free convection in viscoelastic fluids
Old   April 14, 2017, 10:46
Default free convection in viscoelastic fluids
A. Min
alimea is on a distinguished road
Hi all
I have combined viscoelastic solver with buoyantBuossinesqPimpleFoam solver to solve free convection flow of viscoelastic fluid in a cavity. when I run the program after some time steps the run is stopped and I get this error:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5  Foam::fvMatrix<Foam::SymmTensor<double> >::solveSegregated(Foam::dictionary const&) at ??:?
#6  Foam::fvMatrix<Foam::SymmTensor<double> >::solve(Foam::dictionary const&) at ??:?
#7  Foam::Oldroyd_B::correct() at ??:?
 at ??:?
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
./Allrun: line 15: 14497 Floating point exception(core dumped) buoyantBoussinesqPimpleViscoFoam > log
meanwhile there is no problem when I run such a problem for Newtonian fluid.
when I wanted to find the reason, I saw high values of stress (in order of 10^120) in results.
Could you plz help me?
Thanks
alimea is offline   Reply With Quote
Old   April 14, 2017, 13:40
Bloerb will become famous soon enough
This is a crash from the solver. Without further information this could be due to bad boundary conditions mesh, initilization, schemes, etc and of course your programming. Check if the case runs for both solvers seperatly and then try your new one with heat transfer disabled nad then enabled.
Bloerb is offline   Reply With Quote
Old   April 20, 2017, 21:22
A. Min
Hi
Thanks for your answer.
I tried many amounts of mesh, but it isn't solved yet. Also you said that I had to solve the problem in both solver seperately, but it's impossible. because free convection is possible just with solving energy eqn. so I can't solve free convection problem by viscoelastic solver without energy eqn.
When I check the obtained values of stress tensor, I find large value! What is the problem?
free convection, viscoelasticfluid
Simulation of viscoelastic fluids subjected to shear stresses Nagesh Atreyas OpenFOAM Running, Solving & CFD 1 October 27, 2016 04:02
free convection flow and heat transfer alimea CFX 1 October 6, 2016 09:23
forced and free convection over a hot sphere the new one Main CFD Forum 0 October 16, 2013 04:32
Free Stream Temperature in natural convection problem tomcatbobby FLUENT 2 January 27, 2011 05:41
free convection Charif Main CFD Forum 0 January 24, 1999 00:06
