Fixed water level BC
Old   July 2, 2017, 17:58
Post Specified water level inlet BC
alexvhn's Avatar
Alex Ventura
alexvhn is on a distinguished road
This a modified weirOverflow case from $FOAM_TUTORIALS/multiphase/interFoam/ras/
I used groovyBC to set inlet BCs at a specified water level, I also extended the domain upstream to keep inlet BC far enough from the weir.
The setFieldsDict was modified to include a water level upstream and downstream with a specified water level and p_rgh accordingly.
I think it solves another treads in this forum.
But, the inlet and outlet flowrates are not converging. I think I need to extend the domain downstream to avoid the hydraulic jump effects on the outlet patch.
Please your comments.
Regards,
alexvhn is offline   Reply With Quote
fixed level, hydrostatic, inlet, riverine, vof
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 14:27
function to record water level of the whole domain ce73stargazer OpenFOAM Post-Processing 3 September 22, 2016 03:29
Rising water level in a part HHK STAR-CCM+ 0 January 12, 2015 11:22
[snappyHexMesh] AMI-interface "cuts" water jet jrrygg OpenFOAM Meshing & Mesh Conversion 0 February 15, 2013 07:08
