March 7, 2018, 21:09 |
DSMC foam
Jung da yoon
Rep Power: 8 |
I need some help about DSMCfoam result. I did the Super Sonic Corner on the OpenForm tutorial. I want to use this result to get Ch and Cf in para view. I calculated Cf and Ch using (fDMean_X)/(1/2*rhoMMean*mag(UMean)^2) and (qMean)/(1/2*rhoMMean*mag(UMean)^3) equation in paraview But I did not get the results I expected. So I need your help. thank you for reading. Last edited by kane; March 8, 2018 at 02:57. |
May 18, 2018, 12:44 |
ano
Rep Power: 10 |
Hi Kane
In case the problem isn't solved yet: You have to use the inlet velocity of 1936m/s instead of UMean and the inlet density 66.3e-7 kg/m^3 instead of rhoMMean (The values correspond to the tutorial case.) |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
