July 12, 2013, 10:46 |
interRegionHeatTransferModel
Nemanja Kliska
I am trying to create a heat transfer model using chtMultiRegionFoam. In this model I am trying to simulate a heater using a constant internal heating term. I looked into how other people have attempted to do this in OF1.7 but I think these threads are outdated as there has been considerable change to the solver.
I am only working with solid components so the solver for this section looks like: fvm::ddt(betav*rho, h) - fvm::laplacian(betav*alpha, h, "laplacian(alpha,h)") == fvOptions(rho, h) I looked into adding a source term to the above equation, but it seems as though fvOptions has the capacity to act as heat source term using interRegionHeatTransferModel. Since this is a relatively new feature I cannot find any documentation or examples of how to implement this. I already looked at OF2.2 tutorials with fvOptions and turned up empty. Has anyone here used, or has an example/tutorial of how to implement fvOptions::interRegionHeatTransferModel as a constant heat generation source. |
January 22, 2014, 15:11 |
Michael Page
Rep Power: 17 |
I'm facing the same problem.
Does someone have an example of interRegionHeatTransferModel as a constant heat generation source? Thank you, |
March 27, 2018, 01:13 |
Peter Hess
Rep Power: 17 |
Dear openFoamers,
This topic still for me unsolved. How to add heat source to a given region? Any idea? Regards Peter |
March 30, 2018, 10:30 |
Yann
Rep Power: 26 |
Hi Peter,
You can add a heat source using fvOptions with the "scalarSemiImplicitSource". This is quite straightforward and you can use different selectionMode depending on what you want to do. (ie: using a cellZone to add a heat source in a specific volume inside your domain) There are several posts on this topic, Check this one. |
fvoptions, heat source |
