January 17, 2018, 04:18 |
Time Step Continuity Errors simpleFoam
Rep Power: 9 |
I'm trying to simulate a flow around a 3D-wing. I want to use k-omegaSST (or k-epsilon) turbulence model. I'm decreasing the size of the layers step by step, however when my y+ is near 45 the time step continuity error starts diverging and the simulation stops. I've tried to change my schemes, my BC or relaxation coefficients without success. I don't understand where this error come from knowing that the simulation run for a y+~100. Another simulation using the spalartAllmaras model also converges (with the same mesh and BC). Moreover my checkMesh is ok. Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field U tolerance 0.0001 field p tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave kOmegaSSTCoeffs { alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present No finite volume options present Starting time loop forces forces: Not including porosity effects forceCoeffs forces: Not including porosity effects Time = 1 smoothSolver: Solving for Ux, Initial residual = 0.99999, Final residual = 0.0764658, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0386756, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.999997, Final residual = 0.0791299, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0690019, No Iterations 7 time step continuity errors : sum local = 0.028254, global = -0.00313196, cumulative = -0.00313196 smoothSolver: Solving for omega, Initial residual = 0.00535907, Final residual = 0.000196025, No Iterations 1 bounding omega, min: -25706.4 max: 3.8584e+06 average: 95308.2 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.00489828, No Iterations 1 ExecutionTime = 100.23 s ClockTime = 100 s forceCoeffs forces write: Cm = -5.01564 Cd = 44.5862 Cl = 6.34427 Cl(f) = -1.84351 Cl(r) = 8.18777 Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.0503861, Final residual = 0.00457665, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.056634, Final residual = 0.00502492, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.202114, Final residual = 0.0186672, No Iterations 2 GAMG: Solving for p, Initial residual = 0.490306, Final residual = 0.027328, No Iterations 2 time step continuity errors : sum local = 12.3113, global = -0.00624942, cumulative = -0.00938138 smoothSolver: Solving for omega, Initial residual = 0.00135869, Final residual = 1.21457e-05, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.383071, Final residual = 0.00314367, No Iterations 1 ExecutionTime = 131.72 s ClockTime = 132 s forceCoeffs forces write: Cm = -2.32634 Cd = 20.2918 Cl = 2.99807 Cl(f) = -0.827308 Cl(r) = 3.82538 Time = 3 smoothSolver: Solving for Ux, Initial residual = 0.0923705, Final residual = 0.00468338, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.103414, Final residual = 0.00676207, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.203299, Final residual = 0.0108881, No Iterations 4 GAMG: Solving for p, Initial residual = 0.587766, Final residual = 0.0540848, No Iterations 4 time step continuity errors : sum local = 29.5512, global = 0.154192, cumulative = 0.144811 smoothSolver: Solving for omega, Initial residual = 0.0731651, Final residual = 0.00077162, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.0828431, Final residual = 0.000851564, No Iterations 1 ExecutionTime = 169.14 s ClockTime = 169 s forceCoeffs forces write: Cm = 177.768 Cd = -1327 Cl = -292.705 Cl(f) = 31.4153 Cl(r) = -324.121 Time = 4 smoothSolver: Solving for Ux, Initial residual = 0.651467, Final residual = 0.0353532, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.684837, Final residual = 0.0367144, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.684076, Final residual = 0.0372442, No Iterations 1 GAMG: Solving for p, Initial residual = 0.00919992, Final residual = 0.000641066, No Iterations 7 time step continuity errors : sum local = 16.0459, global = -2.34303, cumulative = -2.19822 smoothSolver: Solving for omega, Initial residual = 0.076197, Final residual = 0.0013213, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.0370577, Final residual = 0.000367212, No Iterations 1 ExecutionTime = 206.58 s ClockTime = 207 s forceCoeffs forces write: Cm = -374.837 Cd = 5347.9 Cl = 670.105 Cl(f) = -39.7839 Cl(r) = 709.889 Time = 5 smoothSolver: Solving for Ux, Initial residual = 0.599135, Final residual = 0.0538314, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.641251, Final residual = 0.05281, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.591677, Final residual = 0.0467585, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0677127, Final residual = 0.00567401, No Iterations 13 time step continuity errors : sum local = 41.1121, global = -4.97447, cumulative = -7.17269 smoothSolver: Solving for omega, Initial residual = 0.0675145, Final residual = 0.00111715, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.0337135, Final residual = 0.000382671, No Iterations 1 ExecutionTime = 253.04 s ClockTime = 253 s forceCoeffs forces write: Cm = -8352.88 Cd = -17220.7 Cl = 11998.4 Cl(f) = -2353.7 Cl(r) = 14352.1 Time = 6 smoothSolver: Solving for Ux, Initial residual = 0.689606, Final residual = 0.0548645, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.702136, Final residual = 0.064385, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.691323, Final residual = 0.0648999, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0115375, Final residual = 0.00112664, No Iterations 165 time step continuity errors : sum local = 1635.2, global = 193.916, cumulative = 186.743 smoothSolver: Solving for omega, Initial residual = 0.124886, Final residual = 0.00154642, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.0480225, Final