May 23, 2017, 22:41 |
icoFoam same pressure throughout
Sugajen
Rep Power: 14 |
Hi all,
I am new to OpenFOAM. I started modeling a rectangular domain with inlet velocity and outlet pressure. Tried to solve it with icoFoam but unfortunately from the very first time step, the pressure in the internalField is equal to the outlet pressure. No matter how small the outlet pressure is, internalField takes that value. Any help/suggestions will be very much appreciated. Pressure BC Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 6010; } fixedWalls { type zeroGradient; } lowerMembrane { type zeroGradient; } upperMembrane { type zeroGradient; } } Velocity BC Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0.1 0 0); } outlet { type zeroGradient; } fixedWalls { type noSlip; } lowerMembrane { type noSlip; } upperMembrane { type noSlip; } } Code:
convertToMeters 0.001; vertices ( (0 0 0) (4.5 0 0) (4.5 4.5 0) (0 4.5 0) (0 0 1) (4.5 0 1) (4.5 4.5 1) (0 4.5 1) ); blocks ( hex (0 1 2 3 4 5 6 7) (9 9 2) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (0 4 7 3) ); } outlet { type patch; faces ( (1 2 6 5) ); } fixedWalls { type wall; faces ( (3 7 6 2) (1 5 4 0) ); } upperMembrane { type wall; faces ( (4 5 6 7) ); } lowerMembrane { type wall; faces ( (0 3 2 1) ); } ); mergePatchPairs ( ); |
May 24, 2017, 05:48 |
How did you find "the pressure in the internalField is equal to the outlet pressure"? By viewing the results in some post-processor like paraview? If that's the case, you could probably try cell data instead of point data.
May 24, 2017, 09:53 |
Joshua
Rep Power: 9 |
You have initial fields set to 0 for pressure, with a high outlet pressure of 6010. Your pressure outlet is therefore going to dominate the domain. I would suggest initializing your pressure field as 6010 (same as your outlet). That way velocity can then effect the initialized system.
Joshua |
May 24, 2017, 21:03 |
Still searching for a solution
Sugajen
Rep Power: 14 |
@Bao & @Joshua,
I tried both your suggestions but didn't work. Do you think I should consider changing my boundary conditions - zeroGradient to something else? When I changed them to 0, it did not work. |
May 25, 2017, 09:12 |
Joshua
Rep Power: 9 |
Have you tried running another transient solver like pisoFoam or pimpleFoam? In my opinion they are much better solvers then icoFoam.
Joshua |
May 25, 2017, 14:23 |
pimpleFoam crashes
Sugajen
Rep Power: 14 |
@Joshua
Actually, I was using pimpleFoam at first. But it throws an error at the eight time step which I am posting below. That's why I switched to icoFoam. Code:
Courant Number mean: 1.95828e+100 max: 1.87544e+101 Time = 0.088 PIMPLE: iteration 1 GAMG: Solving for p, Initial residual = 0.832383, Final residual = 0.0176052, No Iterations 1 time step continuity errors : sum local = 1.25645e+99, global = -9.31495e+98, cumulative = -1.0294e+99 smoothSolver: Solving for sigmaxx, Initial residual = 0.747741, Final residual = 0.0639805, No Iterations 2 smoothSolver: Solving for sigmaxy, Initial residual = 0.693769, Final residual = 0.055105, No Iterations 2 smoothSolver: Solving for sigmaxz, Initial residual = 0.682691, Final residual = 0.054775, No Iterations 2 smoothSolver: Solving for sigmayy, Initial residual = 0.56351, Final residual = 0.0472953, No Iterations 2 smoothSolver: Solving for sigmayz, Initial residual = 0.543234, Final residual = 0.0470379, No Iterations 2 smoothSolver: Solving for sigmazz, Initial residual = 0.528148, Final residual = 0.0493034, No Iterations 2 PIMPLE: iteration 2 GAMG: Solving for p, Initial residual = 0.710975, Final residual = 0.0105144, No Iterations 1 time step continuity errors : sum local = 2.26049e+99, global = -5.74118e+98, cumulative = -1.60351e+99 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 void Foam::dot<Foam::SymmTensor<double>, Foam::Tensor<double> >(Foam::Field<Foam::innerProduct<Foam::SymmTensor<double>, Foam::Tensor<double> >::type>&, Foam::UList<Foam::SymmTensor<double> > const&, Foam::UList<Foam::Tensor<double> > const&) at ??:? #4 Foam::tmp<Foam::GeometricField<Foam::innerProduct<Foam::SymmTensor<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::operator&<Foam::SymmTensor<double>, Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::laminarModels::Maxwell<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() at ??:? #6 ? in "/home/sugajen/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/home/sugajen/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" Floating point exception (core dumped) Thanks! |
May 25, 2017, 14:26 |
Joshua
Rep Power: 9 |
Your time step is too large.
