Error for solving FSI problem by using fsiFoam, thanks. |
March 22, 2018, 21:52 |
LI YULONG
Currently I am using fsiFoam of extend4.0 to run a standard turek&horn cylinder-foil fluid structures interaction case. I compiled whole extend and Toolkits step by step follow http://www.openfoamwiki.net/index.ph...re_interaction. The solidFoam can run, but fsiFoam was not able to run. Error information is as follows: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 4.0-10298020aac7 Exec : fsiFoam Date : Mar 23 2018 Time : 10:36:11 Host : workstation PID : 29565 CtrlDict : "/home/liyanmiho/foam/liyanmiho-4.0/FluidSolidInteraction/run/fsiFoam/HronTurekFsi3/fluid/system/controlDict" Case : /home/liyanmiho/foam/liyanmiho-4.0/FluidSolidInteraction/run/fsiFoam/HronTurekFsi3/fluid nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create dynamic mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: refVelocityLaplacian Selecting motion diffusion: quadratic Selecting motion diffusion: inverseDistance Reading stress mesh Creating fixed displacement boundary condition Creating traction displacement boundary conditions Selecting rheology model linearElastic Creating constitutive model Selecting coupling scheme IQN-ILS Starting time loop Creating pointHistory function object. History point ID: 1165 History point coordinates: (0.6 0.2 0.015) Reference point coordinates: (0.6 0.2 0.025334) Creating hronTurekReport function object. Time = 0.001 (dt = 0.001) Create extended GGI zone-to-zone interpolator Checking fluid-to-solid face interpolator Fluid-to-solid face interpolation error: 0.00333563 Checking solid-to-fluid point interpolator (GGI) calcMasterPointAddressing() const Extended GGI, master point distance, max: 0, avg: 0, min: 0 Solid-to-fluid point interpolation error (GGI): 1.24175e-16 Number of uncovered master faces: 0 Number of uncovered slave faces: 0 calcSlavePointAddressing() const Extended GGI, slave point distance, max: 0, avg: 0, min: 0 Extended GGI, slave point orientation (<0), max: -0.707107, min: -1, nIncorrectPoints: 0/434 Setting traction on solid patch Total force (fluid) = (0 0 0) Total force (solid) = (0 0 0) Evolving solid solver: unsTotalLagrangianSolid fvMatrix<Type>::solve: Solving for D, Initial residula = 0, Final residual = 0, No outer iterations = 1 Max relative residual = 0, Relative residual = 0, enforceLinear = 0 Current fsi relative residual norm: 0 Alternative fsi residual: 0 Time = 0.001, iteration: 1 Modes before clean-up : 0, modes after clean-up : 0 Current fsi under-relaxation factor: 0.05 Creating accumulated fluid interface displacement Maximal accumulated displacement of interface points: 0 GAMG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 1 GAMG: Solving for cellMotionUy, Initial residual = 0, Final residual = 0, No Iterations 1 GAMG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 1 GAMG: Solving for cellMotionUy, Initial residual = 0, Final residual = 0, No Iterations 1 Evolving fluid solver: consistentIcoFluid Courant Number mean: 0 max: 0 velocity magnitude: 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.2281e-08, No Iterations 2 DILUPBiCG: Solving for Uy: solution singularity GAMG: Solving for p, Initial residual = 1, Final residual = 8.62349e-07, No Iterations 74 GAMG: Solving for p, Initial residual = 0.035702, Final residual = 9.96795e-07, No Iterations 19 --> FOAM FATAL ERROR: flux requested but p not specified in the fluxRequired sub-dictionary of fvSchemes. From function fvMatrix<Type>::flux() in file lnInclude/fvMatrix.C at line 1046. FOAM aborting Aborted (core dumped) Could you please give me valuable suggestion or information to fix this problem? Thank you very much! Liyan |
May 24, 2018, 10:21 |
Rep Power: 15 |
Hi Liyan,
I realize this may be two months too late, but to fix the flux required problem, you need to add Code:
mesh.schemesDict().setFluxRequired(p().name()); |
March 27, 2019, 14:09 |
Hojatollah Gholami
Rep Power: 7 |
Hi amanbearpig
I run HronTurek test with fsiFoam (FSI2). the problem is when deflection increase, the sulotion diverge. Do you any recommend for fvScheme ond fvSolution? Last edited by Hgholami; March 28, 2019 at 08:36. |
extend 4.0, fsifoam |
Two way Fsi Problem- Non linear problem | kmgraju | CFX | 4 | April 28, 2015 11:15 |
Defining contact regions in FSI problem.!!! | sreemvlk | ANSYS | 0 | June 12, 2014 00:33 |
prestrain in FSI problem | mina.m | STAR-CCM+ | 0 | October 31, 2013 11:39 |
divergent of a FSI problem | edooo0 | FLUENT | 0 | August 5, 2013 17:54 |
FSI MODELING PROBLEM (pinball)!!! | smn | CFX | 1 | September 16, 2009 00:33 |
