Why is the SimpleFoam Laminar solver Valid for Re3000
Like Tree1Likes
  • 1 Post By Santiago
Old   February 28, 2018, 14:54
Default Why is the SimpleFoam Laminar solver Valid for Re3000 [solved]
Shafik Walakaka
walakaka is on a distinguished road
Hi everyone,
I am currently validating a pipeflow simulation (Single-phase). I aim to validate laminar flows first (RAS turned off in pimpleFoam) for Re300 to Re2400.
When the Re gets high enough (approximately past Re2000), I expect the results to stop converging (with RAS turned off) as the flow is no longer laminar.
However, I obtained excellent results when compared to the H-P equation for my flow at Re3000.
My pipe is of length 20m, Diameter 0.0563m. Any if this result is expected?
Regards
Shafik
walakaka is offline   Reply With Quote
Old   March 1, 2018, 08:56
Default R3500 is valid against H-P too? What's wrong
Shafik Walakaka
Hi everyone!
My velocity profile for Re3500 is also valid against the H-P equation using laminar PIMPLE solver in openfoam. Does anyone have any idea what I'm doing wrong?
Pipe is 20m long and 0.0563m Dia.
Attached is the image of the developed velocity profile!
Regards
Shafik
Old   March 7, 2018, 09:26
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
first of all. Please read the purpose of the subforums.
Why shouldn't pimpleFoam be not valid for such Reynolds numbers? If you solve in 'laminar' mode, you are using the Navier-Stokes equations without any assumptions. It is like DNS. The fluid itself follows the Navier-Stokes equations so why should there be a problem. If you mesh if fine, you probably resolve everything.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   March 7, 2018, 15:55
Shafik Walakaka
Originally Posted by Tobi View Post
Thank you for your reply. And I do apologize, I should've posted this in the validation section of the forum.
Thanks again!
Old   March 7, 2018, 17:58
Tobi's Avatar
Tobias Holzmann
Actually you should not put it to the validation cases read the purpose of that forum
I confirm, it confuses a bit
Keep foaming,
Tobias Holzmann
Old   March 8, 2018, 07:31
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by walakaka View Post
Hi everyone!
Regards
Shafik
Just for the purpose of clarification before deleting this post: high Reynolds numbers do not generate turbulence, it only changes the character of NS as a quasi-linear system. Instabilities, and high enough Re, trigger turbulence. This is true in the "real world" as it is in the "numerical world"
Tobi likes this.
Santiago is offline   Reply With Quote
Old   March 8, 2018, 08:30
Karl-Johan Nogenmyr
kalle is on a distinguished road
From https://en.wikipedia.org/wiki/Lamina...ent_transition
Reynolds found that the transition occurred between Re = 2000 and 13000, depending on the smoothness of the entry conditions. When extreme care is taken, the transition can even happen with Re as high as 40000. On the other hand, Re = 2000 appears to be about the lowest value obtained at a rough entrance.
kalle is offline   Reply With Quote
Old   March 8, 2018, 08:47
Tobi's Avatar
Tobias Holzmann
The post is not deleted I just moved it. Thus, your answer will be here forever
Keep foaming,
Tobias Holzmann
Old   March 8, 2018, 09:01
Default Look at me, I'm citing myself
Originally Posted by kalle View Post
"If not much care is taken, when running your simulation, you can arrive to Re=10^8 and still not get turbulence"
-- Santiago
laminar, pipe, simplefoam, single phase flow, turbulent
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 08:05
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
SimpleFoam: Laminar vs. Turbulent Convergence JasonG OpenFOAM 0 June 2, 2011 08:29
Laminar solver? LES? or DNS? Ray Main CFD Forum 5 March 19, 2003 10:19