1) Reduce your time step by a magnitude of 10 2) You can turn on adjustable timestep for pimple and set a max Co of 1. Joshua |
May 25, 2017, 14:52 |
Still crashing
Sugajen
Rep Power: 14 |
Thank you Joshua!
Did as you suggested. Reduced the timeStep size as well as set a maxCo. But it is still crashing. Though we set a maxCo of 0.5, the iterations go well beyond that. Am I missing something? Please find my controlDict file and output of the last successful iteration below. controlDict: Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.1; deltaT 0.0001; writeControl timeStep; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep true; maxDeltaT 0.0001; maxCo 0.5; Code:
Courant Number mean: 0.663709 max: 6.71235 deltaT = 2.38759e-104 Time = 0.0714291 PIMPLE: iteration 1 GAMG: Solving for p, Initial residual = 0.729669, Final residual = 0.00895447, No Iterations 1 time step continuity errors : sum local = 0.000363231, global = 2.0545e-05, cumulative = 23.0525 smoothSolver: Solving for sigmaxx, Initial residual = 0.156834, Final residual = 0.000662181, No Iterations 1 smoothSolver: Solving for sigmaxy, Initial residual = 0.13604, Final residual = 0.000885931, No Iterations 1 smoothSolver: Solving for sigmaxz, Initial residual = 0.140816, Final residual = 0.000860439, No Iterations 1 smoothSolver: Solving for sigmayy, Initial residual = 0.126032, Final residual = 0.00120917, No Iterations 1 smoothSolver: Solving for sigmayz, Initial residual = 0.126016, Final residual = 0.0011654, No Iterations 1 smoothSolver: Solving for sigmazz, Initial residual = 0.128925, Final residual = 0.00115707, No Iterations 1 PIMPLE: iteration 2 GAMG: Solving for p, Initial residual = 0.143409, Final residual = 0.00322247, No Iterations 1 time step continuity errors : sum local = 0.000251366, global = 4.45186e-05, cumulative = 23.0525 smoothSolver: Solving for sigmaxx, Initial residual = 0.134324, Final residual = 0.000689652, No Iterations 1 smoothSolver: Solving for sigmaxy, Initial residual = 0.119069, Final residual = 0.00070716, No Iterations 1 smoothSolver: Solving for sigmaxz, Initial residual = 0.121229, Final residual = 0.000755986, No Iterations 1 smoothSolver: Solving for sigmayy, Initial residual = 0.094852, Final residual = 0.000903834, No Iterations 1 smoothSolver: Solving for sigmayz, Initial residual = 0.0985399, Final residual = 0.000890833, No Iterations 1 smoothSolver: Solving for sigmazz, Initial residual = 0.103933, Final residual = 0.000922095, No Iterations 1 PIMPLE: iteration 3 GAMG: Solving for p, Initial residual = 0.13444, Final residual = 0.00277385, No Iterations 1 time step continuity errors : sum local = 0.000274193, global = 4.10307e-05, cumulative = 23.0526 smoothSolver: Solving for sigmaxx, Initial residual = 0.1354, Final residual = 0.00123334, No Iterations 1 smoothSolver: Solving for sigmaxy, Initial residual = 0.130423, Final residual = 0.00140532, No Iterations 1 smoothSolver: Solving for sigmaxz, Initial residual = 0.133621, Final residual = 0.00144555, No Iterations 1 smoothSolver: Solving for sigmayy, Initial residual = 0.107672, Final residual = 0.00154916, No Iterations 1 smoothSolver: Solving for sigmayz, Initial residual = 0.112155, Final residual = 0.00160124, No Iterations 