PoroussimpleFoam error
Old   December 10, 2017, 06:28
Default PoroussimpleFoam error
adibansv
adiban is on a distinguished road
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.1
Exec : porousSimpleFoam
Date : Dec 10 2017
Time : 16:42:01
Host : "adibanshaan-X550JX"
PID : 3148
Case : /home/adibanshaan/openfoam/tutorials/incompressible/porousSimpleFoam/simple
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: no convergence criteria found. Calculations will run for 100 steps.
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
No MRF models present
Creating porosity model list from porosityProperties
Porosity region porosity1:
selecting model: DarcyForchheimer
creating porous zone: BODY_OUTLET
Using pressure implicit porosity
No finite volume options present
Starting time loop
Time = 1
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0495388, No Iterations 914
time step continuity errors : sum local = 0.000399062, global = -2.60372e-06, cumulative = -2.60372e-06
smoothSolver: Solving for epsilon, Initial residual = 0.984962, Final residual = 0.000482011, No Iterations 2
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0883546, No Iterations 2
ExecutionTime = 376.55 s ClockTime = 377 s
Time = 2
GAMG: Solving for p, Initial residual = 0.00124918, Final residual = 5.63522e-05, No Iterations 1
time step continuity errors : sum local = 1.6613, global = -0.00928858, cumulative = -0.00929119
smoothSolver: Solving for epsilon, Initial residual = 0.980812, Final residual = 0.00154369, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.721139, Final residual = 0.0139732, No Iterations 4
ExecutionTime = 383.11 s ClockTime = 383 s
Time = 3
GAMG: Solving for p, Initial residual = 0.00146809, Final residual = 2.42277e-05, No Iterations 2
time step continuity errors : sum local = 0.522666, global = -0.00903295, cumulative = -0.0183241
smoothSolver: Solving for epsilon, Initial residual = 0.825151, Final residual = 0.0057333, No Iterations 2
bounding epsilon, min: -9.67454 max: 200 average: 0.399154
smoothSolver: Solving for k, Initial residual = 0.441422, Final residual = 0.0236358, No Iterations 4
bounding k, min: -0.0949568 max: 1.01138 average: 0.0313929
ExecutionTime = 390.39 s ClockTime = 391 s
Time = 4
GAMG: Solving for p, Initial residual = 0.999696, Final residual = 0.00455078, No Iterations 1
time step continuity errors : sum local = 449457, global = -96803.5, cumulative = -96803.5
smoothSolver: Solving for epsilon, Initial residual = 0.999994, Final residual = 0.00398206, No Iterations 4
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.00255144, No Iterations 4
ExecutionTime = 397.22 s ClockTime = 398 s
Time = 5
GAMG: Solving for p, Initial residual = 0.995351, Final residual = 0.046944, No Iterations 12
time step continuity errors : sum local = 12059, global = -640.584, cumulative = -97444.1
smoothSolver: Solving for epsilon, Initial residual = 0.439205, Final residual = 0.0301067, No Iterations 8
smoothSolver: Solving for k, Initial residual = 0.99967, Final residual = 0.013118, No Iterations 4
ExecutionTime = 408.89 s ClockTime = 409 s
Time = 6
GAMG: Solving for p, Initial residual = 0.696397, Final residual = 0.00998746, No Iterations 2
time step continuity errors : sum local = 7.07704e+07, global = -2.55952e+06, cumulative = -2.65696e+06
smoothSolver: Solving for epsilon, Initial residual = 0.958146, Final residual = 0.0741997, No Iterations 8
bounding epsilon, min: -3.2309e+11 max: 4.45529e+22 average: 1.09823e+17
smoothSolver: Solving for k, Initial residual = 0.903686, Final residual = 0.0735346, No Iterations 6
bounding k, min: -1.95224e+08 max: 6.86551e+17 average: 2.83196e+12
ExecutionTime = 416.61 s ClockTime = 417 s
Time = 7
GAMG: Solving for p, Initial residual = 0.918434, Final residual = 0.0201012, No Iterations 1
time step continuity errors : sum local = 7.27528e+12, global = 2.52583e+12, cumulative = 2.52583e+12
smoothSolver: Solving for epsilon, Initial residual = 0.195063, Final residual = 8.97931e-07, No Iterations 2
bounding epsilon, min: -1.62953e+24 max: 5.14926e+31 average: 4.79283e+25
smoothSolver: Solving for k, Initial residual = 0.993756, Final residual = 0.0769547, No Iterations 12
ExecutionTime = 423.79 s ClockTime = 424 s
Time = 8
GAMG: Solving for p, Initial residual = 0.0611271, Final residual = 0.00223384, No Iterations 1
time step continuity errors : sum local = 5.34281e+16, global = -9.94591e+12, cumulative = -7.42008e+12
smoothSolver: Solving for epsilon, Initial residual = 1.66479e-12, Final residual = 1.66479e-12, No Iterations 0
smoothSolver: Solving for k, Initial residual = 1.97814e-06, Final residual = 1.17316e-07, No Iterations 4
bounding k, min: -2.39618e+18 max: 8.53024e+33 average: 1.05619e+28
ExecutionTime = 430.58 s ClockTime = 431 s
Time = 9
GAMG: Solving for p, Initial residual = 1.26873e-06, Final residual = 5.82365e-08, No Iterations 4
time step continuity errors : sum local = 3.53114e+20, global = -4.9573e+19, cumulative = -4.9573e+19
smoothSolver: Solving for epsilon, Initial residual = 0.345804, Final residual = 0.00899415, No Iterations 4
bounding epsilon, min: -4.82011e+47 max: 3.68442e+50 average: 2.09989e+45
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0844258, No Iterations 12
bounding k, min: -1.19574e+23 max: 2.26219e+43 average: 3.30907e+38
ExecutionTime = 439.39 s ClockTime = 440 s
Time = 10
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0447648, No Iterations 7
time step continuity errors : sum local = 5.55871e+68, global = 3.3118e+68, cumulative = 3.3118e+68
smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.0397114, No Iterations 4
smoothSolver: Solving for k, Initial residual = 1, Final residual = 5.17045e-07, No Iterations 2
ExecutionTime = 448.79 s ClockTime = 449 s
Time = 11
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? at tensorField.C:?
#4 ? at ??:?
#5 ? at ??:?
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7 ? at ??:?
Floating point exception (core dumped)
i got this message when i am running porous simple foam . what to do???//?
adiban is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
