May 11, 2017, 14:12 |
acoupling scilab anda openfoam
Fábio
Rep Power: 9 |
Does anyone know how to call openfoam in scilab?
May 11, 2017, 15:58 |
You have to be more specific or you get an answer: Code:
unix_w('icoFoam') |
May 11, 2017, 16:12 |
Fábio
Rep Power: 9 |
Buddy, I'm going to create an optimization routine, and I need to run an openfoam solver with every iteration of my algorithm.
May 11, 2017, 16:20 |
If you would like me to repeat previous answer, OK. You can read it one more time.
Though at this point it is starting to look like it is me, who is implementing "optimisation routine": - What data is handled by Scilab? - What data is handled by OpenFOAM? - What is transferred to OpenFOAM? What is transferred back? If you need ATOM, then no, there is no readily available ATOM. |
May 11, 2017, 16:29 |
Fábio
Rep Power: 9 |
What data is treated by Scilab?
Optimization of parameters in Scilab. I need to get data from opemfoam. What data is OpenFOAM treated? Solution of an EDP. I need the parameters calculated in Scilab. What is transferred to OpenFOAM? What is transferred back? Parameters are transferred to Openfoam. The EDP solution is sent back to Scilab. |
May 11, 2017, 16:32 |
OK. It seems my first answer was correct one.
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
Calling OpenFOAM from Scilab | Jefferson_dhv | OpenFOAM Pre-Processing | 6 | February 5, 2016 16:56 |
OpenFOAM Foundation releases OpenFOAM® 3.0.0 | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 1 | November 7, 2015 15:16 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 07:18 |
