Weird result in simulation of Taylor-Couette Flow |
March 18, 2017, 09:53 |
Amin
Hi everybody,
I have recently immigrated from Fluent to OpenFOAM, so maybe this question looks weird I'm solving classic flow of Taylor-Couette (the flow in narrow gap of two rotating concentric cylinders). The results of simulation in Fluent are exactly what I was expecting, but OpenFOAM gives strange results, as you can see in the attached photos. The vectors are slices of the 3D domain, the inner cylinder is rotating with 0.6 rad/sec and the outer one is fixed. As it's apparent from the photos there's a linear velocity for the outer cylinder which is certainly wrong. there's no inlet/outlet BC, the BC for the inner cylinder is rotatingWallVelocity and the BC for the top and bottom faces is symmetry. Any idea is appreciated |
March 19, 2017, 02:35 |
Fumiya Nozaki
Rep Power: 18 |
You might want to check the velocity boundary condition on the outer cylinder.
Is it fixed to (0 0 0)? Best regards, Fumiya
[Personal]
March 19, 2017, 06:41 |
Amin
Tnx for ur reply, actually I also changed the BC for outer cylinder to rotatingWallVelocity with zero angular velocity to force the wall to be stationary, but the results are still the same, here is the U BC for ur consideration
top { type symmetry; } innerwall { type rotatingWallVelocity; origin (0 0 0); axis (0 0 1); omega 0.6; } outerwall { type rotatingWallVelocity; origin (0 0 0); axis (0 0 1); omega 0; } bottom { type symmetry; } |
March 20, 2017, 01:32 |
Fumiya Nozaki
Rep Power: 18 |
Could you upload your case?
[Personal]
March 21, 2017, 08:53 |
Amin
yeah, sure,
please find the case using the link below: https://www.dropbox.com/s/87849pj5aecdtvh/OpenFOAM.tar.gz?dl=0 |
March 21, 2017, 10:05 |
Rep Power: 11 |
I could be wrong, but it looks like a visualisation problem from paraview. Have you enabled the "scale mode" option in the glyphs options of paraview? |
March 21, 2017, 10:39 |
#7 | |
Amin
but when I change it to "vector" the vectors get rational. I think since I wanna visualize vectors of velocity, I have to select this one in "scale mode" |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Preparing Simulation of a Sphere in a Flow | PonchO | OpenFOAM Pre-Processing | 1 | November 11, 2015 15:40 |
T-Junction using rhoPimpleFoam (Simulation blows and weird result) | mecbe2002 | OpenFOAM Running, Solving & CFD | 4 | July 23, 2015 15:26 |
parametric study in flow simulation | topaz | FloEFD, FloWorks & FloTHERM | 1 | July 13, 2015 08:50 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
