November 3, 2017, 21:24 |
CompressibleInterFoam negative T
Rep Power: 8 |
Hello everyone
I'm running a case with compressibleInterFoam where a hot, less dense gas enters an 1 block mesh from an inlet on the ground, and very soon the simulation breaks down because i get negative T. I have tried to change a few things to no avail. This case was adapted from an earlier iteration with interFoam, which worked fine. Below are my files : U Code:
dimensions [0 1 -1 0 0 0 0];//kg m s K mol A cd internalField uniform (0 0 0);//Initially the velocity is (0 0 0) m/s boundaryField { inlet { type turbulentInlet; referenceField uniform (0 0 10.5); fluctuationScale (0.1 0.1 0.5); value uniform (0 0 10.5); } outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } floor { type noSlip; } fixedWalls { type noSlip; } ceiling { type noSlip; } } Code:
dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { inlet { type fixedValue; value uniform 700; } outlet { type zeroGradient; phi rhoPhi; } floor { type zeroGradient; } fixedWalls { type zeroGradient; } ceiling { type zeroGradient; } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { inlet { type calculated; value $internalField; } outlet { type calculated; value $internalField; } floor { type calculated; value $internalField; } fixedWalls { type calculated; value $internalField; } ceiling { type calculated; value $internalField;; } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { inlet { type fixedFluxPressure; phi rhoPhi; rho rho; value uniform 1e5; } outlet { type totalPressure; phi rhoPhi; rho rho; p0 uniform 1e5; } floor { type fixedFluxPressure; phi rhoPhi; rho rho; value uniform 1e5; } fixedWalls { type fixedFluxPressure; phi rhoPhi; rho rho; value uniform 1e5; } ceiling { type fixedFluxPressure; phi rhoPhi; rho rho; value uniform 1e5; } } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedValue; value uniform 1; } outlet { type inletOutlet; inletValue uniform 0; value uniform 0; } floor { type zeroGradient; } fixedWalls { type zeroGradient; } ceiling { type zeroGradient; } } (inlet and outlet are mad with TopoSet and CreatePatch) Code:
convertToMeters 1; vertices ( (0 0 0) (10 0 0) (10 10 0) (0 10 0) (0 0 15) (10 0 15) (10 10 15) (0 10 15) ); blocks ( hex (0 1 2 3 4 5 6 7) (40 40 60) simpleGrading (1 1 1) ); edges ( ); boundary ( floor { type wall; faces ( (0 3 2 1) ); } ceiling { type wall; faces ( (4 5 6 7) ); } fixedWalls { type wall; faces ( (0 4 7 3) (2 6 5 1) (1 5 4 0) (3 7 6 2) ); } ); mergePatchPairs ( ); Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: plus | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(U) cellLimited Gauss linear 1; } divSchemes { default none; div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div(rhoPhi,K) Gauss linear; div(rhoPhi,T) Gauss linear; div(phi,thermo:rho.gas) Gauss linear; div(phi,thermo:rho.air) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div((phi+meshPhi),p) Gauss linear; div((muEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "alpha.gas.*" { nAlphaCorr 2; nAlphaSubCycles 1; cAlpha 1.5; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } cellDisplacement { solver GAMG; tolerance 1e-5; relTol 0; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } "rho.*|pcorr.*" { solver PCG; preconditioner DIC; tolerance 1e-8; relTol 0; } p_rgh { solver GAMG; tolerance 1e-8; relTol 0.05; smoother DICGaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } p_rghFinal { $p_rgh; tolerance 1e-08; relTol 0; } "(U|k|epsilon|T)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-08; relTol 0.1; } "(U|k|epsilon|T)Final" { $U; tolerance 1e-08; relTol 0; } } PIMPLE { momentumPredictor no; nOuterCorrectors 2; nCorrectors 4; nNonOrthogonalCorrectors 1; correctPhi yes; checkMeshCourantNo no; moveMeshOuterCorrectors no; transonic false; } relaxationFactors { fields { } equations { ".*" 1; } } // ************************************************************************* // Code:
phases (gas air); pMin pMin [1 -1 -2 0 0 0 0] 1000; sigma sigma [1 0 -2 0 0 0 0] 0; Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture { specie { molWeight 28.9; } thermodynamics { Cp 1.005; Hf 0; } transport { mu 1.48e-05; Pr 0.7; } } Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture { specie { molWeight 44.0; } equationOfState { rho 1; } thermodynamics { Cp 1.116; Hf 0; } transport { mu 1e-6; Pr 0.713; } } Code:
phases (gas air); gas { transportModel Newtonian;//Newtonian fluid assumed nu [0 2 -1 0 0 0 0] 1e-06; rho [1 -3 0 0 0 0 0] 0.6; } air { transportModel Newtonian; nu [0 2 -1 0 0 0 0] 1.48e-05; rho [1 -3 0 0 0 0 0] 1; } sigma [1 0 -2 0 0 0 0] 0;//surface tension of gas/air If anyone could tell me anything I'm missing here, it would be much appreciated. Best regards. Last edited by Genji; November 5, 2017 at 11:32. |
January 9, 2018, 06:42 |
Rep Power: 8 |
hello
Is this tutorial working ? |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
