sonicFoam forwardstep negative temperature problem.
Old   January 8, 2018, 09:14
Default sonicFoam forwardstep negative temperature problem.
ecad is on a distinguished road
Hello, im trying to solve forwardstep tutorial by using sonicFoam solver with mach numbers of 0.8 and 2 and Gauss linear divSchemes. I tried finer meshes and lower deltaT values but i get the FOAM FATAL ERROR: Negative initial temperature T0 everytime im trying to solve this. Seems like this is due to changes in divSchemes but its required for the problem so i can't change it. Is there any other way to get around this ?
ecad is offline   Reply With Quote
Old   January 8, 2018, 18:28
Taher Chegini
Taataa is on a distinguished road
Assuming that you've setup boundary and initial conditions correctly, negative T means that the solution is unbounded. You have to change schemes e.g. using limiters and/or tighten tolerances. Usually limitedLinear 1 is a good option in unbounded cases. If it worked you can loosen the limiter by lowering the coefficient e.g. limitedLinear 0.2.
Taataa is offline   Reply With Quote
Old   January 8, 2018, 18:31
Thank you. I solved it before reading this and i have done the same thing. Im gonna try lower than 1.
Negative temperature and pressure in sonicFoam :O gallon OpenFOAM Running, Solving & CFD 16 January 21, 2019 05:56
Problem in temperature profiles while using rhoSimpleFoam for Nozzle case Nik_04 OpenFOAM Running, Solving & CFD 0 February 4, 2017 05:04
Natural Convection Air Temperature Problem theBerNii FLUENT 1 November 28, 2016 13:30
Closed Domain Buoyancy Flow Problem Madhatter92 CFX 6 June 20, 2016 21:05
same static and total temperature problem preetam69 FLUENT 1 August 15, 2013 17:17