residual = 0.000597913, No Iterations 1 ExecutionTime = 528.78 s ClockTime = 529 s forceCoeffs forces write: Cm = 5.34103e+06 Cd = -2.49835e+06 Cl = -1.2117e+07 Cl(f) = -717471 Cl(r) = -1.13995e+07 Time = 7 smoothSolver: Solving for Ux, Initial residual = 0.677576, Final residual = 0.025612, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.691005, Final residual = 0.0299412, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.662216, Final residual = 0.0543164, No Iterations 1 GAMG: Solving for p, Initial residual = 0.00381449, Final residual = 0.00746159, No Iterations 1000 time step continuity errors : sum local = 674286, global = -550585, cumulative = -550398 smoothSolver: Solving for omega, Initial residual = 0.0188267, Final residual = 0.000330376, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.0507805, Final residual = 0.000431565, No Iterations 1 ExecutionTime = 2062.05 s ClockTime = 2064 s forceCoeffs forces write: Cm = -2.28456e+10 Cd = 7.07455e+10 Cl = 7.99311e+10 Cl(f) = 1.712e+10 Cl(r) = 6.28112e+10 Time = 8 smoothSolver: Solving for Ux, Initial residual = 0.666421, Final residual = 0.0453112, No Iterations 6 smoothSolver: Solving for Uy, Initial residual = 0.695728, Final residual = 0.0554333, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.653737, Final residual = 0.0285133, No Iterations 5 GAMG: Solving for p, Initial residual = 0.424611, Final residual = 0.0419241, No Iterations 236 time step continuity errors : sum local = 3.19872e+07, global = 2.92964e+07, cumulative = 2.8746e+07 smoothSolver: Solving for omega, Initial residual = 0.122421, Final residual = 0.00140935, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.0480735, Final residual = 0.000354375, No Iterations 1 ExecutionTime = 2449.07 s ClockTime = 2452 s forceCoeffs forces write: Cm = 2.90902e+15 Cd = 5.00479e+15 Cl = -4.29443e+15 Cl(f) = 7.61808e+14 Cl(r) = -5.05624e+15 Time = 9 smoothSolver: Solving for Ux, Initial residual = 0.682372, Final residual = 0.0414407, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.685099, Final residual = 0.0431815, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.686867, Final residual = 0.0604966, No Iterations 2 GAMG: Solving for p, Initial residual = 0.574339, Final residual = 2.82489, No Iterations 1000 time step continuity errors : sum local = 3.73545e+13, global = -3.6676e+13, cumulative = -3.6676e+13 smoothSolver: Solving for omega, Initial residual = 0.00145352, Final residual = 1.949e-05, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.0410455, Final residual = 0.000270812, No Iterations 1 ExecutionTime = 3986.59 s ClockTime = 3991 s forceCoeffs forces write: Cm = 1.44699e+21 Cd = 2.31148e+21 Cl = -2.2355e+21 Cl(f) = 3.2924e+20 Cl(r) = -2.56474e+21 Time = 10 smoothSolver: Solving for Ux, Initial residual = 0.56782, Final residual = 0.0167332, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.61319, Final residual = 0.0588445, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.549356, Final residual = 0.0526533, No Iterations 1 GAMG: Solving for p, Initial residual = 0.97733, Final residual = 0.0958427, No Iterations 13 time step continuity errors : sum local = 3.74547e+12, global = -2.75918e+11, cumulative = -3.69519e+13 smoothSolver: Solving for omega, Initial residual = 0.00314259, Final residual = 5.58918e-05, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.0131684, Final residual = 0.000191094, No Iterations 1 ExecutionTime = 4033.9 s ClockTime = 4038 s forceCoeffs forces write: Cm = 4.98589e+26 Cd = 8.00075e+26 Cl = -7.70819e+26 Cl(f) = 1.1318e+26 Cl(r) = -8.83999e+26 Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : checkMesh Date : Jan 17 2018 Time : 18:05:41 Host : "node1" PID : 23705 Case : /home/dorian/OpenFOAM/dorian-4.1/run/opti_CFD nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 6372893 faces: 16961350 internal faces: 16506757 cells: 5339871 faces per cell: 6.26759 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 4201176 prisms: 52186 wedges: 0 pyramids: 0 tet wedges: 2 tetrahedra: 0 polyhedra: 1086507 Breakdown of polyhedra by number of faces: faces number of cells 4 91219 5 51893 6 79622 7 495583 8 198702 9 94900 10 1585 11 306 12 41478 15 31217 18 2 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology box 7200 7296 ok (non-closed singly connected) inlet 560 609 ok (non-closed singly connected) outlet 560 609 ok (non-closed singly connected) wing 446273 537464 ok (closed singly connected) Checking geometry... Overall domain bounding box (-5 -2.60002 -2) (10 3.00002 2) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (4.16873e-16 -7.5958e-16 7.66195e-15) OK. Max cell openness = 1.18722e-15 OK. Max aspect ratio = 26.1576 OK. Minimum face area = 5.11162e-08. Maximum face area = 0.040077. Face area magnitudes OK. Min volume = 3.57011e-11. Max volume = 0.00801562. Total volume = 335.914. Cell volumes OK. Mesh non-orthogonality Max: 64.8844 average: 9.43194 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.01112 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // kInlet 38.11; // approx k = 1.5*(I*U)^2 ; I = 0.1 dimensions [0 2 -2 0 0 0 0]; internalField uniform $kInlet; boundaryField { inlet { type fixedValue; value uniform $kInlet; } outlet { type inletOutlet; inletValue uniform $kInlet; value uniform $kInlet; } wing { type kqRWallFunction; value uniform $kInlet; } box { type zeroGradient; } } // ************************************************************************* // Thank you ! |
October 9, 2022, 09:23 |
Dai Li
Rep Power: 3 |
Hello. Do you figure out the problem? I also meet the problem. Could you tell the way that you solve this problem? Thanks a lot.
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
