Simplefoam Convergence Problem after Scaling by 0.001
Like Tree3Likes
  • 2 Post By RobertHB
  • 1 Post By CFDy
Old   July 14, 2018, 05:46
Default Simplefoam Convergence Problem after Scaling by 0.001
CFDy is on a distinguished road
Hi everyone,
I have prepared a very simple case to test the capability of simplefoam to simulate turbulet flow with KOSST turbulence model.
The mesh was created using snappyhexmesh in mm, and it is a simple 20 mm (diameter) pipe. If we solve this without scaling, i.e for a pipe having a diameter of 20 meters, the solution converges for inlet velocity of 10 m/s.
However, once the grid us scaled by 0.001 (in all the directions) no convergence can be achieved, and the velocity develops very high and unreasonable magnitudes.
What could be a problem? How can this be corrected?
This problem does not exist if I run pisoFoam.
Thank you in advance.
CFDy is offline   Reply With Quote
Old   July 15, 2018, 22:23
Peter Baskovich
pete20r2 is on a distinguished road
What are your boundary conditions?
pete20r2 is offline   Reply With Quote
Old   July 16, 2018, 02:38
Robert
RobertHB is on a distinguished road
I had similar problems when scaling my blockMesh to micrometer scale (1e-6 m). As for my problem, i accounted it to be to many trailing zeros, but maybe i'm wrong.
To offer a solution: You can always make use of dynamic similarity (i.e. Bolster et al., 2011) by scaling your viscosity instead of your mesh size. This will give you the same results as on your smaller scale, but on your larger mesh.
Robin.Kamenicky and CFDy like this.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   July 21, 2018, 05:56
I don't think that this is a solution. If additional dimensionless numbers must be matched , adjusting the viscosity will not provide accurate and required results.
RobertHB likes this.
Old   July 23, 2018, 03:27
Robert
You are right. It doesn't suffice to only scale the Reynolds number. All other dimensionless numbers important to the problem must match on both scales as well.
[blockMesh] FATAL ERROR: face 6 in patch 2 does not have neighbour cell face: 4(8 9 21 20) robingilbert OpenFOAM Meshing & Mesh Conversion 28 November 23, 2023 06:32
Convergence issue in natural convection problem chrisf90 FLUENT 5 March 5, 2016 08:30
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 13:43
