K-Omega-Epsilon BCs for suction inlet
Old   March 27, 2018, 18:28
Default K-Omega-Epsilon BCs for suction inlet
Romit
CFDBro is on a distinguished road
Hello everyone. I have a question about RAS turbulence boundary conditions related to a suction inlet (i.e. uniform flow velocity out of the domain). While my k omega SST turbulence model converges, my k epsilon implementation blows up (though this might be because this isn't really a free shear layer problem). My y+ is uniform (for now) at about 20. After shadowing these forums extensively, it seemed that k omega SST with the omegaWallFunction, the nutUSpaldingWallFunction, the kqRWallFunction takes care of the wall boundary conditions.
My question is related to the suction inlet (which I hadn't thought of really). I have been using the usual CFD online tool (https://www.cfd-online.com/Tools/turbulence.php) to calculate my k, omega and epsilon assuming my turbulence length scale to be 0.07 the hydraulic diameter and specifying them through turbulentIntensityKineticEnergyInlet (for k), fixedValue (for omega), turbulentMixingLengthDissipationRateInlet (for epsilon).
However this link (https://www.openfoam.com/documentati...alarField.html) says "In the event of reverse flow, a zero-gradient condition is applied" for omega. Now technically in my suction inlet, a reverse flow IS happening. I'm at a loss here - what exactly do I specify for my inlet and outlet BCs for k, omega, epsilon. I have my boundary conditions added here.
U
internalField   uniform 10;
boundaryField
    walls
        	type            kqRWallFunction;
		value           $internalField;
    outlets
		type 			zeroGradient;
    inlet
		type 			turbulentIntensityKineticEnergyInlet;
		intensity       	0.02;
		value 			uniform 0.00015;
P
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlets
        type            totalPressure;
	p0              uniform 0.0;
        gamma		0.0;
    walls
        type            zeroGradient;
nut
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0.14;
boundaryField
    inlet
        type            freestream;
        freestreamValue uniform 0.14;
    outlets
        type            freestream;
    walls
        type            nutUSpaldingWallFunction;
        value           uniform 0;
k
boundaryField
    walls
    outlets
		type 			zeroGradient;
    inlet
		intensity       	0.02;
epsilon
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 100;
boundaryField
    walls
        	type            epsilonWallFunction;
    outlets
		type 			zeroGradient;
    inlet
		type turbulentMixingLengthDissipationRateInlet;
		mixingLength 0.0378;
		value uniform 200; // placeholder
omega
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 1000;
boundaryField
    walls
        type            omegaWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
    inlet
	    type 			fixedValue;
	    value    		        uniform 0.324;
	outlets
	    type 			zeroGradient;
Thanks for reading! If you need anymore information, feel free to ask.
CFDBro is offline   Reply With Quote
boundary conditions, k omega sst, rasmodel
SimpleFoam bounded k and epsilon always diverging Deagle OpenFOAM Running, Solving & CFD 2 October 20, 2017 12:33
epsilon and omega free stream BC's immortality OpenFOAM Running, Solving & CFD 13 September 10, 2013 03:38
inlet and outlet BCs for airfoil simulation michel1988 OpenFOAM Running, Solving & CFD 2 July 9, 2013 11:12
BCs at Inlet and Outlet sebastian OpenFOAM Running, Solving & CFD 3 May 10, 2013 22:34
Inlet and outlet BCs in heat transfer Scot OpenFOAM 0 May 17, 2011 17:23
