icoFoam same pressure throughout
Old   May 23, 2017, 22:41
Default icoFoam same pressure throughout
Sugajen
Sugajen is on a distinguished road
I am new to OpenFOAM. I started modeling a rectangular domain with inlet velocity and outlet pressure. Tried to solve it with icoFoam but unfortunately from the very first time step, the pressure in the internalField is equal to the outlet pressure. No matter how small the outlet pressure is, internalField takes that value. Any help/suggestions will be very much appreciated.
Pressure BC
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 6010;
    fixedWalls
        type            zeroGradient;
    lowerMembrane
        type            zeroGradient;
    upperMembrane
        type            zeroGradient;
Velocity BC
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0.1 0 0);
    outlet
        type            zeroGradient;
    fixedWalls
        type            noSlip;
    lowerMembrane
        type            noSlip;
    upperMembrane
        type            noSlip;
blockMeshDict
convertToMeters 0.001;
vertices
    (0 0 0)
    (4.5 0 0)
    (4.5 4.5 0)
    (0 4.5 0)
    (0 0 1)
    (4.5 0 1)
    (4.5 4.5 1)
    (0 4.5 1)
blocks
    hex (0 1 2 3 4 5 6 7) (9 9 2) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
         (0 4 7 3)
    outlet
        type patch;
        faces
         (1 2 6 5)
    fixedWalls
        type wall;
        faces
        (   (3 7 6 2)
            (1 5 4 0)
    upperMembrane
	type wall;
	faces
	 (4 5 6 7)
    lowerMembrane
	type wall;
	faces
         (0 3 2 1)
mergePatchPairs
Sugajen is offline   Reply With Quote
Old   May 24, 2017, 05:48
bao42 is on a distinguished road
How did you find "the pressure in the internalField is equal to the outlet pressure"? By viewing the results in some post-processor like paraview? If that's the case, you could probably try cell data instead of point data.
bao42 is offline   Reply With Quote
Old   May 24, 2017, 09:53
Joshua
Joshua14 is on a distinguished road
You have initial fields set to 0 for pressure, with a high outlet pressure of 6010. Your pressure outlet is therefore going to dominate the domain. I would suggest initializing your pressure field as 6010 (same as your outlet). That way velocity can then effect the initialized system.
Joshua
Joshua14 is offline   Reply With Quote
Old   May 24, 2017, 21:03
Default Still searching for a solution
Sugajen
@Bao & @Joshua,
I tried both your suggestions but didn't work. Do you think I should consider changing my boundary conditions - zeroGradient to something else? When I changed them to 0, it did not work.
Old   May 25, 2017, 09:12
Joshua
Have you tried running another transient solver like pisoFoam or pimpleFoam? In my opinion they are much better solvers then icoFoam.
Joshua
Old   May 25, 2017, 14:23
Default pimpleFoam crashes
Sugajen
@Joshua
Actually, I was using pimpleFoam at first. But it throws an error at the eight time step which I am posting below. That's why I switched to icoFoam.
 Courant Number mean: 1.95828e+100 max: 1.87544e+101
Time = 0.088
PIMPLE: iteration 1
GAMG:  Solving for p, Initial residual = 0.832383, Final residual = 0.0176052, No Iterations 1
time step continuity errors : sum local = 1.25645e+99, global = -9.31495e+98, cumulative = -1.0294e+99
smoothSolver:  Solving for sigmaxx, Initial residual = 0.747741, Final residual = 0.0639805, No Iterations 2
smoothSolver:  Solving for sigmaxy, Initial residual = 0.693769, Final residual = 0.055105, No Iterations 2
smoothSolver:  Solving for sigmaxz, Initial residual = 0.682691, Final residual = 0.054775, No Iterations 2
smoothSolver:  Solving for sigmayy, Initial residual = 0.56351, Final residual = 0.0472953, No Iterations 2
smoothSolver:  Solving for sigmayz, Initial residual = 0.543234, Final residual = 0.0470379, No Iterations 2
smoothSolver:  Solving for sigmazz, Initial residual = 0.528148, Final residual = 0.0493034, No Iterations 2
PIMPLE: iteration 2
GAMG:  Solving for p, Initial residual = 0.710975, Final residual = 0.0105144, No Iterations 1
time step continuity errors : sum local = 2.26049e+99, global = -5.74118e+98, cumulative = -1.60351e+99
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  void Foam::dot<Foam::SymmTensor<double>, Foam::Tensor<double> >(Foam::Field<Foam::innerProduct<Foam::SymmTensor<double>, Foam::Tensor<double> >::type>&, Foam::UList<Foam::SymmTensor<double> > const&, Foam::UList<Foam::Tensor<double> > const&) at ??:?
