rhoSimpleFoam pressure P is not satisfy perfect gas state equation at inlet patch |
September 18, 2017, 06:40 |
ff
Rep Power: 16 |
Hi Foamers,
In my simulation, I have a jet flow which is similar with Aircraft engine outlet. So at this inlet patch, I set mass flow rate and totaltemperature boundary condtion. Now the problem is after simulation, I got the following solutions at this flow inlet patch T (static temperature) = 803 (this is satisfy what I expected) rho = 0.4633 (this is satisfy what I expected) U = 156.8 (this is satisfy what I expected) p = 1.156e5 The problem is pressure p. If we perform a hand calculation using perfect gas state equation, p = rho*R*T = 0.4633 * 287.1 * 803 = 106809.78429 = 1.068e5 which is also what I expected value. However, the p I got from solution is 1.156e5. This is not what I expected and not even satisfy perfect gas state equation. Doese anyone has any idea what is wrong here? Thanks a lot. |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 6 | January 12, 2021 05:55 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
