May 12, 2017, 23:07 |
groovyBC floating exception
Rep Power: 9 |
Hello all,
I'm using OpenFOAM to simulate a microchannel. And I have to use groovyBC for a boundary condition. I compiled swak4Foam with OpenFOAM 4.1. Now the minimum mesh size is around 2.5e-06, and when I'm using decomposePar, I will see a floating exception. It seems like the function 'delta()' in groovyBC is not working. If I use a coarse mesh with a minimum size of 5e-06 there won't be any problem. My boundary condition (a Robin B.C.) is: Code:
bottom { type groovyBC; variables "GT=snGrad(T);DT=7.92e-13;DC=4.4e-12;"; valueExpression "0"; gradientExpression "0"; fractionExpression "1/(1+DC/(DT*GT*mag(delta())))"; } Code:
--> FOAM Warning : From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(const fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict) in file groovyBCFvPatchField.C at line 131 No value defined for C on bottom therefore using the internal field next to the patch #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? #4 Foam::operator/(double const&, Foam::tmp<Foam::Field<double> > const&) at ??:? #5 Foam::surfaceInterpolation::makeDeltaCoeffs() const at ??:? #6 Foam::surfaceInterpolation::deltaCoeffs() const at ??:? #7 Foam::fvPatch::deltaCoeffs() const at ??:? #8 Foam::groovyBCFvPatchField<double>::groovyBCFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #9 Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::groovyBCFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #10 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #11 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #12 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:? #13 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:? #14 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) at ??:? #15 ? at ??:? #16 ? at ??:? #17 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #18 ? at ??:? Floating point exception (core dumped) Thanks! |
May 14, 2017, 21:04 |
Rep Power: 9 |
OK so I have solved this issue by myself. It turned out to be a meshing problem.
I used a faulty STL which is not closed and snappyHexMesh generated a bad mesh without any warning and error. After fixing the STL file it's working properly. |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 12:31 |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
[foam-extend.org] foam-extend 3.2 on Ubuntu 12.04, Floating point exception for tutorials | arsalan.dryi | OpenFOAM Installation | 7 | November 14, 2016 17:33 |
A floating point exception has occurred: floating point exception [Overflow]. | starlight | STAR-CCM+ | 4 | May 4, 2016 09:08 |
Temperature floating point exception | ayckrom | FLUENT | 1 | May 13, 2015 09:02 |
