Weird velocity at the air-water interface in olafoam |
June 19, 2017, 22:29 |
Lee Jung Hoo
Rep Power: 10 |
Hi, foamers. I'm using olafoam to simulate waves above a structure(a simple mound) like below.
As you can see, there exist some weird huge velocities at the start point and end point of the structure even though waves didn't approach the structure yet. The surface is air-water interface(alpha.water=0.5) and the structure was inserted by using snappyHexMesh. Can anyone explain to me why that some noises exist? Thank you in advance.! |
June 19, 2017, 23:07 |
Pablo Higuera
Rep Power: 19 |
Hi Jung Hoo,
what you see there are spurious velocities (look for it in the forum) when the free surface reaches a non-conformal mesh section (i.e. change in refine level). There is usually no solution, so what I tend to do is to refine the cells in which the free surface is going to be during the whole simulation to the same level beforehand. Another alternative is to use dynamic mesh refinement. Before that, check whether this effect influences your results. It sometimes only decreases dt due to the large velocities and you may learn to live with it... Best, Pablo |
June 21, 2017, 21:15 |
Lee Jung Hoo
Rep Power: 10 |
Thank you for your fast reply. Now I can understand why the spurious velocities exist where the mesh refine level changes.
Thank you for your help! |
high air velocity at interface in interFoam | ufocfd | OpenFOAM Running, Solving & CFD | 3 | May 6, 2019 06:52 |
(interfoam) shear stress at water air interface ! | openfoam1 | OpenFOAM | 11 | October 27, 2014 03:59 |
Boundary condition of velocity and pressure at interface for air water pipe flow | jignesh_thaker2007 | OpenFOAM Running, Solving & CFD | 0 | June 10, 2014 16:42 |
Heat Transfer Coeff on the water air interface | Anton | Main CFD Forum | 3 | June 2, 2010 01:49 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
