March 26, 2018, 21:40 |
Dynamic mesh parallel error in OpenFOAM-5.x
Nadun Palmada
Rep Power: 9 |
Hi
I am trying to run a dynamic mesh problem in parallel (pimpleDyMFoam) (it runs perfectly fine in serial) but I get the following errors when trying to run in parallel: Code:
Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: velocityLaplacian [2] [2] [2] --> FOAM FATAL IO ERROR: [2] size 2432 is not equal to the given value of 1218 [2] [2] file: /people/tpal287/OpenFOAM/tpal287-5.x/2d_symmetric/processor2/0/pointMotionU.boundaryField.upperWall from line 38 to line 2480. [2] [2] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [2] in file /people/tpal287/OpenFOAM-5.x/src/OpenFOAM/lnInclude/Field.C at line 302. [2] FOAM parallel run exiting [2] [3] --> FOAM FATAL IO ERROR: [3] size 2432 is not equal to the given value of 1216 [3] [3] file: /people/tpal287/OpenFOAM/tpal287-5.x/2d_symmetric/processor3/0/pointMotionU.boundaryField.upperWall from line 38 to line 2480. [3] [3] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [3] in file /people/tpal287/OpenFOAM-5.x/src/OpenFOAM/lnInclude/Field.C at line 302. [3] FOAM parallel run exiting [3] Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { leftBoundary { type zeroGradient; } rightBoundary { type zeroGradient; } centerLine { type symmetryPlane; } upperWall { type dynPerCircle; circleRadius 0.01500; xCompInitialCenter 0.0; speed 0.00500; yCompFinalCenter 0.01900; value uniform (0 0 0); } frontAndBack { type empty; } } |
March 27, 2018, 10:19 |
Rep Power: 8 |
Which files do you have in the "0" folder ? regards, Arthur |
March 28, 2018, 17:31 |
Nadun Palmada
Rep Power: 9 |
The <case>/0./ folder has p, U and pointMotionU files
March 29, 2018, 03:42 |
Rep Power: 8 |
delete (or keep a copy) of the pointMotionU file. decompose your case and run the case in parallel.
April 9, 2018, 20:11 |
Nadun Palmada
Rep Power: 9 |
The case doesn't run without the pointMotionU file, i.e. I get this error:
Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: velocityLaplacian [0] [0] [0] --> FOAM FATAL ERROR: [0] cannot find file "/home/nadun/OpenFOAM/3dcylinder/processor0/0/pointMotionU" [0] [0] From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const [0] [1] |
Reconstruction of the parallel case with dynamic mesh | makaveli_lcf | OpenFOAM Post-Processing | 7 | October 18, 2023 11:28 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Parallel processing for SDOF Dynamic mesh | amohizin | Fluent UDF and Scheme Programming | 2 | March 20, 2018 02:33 |
dynamic mesh in openfoam | cctv | OpenFOAM Running, Solving & CFD | 0 | March 19, 2014 02:04 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
