Eroor mpi_abort due to maximum number of iterations |
July 11, 2017, 06:03 |
Jhin him
I am new user of OpenFoam, and I get this error : [25] --> FOAM FATAL ERROR: [25] Maximum number of iterations exceeded [25] [25] From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const There are other lines after parallel run aborting , I can copy and paste if you need to know more about error. I am making an turbulent simulation inside a small cube of 50 mm. The initial value of pressure is 0.001 Pa and I increase the inlet pressure to 40 bars in 1e-5 . In my file T in my folder 0, I put all temperature to uniform 20. Cheers Marc |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