1 smoothSolver: Solving for sigmazz, Initial residual = 0.116955, Final residual = 0.0016714, No Iterations 1 PIMPLE: iteration 4 GAMG: Solving for p, Initial residual = 0.154451, Final residual = 0.00313977, No Iterations 1 time step continuity errors : sum local = 0.000397578, global = 3.54349e-05, cumulative = 23.0526 smoothSolver: Solving for sigmaxx, Initial residual = 0.157579, Final residual = 0.00266918, No Iterations 1 smoothSolver: Solving for sigmaxy, Initial residual = 0.152596, Final residual = 0.00308912, No Iterations 1 smoothSolver: Solving for sigmaxz, Initial residual = 0.156793, Final residual = 0.00311075, No Iterations 1 smoothSolver: Solving for sigmayy, Initial residual = 0.146138, Final residual = 0.00377687, No Iterations 1 smoothSolver: Solving for sigmayz, Initial residual = 0.15078, Final residual = 0.00380433, No Iterations 1 smoothSolver: Solving for sigmazz, Initial residual = 0.154905, Final residual = 0.0038161, No Iterations 1 PIMPLE: iteration 5 GAMG: Solving for p, Initial residual = 0.196638, Final residual = 0.00411544, No Iterations 1 time step continuity errors : sum local = 0.000704938, global = 3.31079e-05, cumulative = 23.0526 smoothSolver: Solving for sigmaxx, Initial residual = 0.205283, Final residual = 0.00651574, No Iterations 1 smoothSolver: Solving for sigmaxy, Initial residual = 0.197487, Final residual = 0.00771348, No Iterations 1 smoothSolver: Solving for sigmaxz, Initial residual = 0.202468, Final residual = 0.00770267, No Iterations 1 smoothSolver: Solving for sigmayy, Initial residual = 0.196547, Final residual = 0.00977995, No Iterations 1 smoothSolver: Solving for sigmayz, Initial residual = 0.198549, Final residual = 0.00964261, No Iterations 1 smoothSolver: Solving for sigmazz, Initial residual = 0.205165, Final residual = 0.00963499, No Iterations 1 PIMPLE: iteration 6 GAMG: Solving for p, Initial residual = 0.267345, Final residual = 0.00569992, No Iterations 1 time step continuity errors : sum local = 0.00145128, global = 3.15007e-05, cumulative = 23.0527 smoothSolver: Solving for sigmaxx, Initial residual = 0.277455, Final residual = 0.0152066, No Iterations 1 smoothSolver: Solving for sigmaxy, Initial residual = 0.265611, Final residual = 0.0184275, No Iterations 1 smoothSolver: Solving for sigmaxz, Initial residual = 0.270851, Final residual = 0.0180328, No Iterations 1 smoothSolver: Solving for sigmayy, Initial residual = 0.271589, Final residual = 0.0241334, No Iterations 1 smoothSolver: Solving for sigmayz, Initial residual = 0.269955, Final residual = 0.0229864, No Iterations 1 smoothSolver: Solving for sigmazz, Initial residual = 0.276123, Final residual = 0.0222251, No Iterations 1 PIMPLE: iteration 7 GAMG: Solving for p, Initial residual = 0.354711, Final residual = 0.00776282, No Iterations 1 time step continuity errors : sum local = 0.00330826, global = 1.97892e-05, cumulative = 23.0527 smoothSolver: Solving for sigmaxx, Initial residual = 0.356287, Final residual = 0.0325556, No Iterations 1 smoothSolver: Solving for sigmaxy, Initial residual = 0.341959, Final residual = 0.00701936, No Iterations 2 smoothSolver: Solving for sigmaxz, Initial residual = 0.346168, Final residual = 0.00671219, No Iterations 2 smoothSolver: Solving for sigmayy, Initial residual = 0.356212, Final residual = 0.00887653, No Iterations 2 smoothSolver: Solving for sigmayz, Initial residual = 0.352708, Final residual = 0.00833179, No Iterations 2 smoothSolver: Solving for sigmazz, Initial residual = 0.356016, Final residual = 0.00778691, No Iterations 2 PIMPLE: iteration 8 GAMG: Solving for p, Initial residual = 0.435929, Final residual = 0.00935036, No Iterations 1 time step continuity errors : sum local = 0.00741005, global = 0.000179898, cumulative = 23.0529 smoothSolver: Solving for sigmaxx, Initial residual = 0.42109, Final residual = 0.0130746, No Iterations 2 smoothSolver: Solving for sigmaxy, Initial residual = 0.432944, Final residual = 0.0158246, No Iterations 2 smoothSolver: Solving for sigmaxz, Initial residual = 0.436075, Final residual = 0.0151397, No Iterations 2 smoothSolver: Solving for sigmayy, Initial residual = 0.445616, Final residual = 0.0183585, No Iterations 2 smoothSolver: Solving for sigmayz, Initial residual = 0.439054, Final residual = 0.0176198, No Iterations 2 smoothSolver: Solving for sigmazz, Initial residual = 0.433173, Final residual = 0.016696, No Iterations 2 PIMPLE: iteration 9 GAMG: Solving for p, Initial residual = 0.50547, Final residual = 0.010613, No Iterations 1 time step continuity errors : sum local = 0.0168803, global = 0.00190167, cumulative = 23.0548 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::twoSymm(Foam::Field<Foam::SymmTensor<double> >&, Foam::UList<Foam::Tensor<double> > const&) at ??:? #4 Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::twoSymm<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 Foam::laminarModels::Maxwell<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() at ??:? #6 ? in "/home/sugajen/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/home/sugajen/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" Floating point exception (core dumped) |
May 25, 2017, 14:56 |
#9 |
Joshua
Rep Power: 9 |
What scheme are you using for time? Euler?
Joshua |
May 25, 2017, 15:00 |
backward
#10 |
Sugajen
Rep Power: 14 |
I have been using backward!
May 25, 2017, 15:13 |
#11 |
Joshua
Rep Power: 9 |
Try using Euler as see how that does.
Joshua |
May 25, 2017, 15:15 |
All time schemes fail
#12 |
Sugajen
Rep Power: 14 |
Sure Joshua! Just tried CrankNicolson 0.9, Euler, localEuler, none and steadyState.
All of them fail at time = 0.07. There is something happening at t = 0.07. |
May 25, 2017, 15:30 |
#13 |
Joshua
Rep Power: 9 |
At this point I would be guessing its your mesh. Maybe something isn't refined enough or you have a funky cell.
Joshua |
May 25, 2017, 17:46 |
It must be the mesh
#14 |
Sugajen
Rep Power: 14 |
That was a good guess! As I doubled and quadrupled the cells per side of the mesh, the solution crashed at half and quarter of the previous total times correspondingly.
I checked the mesh and vertices multiple times but nothing I can see wrong. Any thoughts? Thank you! |
Pressure Inlet Boundary Conditions | Mr.Goodcat | FLUENT | 5 | June 20, 2019 01:47 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
pressure distribution in water flow, differences in icoFoam and COMSOL | deniggo | OpenFOAM Running, Solving & CFD | 14 | September 30, 2010 03:48 |