#4  Foam::tmp<Foam::GeometricField<Foam::innerProduct<Foam::SymmTensor<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::operator&<Foam::SymmTensor<double>, Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5  Foam::laminarModels::Maxwell<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() at ??:?
#6  ? in "/home/sugajen/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8  ? in "/home/sugajen/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
Floating point exception (core dumped)
The Courant number shoots up. What do you think is the problem ?
Thanks!
Old   May 25, 2017, 14:26
Joshua
Your time step is too large.
1) Reduce your time step by a magnitude of 10
2) You can turn on adjustable timestep for pimple and set a max Co of 1.
Joshua
Old   May 25, 2017, 14:52
Default Still crashing
Sugajen
Thank you Joshua!
Did as you suggested. Reduced the timeStep size as well as set a maxCo. But it is still crashing. Though we set a maxCo of 0.5, the iterations go well beyond that. Am I missing something?
Please find my controlDict file and output of the last successful iteration below.
controlDict:
 FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pimpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.1;
deltaT          0.0001;
writeControl    timeStep;
writeInterval   100;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep true;
maxDeltaT	0.0001;
maxCo		0.5;
Output:
 Courant Number mean: 0.663709 max: 6.71235
deltaT = 2.38759e-104
Time = 0.0714291
PIMPLE: iteration 1
GAMG:  Solving for p, Initial residual = 0.729669, Final residual = 0.00895447, No Iterations 1
time step continuity errors : sum local = 0.000363231, global = 2.0545e-05, cumulative = 23.0525
smoothSolver:  Solving for sigmaxx, Initial residual = 0.156834, Final residual = 0.000662181, No Iterations 1
smoothSolver:  Solving for sigmaxy, Initial residual = 0.13604, Final residual = 0.000885931, No Iterations 1
smoothSolver:  Solving for sigmaxz, Initial residual = 0.140816, Final residual = 0.000860439, No Iterations 1
smoothSolver:  Solving for sigmayy, Initial residual = 0.126032, Final residual = 0.00120917, No Iterations 1
smoothSolver:  Solving for sigmayz, Initial residual = 0.126016, Final residual = 0.0011654, No Iterations 1
smoothSolver:  Solving for sigmazz, Initial residual = 0.128925, Final residual = 0.00115707, No Iterations 1
PIMPLE: iteration 2
GAMG:  Solving for p, Initial residual = 0.143409, Final residual = 0.00322247, No Iterations 1
time step continuity errors : sum local = 0.000251366, global = 4.45186e-05, cumulative = 23.0525
smoothSolver:  Solving for sigmaxx, Initial residual = 0.134324, Final residual = 0.000689652, No Iterations 1
smoothSolver:  Solving for sigmaxy, Initial residual = 0.119069, Final residual = 0.00070716, No Iterations 1
smoothSolver:  Solving for sigmaxz, Initial residual = 0.121229, Final residual = 0.000755986, No Iterations 1
smoothSolver:  Solving for sigmayy, Initial residual = 0.094852, Final residual = 0.000903834, No Iterations 1
smoothSolver:  Solving for sigmayz, Initial residual = 0.0985399, Final residual = 0.000890833, No Iterations 1
smoothSolver:  Solving for sigmazz, Initial residual = 0.103933, Final residual = 0.000922095, No Iterations 1
PIMPLE: iteration 3
GAMG:  Solving for p, Initial residual = 0.13444, Final residual = 0.00277385, No Iterations 1
