drag and lift coefficients in axisymmetric and 3D simulations! |
July 1, 2017, 16:33 |
OpenFoam
Rep Power: 9 |
Hi All,
I am working on verifying the drag and lift coefficients using two different simulations (axisymmetric vs. 3D) of the flow over a C-D nozzle. Both simulations converged with four orders of magnitude. In both simulations, I have used the following force function; Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ forces { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; outputInterval 1; patches ( "CDNozzle.*" ); pName p; UName U; rhoName rhoInf; // reference density log true; CofR (0 0 0); // Center of rotation rhoInf 1; } forceCoeffs { type forceCoeffs; functionObjectLibs ( "libforces.so" ); outputControl timeStep; outputInterval 1; patches ( "CDNozzle.*" ); pName p; UName U; rhoName rhoInf; log true; liftDir (0 1 0); // Direction of lift coefficient dragDir (1 0 0); // Direction of drag coefficient CofR (0 0 0); pitchAxis (0 0 1); //Pitching moment axis magUInf 8; // Free stream velocity magnitude rhoInf 1; lRef 1; //Reference lenght Aref 1; // Reference area } // ************************************************************************* // 3D Cd Cl 2.139615e-01 -1.042097e-03 Axisymmetric Cd Cl 2.887599e-03 -3.213962e-03 In the axismmetric results for the drag, I did the following calculations; Cd = 2.887599e-03*360/5 = 2.07907128e-01 (~3% error), where the value 5 is the wedge angle. However, the lift coefficient doesn't seem to be right in the axismmetric results . I am not quite sure what could be the issue here? Anyone has done similar simulation could guide us? Thanks for your time, |
