twoPhaseEulerFoam kOmegaSST model error message meaning |
April 10, 2019, 08:16 |
Vivekananda
Rep Power: 8 |
Hello foamers,
Please reply to this thread as it is a bit alarming for me. I am getting the following error message while running kOmegaSST in twoPhaseEulerFoam. My case is to simulate a two phase liquid liquid system without heat transfer and mass transfer. I intend to find out the dispersed phase holdup at various operating conditions. please help me out. The error message: #0 Foam::error: printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) at ??:? #10 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Fo am::PhaseCompressibleTurbulenceModel<Foam: phaseModel> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foa m::PhaseCompressibleTurbulenceModel<Foam: phaseModel> > > >::correct() at ??:? #11 Foam::twoPhaseSystem::correctTurbulence() at ??:? #12 ? at ??:? #13 __libc_start_main in "/lib64/libc.so.6" #14 ? at ??:? Floating point exception (core dumped) |
April 10, 2019, 08:55 |
#2 | |
K
Rep Power: 8 |
I think it would be easier to figure out what is wrong if you can upload your case file.
June 19, 2019, 13:17 |
Lourenço SM
Rep Power: 11 |
I have the same problem. Any solution?
kEpsilon turbulence model and twoPhaseEulerFoam | remidemol | OpenFOAM Running, Solving & CFD | 6 | July 14, 2017 10:58 |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 10:36 |
how to write header file for coalescence model in twoPhaseEulerFoam | mehrdad_kbg | OpenFOAM Programming & Development | 1 | May 20, 2013 21:23 |
some quiries about how to set a "low_Re" kOmegaSST model? | immortality | OpenFOAM Running, Solving & CFD | 1 | May 6, 2013 03:44 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