time step continuity errors : sum local = 0.000274193, global = 4.10307e-05, cumulative = 23.0526
smoothSolver:  Solving for sigmaxx, Initial residual = 0.1354, Final residual = 0.00123334, No Iterations 1
smoothSolver:  Solving for sigmaxy, Initial residual = 0.130423, Final residual = 0.00140532, No Iterations 1
smoothSolver:  Solving for sigmaxz, Initial residual = 0.133621, Final residual = 0.00144555, No Iterations 1
smoothSolver:  Solving for sigmayy, Initial residual = 0.107672, Final residual = 0.00154916, No Iterations 1
smoothSolver:  Solving for sigmayz, Initial residual = 0.112155, Final residual = 0.00160124, No Iterations 1
smoothSolver:  Solving for sigmazz, Initial residual = 0.116955, Final residual = 0.0016714, No Iterations 1
PIMPLE: iteration 4
GAMG:  Solving for p, Initial residual = 0.154451, Final residual = 0.00313977, No Iterations 1
time step continuity errors : sum local = 0.000397578, global = 3.54349e-05, cumulative = 23.0526
smoothSolver:  Solving for sigmaxx, Initial residual = 0.157579, Final residual = 0.00266918, No Iterations 1
smoothSolver:  Solving for sigmaxy, Initial residual = 0.152596, Final residual = 0.00308912, No Iterations 1
smoothSolver:  Solving for sigmaxz, Initial residual = 0.156793, Final residual = 0.00311075, No Iterations 1
smoothSolver:  Solving for sigmayy, Initial residual = 0.146138, Final residual = 0.00377687, No Iterations 1
smoothSolver:  Solving for sigmayz, Initial residual = 0.15078, Final residual = 0.00380433, No Iterations 1
smoothSolver:  Solving for sigmazz, Initial residual = 0.154905, Final residual = 0.0038161, No Iterations 1
PIMPLE: iteration 5
GAMG:  Solving for p, Initial residual = 0.196638, Final residual = 0.00411544, No Iterations 1
time step continuity errors : sum local = 0.000704938, global = 3.31079e-05, cumulative = 23.0526
smoothSolver:  Solving for sigmaxx, Initial residual = 0.205283, Final residual = 0.00651574, No Iterations 1
smoothSolver:  Solving for sigmaxy, Initial residual = 0.197487, Final residual = 0.00771348, No Iterations 1
smoothSolver:  Solving for sigmaxz, Initial residual = 0.202468, Final residual = 0.00770267, No Iterations 1
smoothSolver:  Solving for sigmayy, Initial residual = 0.196547, Final residual = 0.00977995, No Iterations 1
smoothSolver:  Solving for sigmayz, Initial residual = 0.198549, Final residual = 0.00964261, No Iterations 1
smoothSolver:  Solving for sigmazz, Initial residual = 0.205165, Final residual = 0.00963499, No Iterations 1
PIMPLE: iteration 6
GAMG:  Solving for p, Initial residual = 0.267345, Final residual = 0.00569992, No Iterations 1
time step continuity errors : sum local = 0.00145128, global = 3.15007e-05, cumulative = 23.0527
smoothSolver:  Solving for sigmaxx, Initial residual = 0.277455, Final residual = 0.0152066, No Iterations 1
smoothSolver:  Solving for sigmaxy, Initial residual = 0.265611, Final residual = 0.0184275, No Iterations 1
smoothSolver:  Solving for sigmaxz, Initial residual = 0.270851, Final residual = 0.0180328, No Iterations 1
smoothSolver:  Solving for sigmayy, Initial residual = 0.271589, Final residual = 0.0241334, No Iterations 1
smoothSolver:  Solving for sigmayz, Initial residual = 0.269955, Final residual = 0.0229864, No Iterations 1
smoothSolver:  Solving for sigmazz, Initial residual = 0.276123, Final residual = 0.0222251, No Iterations 1
PIMPLE: iteration 7
