Simulation of a fluidic oscillator with SA-IDDES: oscillation frequency too high
Old   April 4, 2017, 03:57
Default Simulation of a fluidic oscillator with SA-IDDES: oscillation frequency too high
Hendrik
Zymorui is on a distinguished road
Dear Foamers,
I'm conducting a transient study of a fluidic oscillator with water at 20°C (corresponding to nu=1.004e-6). For this I'm using the SpalartAllmarasIDDES turbulence model and the pisoFoam-solver. The Mean Courant Number is 0.1 and the maximum about 7. I average the pressure over a diameter slice in each feedback loop and use the pressure difference between both to calculate a sinoid signal containing the oscillation frequency of the jet for the particular inlet velocity.
My problem is that the CFD oscillation frequency of the jet is almost the double of experimental values. The problem persists for all flow rates even in the laminar regime (where I used no turbulence model). As I have double checked the geometry, the Mesh should be fine (checkMesh):
- 1mio Cells
- blockMesh generated
- y+=1
- cell-to-cell-exp-ratio at the wall is about 1.2
- Non-Ortho-Max 58
- Max aspect ratio 152
- Max skewness 1.7
So I guess there must be something wrong with my fvSchemes or fvSolutions. Does anyone have suggestions what part of the simulation could make the oscillation frequency getting over estimated that strong?
Kind regards,
Hendrik
fvSchemes
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default backward;
d2dt2Schemes
gradSchemes
    default         cellLimited Gauss linear 1; //Gauss linear;
    //grad(nuTilda)   cellLimited Gauss linear 1;
    //grad(U)         cellLimited Gauss linear 1;
divSchemes	// convection
    default         none;
    div(phi,U)      Gauss linearUpwind grad(U); // LUST unlimitedGrad(U);
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,nuTilda) Gauss limitedLinear 1;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes   // diffusion
    default         Gauss linear limited corrected 0.33;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited corrected 0.33;
wallDist
    method meshWave;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-5;
        relTol          0.05;
        smoother        GaussSeidel;
	//nSweeps			1;
	nPreSweeps		0;
	nPostSweeps		2;
	nFinestSweeps		2;
        nCellsInCoarsestLevel 50;
	//maxIter			50;
    pFinal
        $p;
	tolerance       1e-5;
        relTol          0;
	//maxIter		100;
    "(U|k|B|nuTilda)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
	nSweeps		1;
        tolerance       1e-5;
        relTol          0;
PISO
    nCorrectors     3;
    nNonOrthogonalCorrectors 1;
relaxationFactors
	p	1;
    "U.*"               1;
    "nuTilda.*"         1;
Zymorui is offline   Reply With Quote
Old   April 4, 2017, 07:40
sati is on a distinguished road
A Courant number of 7 is way too high. You should decrease your time step to reach a maxCo < 1.
sati is offline   Reply With Quote
Old   April 11, 2017, 03:58
Hendrik
It took me some time but I've narrowed the issue down to the outlet boundary condition. I did a quick run with fluent and got the right frequency right away. (transient kOmega simulation). But fluent gave the 'A wall has been set at portions of an outlet'-notice. My fixedValue=0 pressure condition at the outlet created backflow, as the vortice cores in the outlet channel were at p<0.
I experimented with advective -> phi, BC for velocity and fixedMean for pressure but it's not quite right yet.
Does anyone have some experience with the backflow issue? Is there a BC that does something similar as fluent does?
simulation of airfoil at high AOA hsnu84053 FLUENT 0 January 26, 2007 21:34
Reasons for failed validation at high frequency zonexo Main CFD Forum 5 October 23, 2006 09:32
Airfoil simulation in High Angles of Attack Yasser Nabavi FLUENT 0 April 21, 2006 17:28
MRF simulation : continuity residual high as 0.4 guru FLUENT 2 February 7, 2005 09:33
Problem about 3D blunt body high Re simulation David FLUENT 0 September 27, 2002 10:59
