Simulation stops at simulation but doesn't diverge mpirun error
Old   March 28, 2018, 03:52
Default Simulation stops at simulation but doesn't diverge mpirun error
D
Dar87 is on a distinguished road
Hi everyone,
I have a strange problem with my simulation on OpenFoam.
I notice that the simulation during the running stops at certain iteration, but doesn't diverge, simply no proceed.
In other similar simulations the running stops at certain iteration, without diverging and after some time exits, giving me the following error:
mpirun noticed that process rank 0 with PID 27164 on node thinkstation-node exited on signal 15 (Terminated).
Moreover I ran other similar simulations with same geometry, same mesh, changing only boudary conditions and they run without similar problems.
The solver that I use is rhoSimpleFoam
The mesh consists of 10^6 cells.
Dar87 is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
