July 9, 2017, 12:32 |
simpleFoam and pimpleFoam on a free-jet
Rep Power: 10 |
I'm trying to obtain both steady-state and time-tracked solution for a plane jet issuing into an environment. I have run simpleFoam and pimpleFoam with identical bounday and initial conditions. The results are shown below, with the pimpleFoam solution at approximately 0.1s after start.
I understand simpleFoam offers the steady state solution.So, with identical initial conditions, the time-stepping solution for pimple will approximate the simple-solution once it has reached statistically steady state. However as is obvious from the figure, the two solutions are very very different. In particular the centreline decay drop is very fast for Simple, while the pimple solution approximates experimental conditions more accurately. What is going on here? |
free jet undefined, openfoam, pimplefoam, simplefoam |
pimpleFoam vs simpleFoam vs pisoFoam vs icoFoam? | phsieh2005 | OpenFOAM Running, Solving & CFD | 45 | March 22, 2021 09:14 |
Unsteady state calculation including porous media | KeiJun | OpenFOAM Programming & Development | 3 | December 18, 2015 10:57 |
pimpleFoam initialization? | TBERGE | OpenFOAM Running, Solving & CFD | 2 | April 2, 2014 08:20 |
Starting pimpleFoam computation from simpleFoam result | vinz | OpenFOAM Running, Solving & CFD | 9 | March 17, 2014 12:35 |
Differences simpleFoam vs. pimpleFoam / RASModel.H vs turbulenceModel.H | uli | OpenFOAM Programming & Development | 7 | January 26, 2013 15:01 |
