Why codedFixedValue BC doesn't work in parallel?
Like Tree3Likes
  • 2 Post By alexeym
  • 1 Post By alexeym
Old   June 20, 2017, 11:39
Default Why codedFixedValue BC doesn't work in parallel?
Mauricio de Alba
mau_cfd is on a distinguished road
Hi there. I'm running a rhoPimpleFoam case where in a BC I use a codedFixedValue to set its temperature as the one read from other BC. It works fine when it runs in serial but when I try to run it in parallel I get the message shown in the picture.
The same problem with two OpFm versions OF1612+ and OpFm version 17.06 from CFD Support that I think is the OpFm dev from the fundation under cygwin running in Windows. I have to say that the crash message is not the same, I'm showing the one for the 17.06 version.
Hope someone can help me.
Regards.
Mauricio
mau_cfd is offline   Reply With Quote
Old   June 21, 2017, 18:05
Mauricio de Alba
It depends of the direction of the partition if it crash or not.
Old   June 22, 2017, 07:45
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Since it is CODED fixed value, it would be much easier to diagnose your case if you actually post your code.
Tobi and vsb like this.
alexeym is offline   Reply With Quote
Old   June 23, 2017, 20:45
Mauricio de Alba
Thank you very much for reply alexeym, I appreciate your time. I've been reading older post related and looks like an abnormal mathematical operation results when pointing in the mesh with the code inside the codedFixedValue. The strange thing to me is that this only happen when running in parallel and even in that case depends on the direction of decomposing the domain.
I'm posting the 0/T where I have the coded BC. The case is related with a freezer of a household refrigerator.
Regards.
Old   June 24, 2017, 08:22
Alexey Matveichev
Strange things can happen in FZ_SUCCION patch is not present in subdomain, where FZ_INLET is located. This line
label patchID = mesh.boundaryMesh().findPatchID("FZ_SUCCION");
sets patchID to -1, and the rest becomes slightly meaningless.
Either decompose domain so parts of above mentioned patches are present in all subdomains, or rewrite code.
mau_cfd likes this.
Old   June 26, 2017, 12:34
Mauricio de Alba
Thank you alexeym for the explanation, now I see very clear what is happening. I'll follow your recommendations.
Best Regards.
Mauricio
Old   July 5, 2017, 17:01
Mauricio de Alba
Decompose the domain with "preservePatches" option solved the problem.
Thanks for the hint alexeym.
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 04:38
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
chtMultiRegionSimpleFoam: crash on parallel run student666 OpenFOAM Running, Solving & CFD 3 April 20, 2017 11:05
User fortran to input/output file in a parallel run doublestrong CFX 5 March 31, 2017 08:15
Cases with small length scale work fine on a single processor but fail in parallel adona058 OpenFOAM Bugs 5 April 17, 2009 04:41
