Dynamic mesh parallel error in OpenFOAM-5.x
Old   March 26, 2018, 21:40
Default Dynamic mesh parallel error in OpenFOAM-5.x
Nadun Palmada
Nadun19 is on a distinguished road
Hi
I am trying to run a dynamic mesh problem in parallel (pimpleDyMFoam) (it runs perfectly fine in serial) but I get the following errors when trying to run in parallel:
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: velocityLaplacian
[2]
[2]
[2] --> FOAM FATAL IO ERROR:
[2] size 2432 is not equal to the given value of 1218
[2]
[2] file: /people/tpal287/OpenFOAM/tpal287-5.x/2d_symmetric/processor2/0/pointMotionU.boundaryField.upperWall from line 38 to line 2480.
[2]
[2]     From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int]
[2]     in file /people/tpal287/OpenFOAM-5.x/src/OpenFOAM/lnInclude/Field.C at line 302.
[2]
FOAM parallel run exiting
[2]
[3] --> FOAM FATAL IO ERROR:
[3] size 2432 is not equal to the given value of 1216
[3]
[3] file: /people/tpal287/OpenFOAM/tpal287-5.x/2d_symmetric/processor3/0/pointMotionU.boundaryField.upperWall from line 38 to line 2480.
[3]
[3]     From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int]
[3]     in file /people/tpal287/OpenFOAM-5.x/src/OpenFOAM/lnInclude/Field.C at line 302.
[3]
[3]
decomposePar runs perfectly fine without any errors. My pointMotionU in the case/0/ directory looks like:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    leftBoundary
        type            zeroGradient;
    rightBoundary
        type            zeroGradient;
    centerLine
        type            symmetryPlane;
	upperWall
		type			dynPerCircle;
		circleRadius	0.01500;
		xCompInitialCenter	0.0;
		speed			0.00500;
		yCompFinalCenter	0.01900;
		value			uniform (0 0 0);
	frontAndBack
		type empty;
Thanks in advance
Nadun19 is offline   Reply With Quote
Old   March 27, 2018, 10:19
mojuss is on a distinguished road
Which files do you have in the "0" folder ?
regards,
Arthur
mojuss is offline   Reply With Quote
Old   March 28, 2018, 17:31
Nadun Palmada
The <case>/0./ folder has p, U and pointMotionU files
Old   March 29, 2018, 03:42
delete (or keep a copy) of the pointMotionU file. decompose your case and run the case in parallel.
Old   April 9, 2018, 20:11
Nadun Palmada
The case doesn't run without the pointMotionU file, i.e. I get this error:
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] cannot find file "/home/nadun/OpenFOAM/3dcylinder/processor0/0/pointMotionU"
[0]
[0]     From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
[0] [1]
Reconstruction of the parallel case with dynamic mesh makaveli_lcf OpenFOAM Post-Processing 7 October 18, 2023 11:28
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
Parallel processing for SDOF Dynamic mesh amohizin Fluent UDF and Scheme Programming 2 March 20, 2018 02:33
dynamic mesh in openfoam cctv OpenFOAM Running, Solving & CFD 0 March 19, 2014 02:04
