April 12, 2016, 09:16 |
Flow around cylinder with DES in Re=3900
Qin Zhang
Rep Power: 14 |
Hi All,
I want to validate the DES model in OpenFOAM by simulating the flow around circular cylinder at Re=3900. The wake flow looks ok, but the mean Cd is around 1.2, which should be around 0.98~1.05 according to experimental data. This validation case has been test a lot by other guys and code. I also tried to increase the grid size (from 0.5m to 3.5m); play around nuTilda and nut; different numerical schemes, different OpenFOAM versions, etc. The mean Cd is still higher than I expect. Could anyone help me out? Many thanks, Qin |
March 18, 2017, 08:38 |
Fumiya Nozaki
Rep Power: 18 |
According to the following paper, the turbulence models have a relatively large impact on the mean Cd value:
https://www.researchgate.net/publica...using_OpenFOAM Best regards, Fumiya
[Personal]
March 18, 2017, 11:44 |
Uwe Pilz
Rep Power: 15 |
Dear Qin,
form this simple example - flow around a cylinder - one may learn a lot how complicated cfd simulations are. Most publications in this field are not able to show the course of the experimental data, even if one would accept some slightly dislocation of the curve. To get the real experimental data for w wide range of Reynold numbers (the most accurate are from Schlichting) is hard to solve. I experiment in that field and will sum my results in an article. But I still need some weeks for it. What I can say now is - Low Re and high Re require different strategy, differnt solvers. At the moment I calculate higher Re form 1000 upward - The mesh plays an important role. I experimented with the mesh at Re=1000, because delta x needs not to bee very high for a decent y+. A very fin mesh is not sufficient, the mesh should be well balanced. - The simulated areas need to be large enough. Especially at lower Re numbers, the y direction needs to be larger. Fluid friction reaches wide out. It is worth experimenting with that keeping the mesh balanced. - The length of simulated outflow is important too. - It is worth to find the coarsest mesh and the smallest simulated area, because at higher Re numbers the mesh needs to be much finer and the calculation time increases. At the moment I experiment with 2d geometry. If I understand all effects I will make some calculations 3d. It would last much too long if I would performe every experimental run in 3d (at a normal PC).
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 18, 2017, 13:24 |
Uwe Pilz
Rep Power: 15 |
From my experments I give you a mesh which works fine for Re=3900. Some commenst are in German, sorry fort that. The mesh comes from a simple script based mesh generator, therfore the comments are "jumping". I use LES for my simulations.
With this mesh I get a cp value of around 0.98 (it moves with the flow between 0.945 and 1.015). Maximum y+ at the cylinder wall is 9.3. I give two images of the quasi stationary flow: In the forst one, the Prandl layer can be seen easily. Code:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } convertToMeters 1; vertices ( (0.5 0 -0.5) // 0 (1 0 -0.5) // 1 (5 0 -0.5) // 2 (5 0.707107 -0.5) // 3 (0.707107 0.707107 -0.5) // 4 (0.353553 0.353553 -0.5) // 5 (5 4.5 -0.5) // 6o (0.707107 4.5 -0.5) // 7o (0 4.5 -0.5) // 8o (0 1 -0.5) // 9 (0 0.5 -0.5) //10 (-0.5 0 -0.5) //11 (-1 0 -0.5) //12 (-5 0 -0.5) //13 linke Kante (-5 0.707107 -0.5) //14 linke Kante (-0.707107 0.707107 -0.5) //15 (-0.353553 0.353553 -0.5) //16 (-5 4.5 -0.5) //17o linke Kante, obere Kante (-0.707107 4.5 -0.5) //18o = Ende oberer linker Teil (0.5 0 0.5) //19 (1 0 0.5) //20 (5 0 0.5) //21 (5 0.707107 0.5) //22 (0.707107 0.707107 0.5) //23 (0.353553 0.353553 0.5) //24 (5 4.5 0.5) //25o (0.707107 4.5 