to simulate the pressure pulsation effect in Intake manifolds of IC engine. For that
I started my simulation with rhoSimpleFoam with massflow rate at outlet and total Pressure at inlet. I reached with steady state results from rhoSimpleFoam.
Now I want to change the boundary condition at outlet to zero (0) massflow rate and want to achieve the pressure pulsation effect. my new BC is like this:
Outlet
        type            flowRateInletVelocity;
        rhoInlet        1.1792;
         massFlowRate    table
        (0   -3.2793e-4)// mass flow at the beginning
        (0.0005  0) // flow reduced to zero in 0.5 milliseconds
        (1 0)
But I am facing a strange problem that my flowrate at a patch starts decreasing before the time 0.0005 s.
To me, the mass flow should remain constant to -3.2793e-4 kg/s before the time 0.5 milliseconds as the steady state has already been reached using rhoSimpleFoam.
I also made the same simulation using rhoPimpleFoam just to monitor massflow rate and I observed that it steady before 0.5 ms.
Kindly, suggest me something?
DeepIndia is offline   Reply With Quote
Old   April 12, 2017, 10:10
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
If I remember correctly, we make a linear interpolation inbetween the table:
massFlowRate    table
        (0.0005 -3.2793e-4) // mass constant till that time
        (0.001 0) // mass decrease in the next 0.5 ms
        (1 0)
Try that one and give feedback.
DeepIndia likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   April 13, 2017, 05:51
Hello Tobi, thanks for the answer. I think it is okay, because i want a linear reduction in flow rate to zero in 0.5 milliseconds and zero flow after that. And i have tested it with rhopimplefoam.
My objective is use the steady state results from rhosimplefoam and then produce the unsteady effects due to reduction in mass flow with unsteady solver.
So, i want my unsteady solver to reach first the steady state (steady mass flow) using the rhosimplefoam results. I know that in beginning there will be some oscillations and the flow will stabilize quickly.
So , I specified the following:
massFlowRate table
(0 -3.2793e-4)
(1 -3.2793e-4)
And I observed that the mass flow rate gets stable after some time if I make the transition from rhoSimpleFoam to rhoPimplefoam (see the pic).But it is not the case with the rhocentralfoam, the solver i want to use.
I think, it is because of the fact that when I compare the the createfields.h for rhoSimpleFoam and rhoPimpleFoam they create the same fields.
But rhoCentraleFoam, has some extra fields like rhoE, rhoU, pos in its createfields.h. So, when I impose the steady-state results from rhosimplefoam to rhocentralfoam there are just like an initial guess to it. And that is why the flow does not stabilize quickly.
So, may be if I can modify rhoSimpleFoam to create the extra fields like rhoE, rhoU, pos. It can work. What is your opinion?
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 08:05
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
descriptions for rhoCentralFoam solver lines immortality OpenFOAM Running, Solving & CFD 0 December 1, 2012 18:08
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