GAMG:  Solving for p, Initial residual = 0.354711, Final residual = 0.00776282, No Iterations 1
time step continuity errors : sum local = 0.00330826, global = 1.97892e-05, cumulative = 23.0527
smoothSolver:  Solving for sigmaxx, Initial residual = 0.356287, Final residual = 0.0325556, No Iterations 1
smoothSolver:  Solving for sigmaxy, Initial residual = 0.341959, Final residual = 0.00701936, No Iterations 2
smoothSolver:  Solving for sigmaxz, Initial residual = 0.346168, Final residual = 0.00671219, No Iterations 2
smoothSolver:  Solving for sigmayy, Initial residual = 0.356212, Final residual = 0.00887653, No Iterations 2
smoothSolver:  Solving for sigmayz, Initial residual = 0.352708, Final residual = 0.00833179, No Iterations 2
smoothSolver:  Solving for sigmazz, Initial residual = 0.356016, Final residual = 0.00778691, No Iterations 2
PIMPLE: iteration 8
GAMG:  Solving for p, Initial residual = 0.435929, Final residual = 0.00935036, No Iterations 1
time step continuity errors : sum local = 0.00741005, global = 0.000179898, cumulative = 23.0529
smoothSolver:  Solving for sigmaxx, Initial residual = 0.42109, Final residual = 0.0130746, No Iterations 2
smoothSolver:  Solving for sigmaxy, Initial residual = 0.432944, Final residual = 0.0158246, No Iterations 2
smoothSolver:  Solving for sigmaxz, Initial residual = 0.436075, Final residual = 0.0151397, No Iterations 2
smoothSolver:  Solving for sigmayy, Initial residual = 0.445616, Final residual = 0.0183585, No Iterations 2
smoothSolver:  Solving for sigmayz, Initial residual = 0.439054, Final residual = 0.0176198, No Iterations 2
smoothSolver:  Solving for sigmazz, Initial residual = 0.433173, Final residual = 0.016696, No Iterations 2
PIMPLE: iteration 9
GAMG:  Solving for p, Initial residual = 0.50547, Final residual = 0.010613, No Iterations 1
time step continuity errors : sum local = 0.0168803, global = 0.00190167, cumulative = 23.0548
#3  Foam::twoSymm(Foam::Field<Foam::SymmTensor<double> >&, Foam::UList<Foam::Tensor<double> > const&) at ??:?
#4  Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::twoSymm<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
Old   May 25, 2017, 14:56
Joshua
What scheme are you using for time? Euler?
Joshua
Old   May 25, 2017, 15:00
Default backward
Sugajen
I have been using backward!
Old   May 25, 2017, 15:13
Joshua
Try using Euler as see how that does.
Joshua
Old   May 25, 2017, 15:15
Default All time schemes fail
  #12
Sugajen
Sure Joshua! Just tried CrankNicolson 0.9, Euler, localEuler, none and steadyState.
All of them fail at time = 0.07.
There is something happening at t = 0.07.
Old   May 25, 2017, 15:30
Joshua
At this point I would be guessing its your mesh. Maybe something isn't refined enough or you have a funky cell.
Joshua
Old   May 25, 2017, 17:46
Default It must be the mesh
  #14
Sugajen
That was a good guess! As I doubled and quadrupled the cells per side of the mesh, the solution crashed at half and quarter of the previous total times correspondingly.
I checked the mesh and vertices multiple times but nothing I can see wrong. Any thoughts?
Thank you!
Pressure Inlet Boundary Conditions Mr.Goodcat FLUENT 5 June 20, 2019 01:47
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
pressure distribution in water flow, differences in icoFoam and COMSOL deniggo OpenFOAM Running, Solving & CFD 14 September 30, 2010 03:48