0.5) //26o (0 4.5 0.5) //27o (0 1 0.5) //28 (0 0.5 0.5) //29 (-0.5 0 0.5) //30 (-1 0 0.5) //31 (-5 0 0.5) //32 linke Kante (-5 0.707107 0.5) //33 linke Kante (-0.707107 0.707107 0.5) //34 (-0.353553 0.353553 0.5) //35 (-5 4.5 0.5) //36o linke Kante (-0.707107 4.5 0.5) //37o = Ende oberer rechter Teil (5 -0.707107 -0.5) //38 (0.707107 -0.707107 -0.5) //39 (0.353553 -0.353553 -0.5) //40 (5 -4.5 -0.5) //41u (0.707107 -4.5 -0.5) //42u (0 -4.5 -0.5) //43u (0 -1 -0.5) //44 (0 -0.5 -0.5) //45 (-5 -0.707107 -0.5) //46 (-0.707107 -0.707107 -0.5) //47 (-0.353553 -0.353553 -0.5) //48 (-5 -4.5 -0.5) //49u (-0.707107 -4.5 -0.5) //50u (5 -0.707107 0.5) //51 (0.707107 -0.707107 0.5) //52 (0.353553 -0.353553 0.5) //53 (5 -4.5 0.5) //54u (0.707107 -4.5 0.5) //55u (0 -4.5 0.5) //56u (0 -1 0.5) //57 (0 -0.5 0.5) //58 (-5 -0.707107 0.5) //59 (-0.707107 -0.707107 0.5) //60 (-0.353553 -0.353553 0.5) //61 (-5 -4.5 0.5) //62u (-0.707107 -4.5 0.5) //63u ); /* wirkliche Blöcke */ blocks ( hex ( 5 4 9 10 24 23 28 29) (5 5 1) simpleGrading (2 1 1) //0 hex ( 0 1 4 5 19 20 23 24) (5 5 1) simpleGrading (2 1 1) //1 hex ( 1 2 3 4 20 21 22 23) (45 5 1) simpleGrading (3 1 1) //2 hex ( 4 3 6 7 23 22 25 26) (45 27 1) simpleGrading (3 2 1) //3 o hex ( 9 4 7 8 28 23 26 27) (5 27 1) simpleGrading ( 1 2 1) //4 o hex (16 10 9 15 35 29 28 34) (5 5 1) simpleGrading ( 1 2 1) //5 hex (11 16 15 12 30 35 34 31) (5 5 1) simpleGrading ( 1 2 1) //6 hex (12 15 14 13 31 34 33 32) (5 25 1) simpleGrading ( 1 2 1) //7 Elemente nach vorn hex (15 18 17 14 34 37 36 33) (27 25 1) simpleGrading (2 2 1) //8 o Elemente nach vorn hex ( 9 8 18 15 28 27 37 34) (27 5 1) simpleGrading (2 1 1) //9 o hex (40 45 44 39 53 58 57 52) (5 5 1) simpleGrading ( 1 2 1) //10 hex ( 0 40 39 1 19 53 52 20) (5 5 1) simpleGrading ( 1 2 1) //11 hex ( 1 39 38 2 20 52 51 21) (5 45 1) simpleGrading ( 1 3 1) //12 hex (39 42 41 38 52 55 54 51) (27 45 1) simpleGrading (2 3 1) //13u hex (44 43 42 39 57 56 55 52) (27 5 1) simpleGrading (2 1 1) //14u hex (48 47 44 45 61 60 57 58) (5 5 1) simpleGrading (2 1 1) //15 hex (11 12 47 48 30 31 60 61) (5 5 1) simpleGrading (2 1 1) //16 hex (12 13 46 47 31 32 59 60) (25 5 1) simpleGrading (2 1 1) //17 Elemente nach vorn hex (47 46 49 50 60 59 62 63) (25 27 1) simpleGrading (2 2 1) //18u Elemente nach vorn hex (44 47 50 43 57 60 63 56) (5 27 1) simpleGrading ( 1 2 1) //19u ); edges ( arc 0 5 (0.469846 0.17101 -0.5) arc 5 10 (0.17101 0.469846 -0.5) arc 1 4 (0.939693 0.34202 -0.5) arc 4 9 (0.34202 0.939693 -0.5) arc 19 24 (0.469846 0.17101 0.5) arc 24 29 (0.17101 0.469846 0.5) arc 20 23 (0.939693 0.34202 0.5) arc 23 28 (0.34202 0.939693 0.5) arc 11 16 (-0.469846 0.17101 -0.5) arc 16 10 (-0.17101 0.469846 -0.5) arc 12 15 (-0.939693 0.34202 -0.5) arc 15 9 (-0.34202 0.939693 -0.5) arc 30 35 (-0.469846 0.17101 0.5) arc 35 29 (-0.17101 0.469846 0.5) arc 31 34 (-0.939693 0.34202 0.5) arc 34 28 (-0.34202 0.939693 0.5) arc 0 40 (0.469846 -0.17101 -0.5) arc 40 45 (0.17101 -0.469846 -0.5) arc 1 39 (0.939693 -0.34202 -0.5) arc 39 44 (0.34202 -0.939693 -0.5) arc 19 53 (0.469846 -0.17101 0.5) arc 53 58 (0.17101 -0.469846 0.5) arc 20 52 (0.939693 -0.34202 0.5) arc 52 57 (0.34202 -0.939693 0.5) arc 11 48 (-0.469846 -0.17101 -0.5) arc 48 45 (-0.17101 -0.469846 -0.5) arc 12 47 (-0.939693 -0.34202 -0.5) arc 47 44 (-0.34202 -0.939693 -0.5) arc 30 61 (-0.469846 -0.17101 0.5) arc 61 58 (-0.17101 -0.469846 0.5) arc 31 60 (-0.939693 -0.34202 0.5) arc 60 57 (-0.34202 -0.939693 0.5) ); boundary ( top { type symmetryPlane; faces ( (7 8 27 26) (6 7 26 25) (8 18 37 27) (18 17 36 37) ); } bottom { type symmetryPlane; faces ( (49 50 63 62) (50 43 56 63) (43 42 55 56) (42 41 54 55) ); } inlet { type wall; faces ( (14 13 32 33) (17 14 33 36) (46 13 32 