Problem simulating the temperature rise in a composite material (chtMultiRegionFoam)
Old   February 26, 2019, 05:02
Default Problem simulating the temperature rise in a composite material (chtMultiRegionFoam)
Adam
Adam_K is on a distinguished road
I would like to to simulate the temperature evolution in a composite material comprised on fibers in a matrix, however I've reached a point where I am banging my head against the wall! So I am hoping that someone else has faced a similar issue and can point me in the right direction
I would like to compare with a system of known analytical response so I am looking at a slab initially at 300 K, with both left and right extremities at 310 K for time t > 0s. Here is an image of the system, the slab repeats in the vertical direction (cyclicAMI BCs) and is roughly 5% fibers by volume. I'm using the chtMultiRegionFoam solver from OpenFOAM version 5 via BlueCFD.Here is a link to the case on Dropbox. I defined my mesh with gmsh, then import it using "gmshToFoam", run "changeDictionary" then "splitMeshRegions -cellZonesOnly -overwrite" before running "chtMultiRegionFoam".
I am able to run the simulations that converge, however my bench-marking case is not giving me the result that I expect. I would like to confirm that an aluminum slab with aluminum fibers in it gives the same response as a solid aluminum slab; here are the results of four simulations for the temperature at the center of a 2 cm thick slab. I defined probes in OpenFOAM in both phases at the center of the slab.
  • Black curve - solid aluminum, solved using the laplacianFoam solver, matches well with the analytical solution from Carslaw and Jaeger.
  • Blue curves - composite where both the matrix and the fibers have the same thermal conductivity. There is a thermal resistance between the phases and the fiber temperature and the fiber temperature lags behind that of the matrix.
  • Orange curves - same as the blue curves, but with lower thermal resistance. The fiber and matrix temperatures are very close (as expected), however the overall thermal response to the same boundary conditions is much slower (not expected)
  • Yellow curves - no defined thermal resistance. The fibre-matrix temperature different trend continues to the extreme where the fiber and matrix temperatures are the same, however the temperature increase at the center of the slab is incredibly slow
Does anyone have any insight as to why I am having trouble? I would have expected the orange and yellow curves to converge towards that of a solid block of aluminum (the black curve).
Adam_K is offline   Reply With Quote
Old   March 2, 2019, 10:27
Robin Kamenicky
Robin.Kamenicky is on a distinguished road
Hi Adam,
having a look at your case. Can you send your log files?
Can you send the case with no resistance?
In the file system/fibres/fvSolution change entry for h
h
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.1;
to
h
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0;
Do the same for
system/matrix/fvSolution
If you are interested in temperature evolution in time, use second order scheme for time derivative.
Instead of
ddtSchemes
    default Euler;
Try to use
ddtSchemes
    default CrankNicolson 0.9;
Eventually you can try value 1.
Change it for both system/fibres/fvSchemes, system/mastrix/fvSchemes.
I can see no time step is defined. Only the first one by deltaT.
It is good to setup maxDeltaT and maxDi.
Kind regards,
Robin
Robin.Kamenicky is offline   Reply With Quote
Old   March 27, 2019, 06:51
Adam
Hello Robin,
[Edit March 29th: I think it's a problem with a high diffusion number associated to an oversized time step. For a smaller domain and a maxDi of 1 I am able to replicate the analytical solution. Now I'm working on seeing if that scales well to a larger domain.]
Thanks a lot for your suggestions. I was away a bit this month, so I've only just had the chance to make those changes to fvSchemes and fvSolution. I used a 1 ms time step. This is the "no resistance" case.
Here is the first few iterations from . My whole case-file is here, on dropbox.
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
/*   Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt   *\
|  Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com   |
Build  : 5.x-963176928289
Exec   : C:/PROGRA~1/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/bin/chtMultiRegionFoam.exe
Date   : Mar 27 2019
Time   : 17:04:43
Host   : "DESKTOP-94MS23F"
PID    : 8528
I/O    : uncollated
Case   : C:/PROGRA~1/blueCFD/OFUSER~1/run/2019-0~2/NOTHER~2
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create solid mesh for region matrix for time = 0
Create solid mesh for region fibres for time = 0
*** Reading solid mesh thermophysical properties for region matrix
    Adding to thermos
Selecting thermodynamics package
    type            heSolidThermo;
    mixture         pureMixture;
    transport       constIso;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy;
AMI: Creating addressing and weights between 1381 source faces and 1381 target faces
AMI: Patch source sum(weights) min/max/average = 1, 1, 1
AMI: Patch target sum(weights) min/max/average = 1, 1, 1
    Adding to radiations
Radiation model not active: radiationProperties not found
Selecting radiationModel none
    Adding fvOptions
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options model type limitTemperature
    Source: temperatureLimit
    - selecting all cells
    - selected 73456 cell(s) with volume 7.6332094e-010
*** Reading solid mesh thermophysical properties for region fibres
    Adding to thermos
    type            heSolidThermo;
    transport       constIso;
    thermo          hConst;
    specie          specie;
AMI: Creating addressing and weights between 148 source faces and 148 target faces
    Adding fvOptions
    - selected 20710 cell(s) with volume 3.6679059e-011
Region: matrix Diffusion Number mean: 7524.4325 max: 650221.95
Region: fibres Diffusion Number mean: 15009.725 max: 257544.89
--> FOAM Warning :
    From function virtual void Foam::probes::findElements(const Foam::fvMesh&)
    in file probes/probes.C at line 119
    Did not find location (0.01 0.000124 0.0001) in any cell. Skipping location.
