CompressibleInterFoam negative T
Old   November 3, 2017, 21:24
Default CompressibleInterFoam negative T
Genji is on a distinguished road
Hello everyone
I'm running a case with compressibleInterFoam where a hot, less dense gas enters an 1 block mesh from an inlet on the ground, and very soon the simulation breaks down because i get negative T. I have tried to change a few things to no avail. This case was adapted from an earlier iteration with interFoam, which worked fine. Below are my files :
U
dimensions      [0 1 -1 0 0 0 0];//kg m s K mol A cd
internalField   uniform (0 0 0);//Initially the velocity is (0 0 0) m/s
boundaryField
    inlet
    type             turbulentInlet;
	referenceField		uniform (0 0 10.5);
	fluctuationScale  		(0.1 0.1 0.5);
	value		uniform (0 0 10.5);
    outlet
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    floor
        type            noSlip;
    fixedWalls
        type            noSlip;
	ceiling
        type            noSlip;
T
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 700;
    outlet
		type            zeroGradient;
                phi             rhoPhi;
    floor
        type            zeroGradient;
    fixedWalls
        type            zeroGradient;
	ceiling
        type            zeroGradient;
p
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
    inlet
        type               calculated;
        value              $internalField;
    outlet
        type               calculated;
    floor
        type               calculated;
    fixedWalls
        type               calculated;
	ceiling
        type               calculated;
        value              $internalField;;
p_rgh
boundaryField
    inlet
        type            fixedFluxPressure;
		phi             rhoPhi;
        rho             rho;
        value           uniform 1e5;
    outlet
        type            totalPressure;
		phi             rhoPhi;
        rho             rho;
        p0              uniform 1e5;
    floor
		phi             rhoPhi;
        rho             rho;
        value           uniform 1e5;
    fixedWalls
		phi             rhoPhi;
        rho             rho;
        value           uniform 1e5;
	ceiling
		phi             rhoPhi;
        rho             rho;
        value           uniform 1e5;
alpha.gas
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            fixedValue;
	value	 	uniform 1;
    outlet
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    floor
        type            zeroGradient;
    fixedWalls
        type            zeroGradient;
	ceiling
        type            zeroGradient;
blockMeshDict
(inlet and outlet are mad with TopoSet and CreatePatch)
convertToMeters 1;
vertices
	(0 0 0)
	(10 0 0)
	(10 10 0)
	(0 10 0)
	(0 0 15)
	(10 0 15)
	(10 10 15)
	(0 10 15)
blocks
    hex (0 1 2 3 4 5 6 7) (40 40 60) simpleGrading (1 1 1)
edges
boundary
    floor
        type wall;
        faces
			(0 3 2 1)
    ceiling
        type wall;
        faces
			(4 5 6 7)
    fixedWalls
        type wall;
        faces
            (0 4 7 3)
            (2 6 5 1)
            (1 5 4 0)
            (3 7 6 2)
mergePatchPairs
fvSchemes
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default             Gauss linear;
    grad(U)             cellLimited Gauss linear 1;
divSchemes
    default         none;
    div(rhoPhi,U)       Gauss linearUpwind grad(U);
    div(phi,alpha)      Gauss vanLeer;
    div(phirb,alpha)    Gauss linear;
    div(rhoPhi,K)       Gauss linear;
    div(rhoPhi,T)       Gauss linear;
    div(phi,thermo:rho.gas) Gauss linear;
    div(phi,thermo:rho.air) Gauss linear;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
    div((phi+meshPhi),p)    Gauss linear;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fvSolution
|  \\    /   O peration     | Version:  4.0                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
	"alpha.gas.*"
		nAlphaCorr      2;
		nAlphaSubCycles 1;
		cAlpha          1.5;
		MULESCorr       yes;
		nLimiterIter    3;
		solver          smoothSolver;
		smoother        symGaussSeidel;
		tolerance       1e-8;
		relTol          0;
     cellDisplacement
        solver          GAMG;
        tolerance       1e-5;
        relTol          0;
        smoother        GaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    "rho.*|pcorr.*"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-8;
        relTol          0;
    p_rgh
        solver           GAMG;
        tolerance        1e-8;
        relTol           0.05;
        smoother         DICGaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration on;
        mergeLevels      1;
    p_rghFinal
        $p_rgh;
        tolerance       1e-08;
        relTol          0;
    "(U|k|epsilon|T)"
        tolerance       1e-08;
        relTol          0.1;
    "(U|k|epsilon|T)Final"
        $U;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nOuterCorrectors 2;
    nCorrectors      4;
    nNonOrthogonalCorrectors 1;
    correctPhi              yes;
    checkMeshCourantNo      no;
    moveMeshOuterCorrectors no;
    transonic   false;
relaxationFactors
    fields
    equations
        ".*"    1;
thermophysicalProperties
phases (gas air);
pMin            pMin [1 -1 -2 0 0 0 0] 1000;
sigma           sigma [1 0 -2 0 0 0 0] 0;
thermophysicalProperties.air
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        molWeight   28.9;
    thermodynamics
        Cp          1.005;
        Hf          0;
    transport
        mu          1.48e-05;
        Pr          0.7;
thermophysicalProperties.gas
thermoType
	type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
mixture
    specie
        molWeight   44.0;
    equationOfState
        rho         1;
    thermodynamics
        Cp          1.116;
        Hf          0;
    transport
        mu          1e-6;
        Pr          0.713;
transportProperties
phases (gas air);
gas
    transportModel  Newtonian;//Newtonian fluid assumed
    nu              [0 2 -1 0 0 0 0] 1e-06;
    rho             [1 -3 0 0 0 0 0] 0.6;
air
    nu              [0 2 -1 0 0 0 0] 1.48e-05;
    rho             [1 -3 0 0 0 0 0] 1;
sigma           [1 0 -2 0 0 0 0] 0;//surface tension of gas/air
and i don't calculate turbulence so I have a laminar model.
If anyone could tell me anything I'm missing here, it would be much appreciated.
Best regards.
Genji is offline   Reply With Quote
Old   January 9, 2018, 06:42
tian_lei is on a distinguished road
hello
Is this tutorial working ?
tian_lei is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
