November 20, 2017, 09:42 |
perturbU links are dead
rik houthuys
Rep Power: 9 |
Dear all,
I need to download perturbU utility for OpenFOAM 4. I've followed the instruction here http://openfoamwiki.net/index.php/Contrib/perturbU. Unfortunately the repository seems to be empty So can anyone provide link for perturbU for OpenFOAM 4 Best regards. |
November 20, 2017, 10:18 |
Rubens Stuginski Jr
Rep Power: 17 |
The link is OK.
Try again. |
November 28, 2017, 17:07 |
rik houthuys
Rep Power: 9 |
Are you sure?
the links in the wiki article returns "404: Not Found" wget https://github.com/wyldckat/perturbU/archive/OF40x.zip -O perturbU.zip If you can access this file please share it here! |
November 28, 2017, 20:21 |
Rubens Stuginski Jr
Rep Power: 17 |
Hi Houthuys.
I think this utilities is no more available. You can get more information in https://github.com/wyldckat/perturbU Maybe Bruno (wyldckat) has more information about this utilities. Sorry. Rubens |
November 30, 2017, 05:16 |
Hilbert
Rep Power: 10 |
Hi Houthuys.
I assume you want to do some LES and need a perturbed field? For my own LES i ended up making some small modifications to boxturb. boxturb gives you a uniform turbulence field, but changing the code to accept a baseline velocity is quite simple. Hope it helps, Cheers, |
dead volumes in stirred tanks | soroosh dbi | FLUENT | 0 | July 11, 2017 11:35 |
Sharing links for two phase solver packages developed by openfoam community | swap_9068 | OpenFOAM Programming & Development | 1 | April 2, 2017 05:43 |
is PerturbU there in OpenFOAM 2.1? | turbfoam | OpenFOAM Running, Solving & CFD | 3 | December 26, 2012 15:18 |
Links Section - Major Update! | pete | Site News & Announcements | 0 | February 6, 2012 07:51 |
Dead cells created on edges when a grid file is generated in GAMBIT and imported into FLUENT4 | Isaac Manohar Ch. | FLUENT | 1 | June 2, 2000 04:58 |