59) (46 49 62 59) ); } outlet { type wall; faces ( (2 3 22 21) (3 6 25 22) (38 51 21 2) (41 54 51 38) ); } cylinder { type wall; faces ( (10 5 24 29) (5 0 19 24) (16 10 29 35) (11 16 35 30) (48 11 30 61) (45 48 61 58) (40 45 58 53) (0 40 53 19) ); } frontAndBack { type empty; faces ( (5 10 9 4) (24 23 28 29) (0 5 4 1) (19 20 23 24) (1 4 3 2) (20 21 22 23) (4 7 6 3) (23 22 25 26) (4 9 8 7) (28 23 26 27) (16 15 9 10) (35 29 28 34) (12 15 16 11) (31 30 35 34) (13 14 15 12) (32 31 34 33) (14 17 18 15) (33 34 37 36) (15 18 8 9) (34 28 27 37) (45 40 39 44) (58 57 52 53) (40 0 1 39) (53 52 20 19) (39 1 2 38) (52 51 21 20) (39 38 41 42) (52 55 54 51) (44 39 42 43) (57 56 55 52) (47 48 45 44) (60 57 58 61) (12 11 48 47) (31 60 61 30) (13 12 47 46) (32 59 60 31) (49 46 47 50) (62 63 60 59) (50 47 44 43) (63 56 57 60) ); } ); mergePatchPairs();
March 19, 2017, 03:39 |
Santiago Lopez Castano
Rep Power: 15 |
March 19, 2017, 05:16 |
Uwe Pilz
Rep Power: 15 |
I use the dynamic one equation eddy-viscosity model (dynamicKEqn) with simple filter.
March 19, 2017, 15:53 |
Rep Power: 15 |
Which scheme are you using for the div operators?
Sent from my GT-I8190L using CFD Online Forum mobile app |
March 20, 2017, 01:00 |
Uwe Pilz
Rep Power: 15 |
I use the van Leer schemes on most variables because the are known for increasing numerical stability. They are also known for being more diffusive, especially at sharp edges (which we don't have here).
divSchemes { default none; div(phi,U) bounded Gauss vanLeerV; div(phi,k) bounded Gauss vanLeer; div(phi,epsilon) bounded Gauss vanLeer; div(phi,R) bounded Gauss vanLeer; div(R) Gauss linear; div(phi,nuTilda) bounded Gauss vanLeer; div((nuEff*dev2(T(grad(U))))) Gauss linear; }
March 20, 2017, 02:21 |
#9 |
Rep Power: 15 |
Mmmm, two things: (1) van Leer is a NVD scheme that filters high-wavenumber scales of the field being represented, by upwinding the fluxes and reconstructing the slope of such function; (2) NVD schemes are already bounded, so I would be careful when using 'bounded' in the scheme. Lastly, you are doing boussinesq-type DES/LES , so you may want to use dispersive and high order schemes on your div grad laplacian terms.
Also, from the figures you have shown, it seems that the separation of the boundary later is not well represented by your simulation; that would explain, physically, why you are coming up with a higher Cd coefficient. Sent from my GT-I8190L using CFD Online Forum mobile app Last edited by Santiago; March 20, 2017 at 06:43. |
March 20, 2017, 12:26 |
#10 |
Uwe Pilz
Rep Power: 15 |
Dear Santiago,
thank you for your advice. I read a lot about differntiation schemes and will change my simulation to less exotic ones. Because I go for good manual mesh, many of the "tricks" seem to be unnecessary and reduce the precision of the solution.
March 22, 2017, 14:32 |
#11 |
Are you running 2D or 3D? Any LES/DES simulations should be 3D to capture the inherently 3D nature of turbulence. Running in 2D should not be expected to give you the right results.
March 23, 2017, 05:16 |
#12 |
Qin Zhang
Rep Power: 14 |
Hi piu58
Thank you for your information. I actually didn't expect anyone could reply my post after so long time. I think one of the reason of the problem maybe because Openfoam only have two-order accuracy numerical scheme, while others are using 5 order WENO or else to achieve the idea mean Cd. It's good to hear all your advice and discussion. Regards, Qin Zhang |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 16:16 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Flow induced vibration of a mobile cylinder | Hooman | Main CFD Forum | 0 | December 31, 2010 08:48 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 14:32 |