--> FOAM Warning :
    Did not find location (0.019925 0.000124 0.0001) in any cell. Skipping location.
Time = 0.001
Pimple iteration 0
Solving for solid region matrix
DICPCG:  Solving for h, Initial residual = 1, Final residual = 8.7885959e-007, No Iterations 85
Min/max T:300 310
Solving for solid region fibres
DICPCG:  Solving for h, Initial residual = 1, Final residual = 8.3388789e-007, No Iterations 27
Min/max T:300 300.70153
ExecutionTime = 2.66 s  ClockTime = 3 s
Time = 0.002
Pimple iteration 0
DICPCG:  Solving for h, Initial residual = 0.091379998, Final residual = 8.8626934e-007, No Iterations 65
Min/max T:300 310
DICPCG:  Solving for h, Initial residual = 0.22912758, Final residual = 8.3766736e-007, No Iterations 24
Min/max T:300 301.31034
ExecutionTime = 2.769 s  ClockTime = 3 s
Time = 0.003
Pimple iteration 0
DICPCG:  Solving for h, Initial residual = 0.02080289, Final residual = 9.3586955e-007, No Iterations 59
Min/max T:300 310
DICPCG:  Solving for h, Initial residual = 0.11277348, Final residual = 8.3206096e-007, No Iterations 23
Min/max T:300 301.83189
ExecutionTime = 2.872 s  ClockTime = 3 s
Time = 0.004
Pimple iteration 0
DICPCG:  Solving for h, Initial residual = 0.016267807, Final residual = 9.2612505e-007, No Iterations 62
Min/max T:300 310
DICPCG:  Solving for h, Initial residual = 0.07841582, Final residual = 5.6578338e-007, No Iterations 23
Min/max T:300 302.29699
ExecutionTime = 2.978 s  ClockTime = 3 s
Time = 0.005
Pimple iteration 0
DICPCG:  Solving for h, Initial residual = 0.0146828, Final residual = 9.8860161e-007, No Iterations 59
Min/max T:300 310
DICPCG:  Solving for h, Initial residual = 0.057160497, Final residual = 4.6066147e-007, No Iterations 23
Min/max T:300 302.70423
ExecutionTime = 3.081 s  ClockTime = 3 s
Time = 0.006
Pimple iteration 0
DICPCG:  Solving for h, Initial residual = 0.013493589, Final residual = 9.3242413e-007, No Iterations 60
Min/max T:300 310
DICPCG:  Solving for h, Initial residual = 0.046087991, Final residual = 8.5158944e-007, No Iterations 22
Min/max T:300 303.0747
ExecutionTime = 3.183 s  ClockTime = 3 s
Time = 0.007
Pimple iteration 0
DICPCG:  Solving for h, Initial residual = 0.012048782, Final residual = 8.9506872e-007, No Iterations 59
Min/max T:300 310
DICPCG:  Solving for h, Initial residual = 0.037440288, Final residual = 6.4396571e-007, No Iterations 22
Min/max T:300 303.40641
ExecutionTime = 3.286 s  ClockTime = 3 s
Time = 0.008
Pimple iteration 0
DICPCG:  Solving for h, Initial residual = 0.0114714, Final residual = 9.2839842e-007, No Iterations 59
Min/max T:300 310
DICPCG:  Solving for h, Initial residual = 0.032033575, Final residual = 5.2419503e-007, No Iterations 22
Min/max T:300 303.71249
ExecutionTime = 3.391 s  ClockTime = 3 s
Time = 0.009
Pimple iteration 0
DICPCG:  Solving for h, Initial residual = 0.010345927, Final residual = 9.4233542e-007, No Iterations 58
Min/max T:300 310
DICPCG:  Solving for h, Initial residual = 0.027442799, Final residual = 7.7909506e-007, No Iterations 21
Min/max T:300 303.98976
ExecutionTime = 3.493 s  ClockTime = 4 s
Time = 0.01
Closed volume pressure rise with temperature rise vinayak4399 FLUENT 10 March 11, 2020 08:29
Rise of temperature in a thin film by electric potential SofiG System Analysis 0 January 21, 2019 04:41
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
