BC of wideBandAbsorptionEmission
Old   April 1, 2018, 03:50
Post BC of wideBandAbsorptionEmission
Jung da yoon
kane is on a distinguished road
Hello all!!
I have tried to use wideBandAbsorptionEmission model.
But I don't know the form of BC.
This is the constant directory.
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      radiationProperties;
radiation on;
radiationModel  fvDOM;
fvDOMCoeffs
    nPhi    3;         // azimuthal angles in PI/2 on X-Y.(from Y to X)
    nTheta  6;          // polar angles in PI (from Z to X-Y plane)
    convergence 1e-6;   // convergence criteria for radiation iteration
    maxIter 1000;         // maximum number of iterations
// Number of flow iterations per radiation iteration
solverFreq 1;
absorptionEmissionModel wideBandAbsorptionEmission;
constantAbsorptionEmissionCoeffs
   absorptivity    absorptivity    [ 0 -1 0 0 0 0 0 ]  1;
   emissivity      emissivity      [ 0 -1 0 0 0 0 0 ]  0;
   E               E               [ 1 -1 -3 0 0 0 0 ] 0.05;
scatterModel    none;
But I have to modify constantAbsorptionEmissionCoeffs part with below code.
band0
        bandLimits (1.0e-6 2.63e-6);
        EhrrCoeff       0.0;
        species
            CH4
                Tcommon         300.;
                Tlow            300.;
                Thigh           2500.;
                invTemp         false;
                loTcoeffs (0 0 0 0 0 0) ;
                hiTcoeffs (.1 0 0 0 0 0);
            CO2
                Tcommon         300.;
                Tlow            300.;
                Thigh           2500.;
                invTemp         false;
            H2O
                Tcommon         300.;
                Tlow            300.;
                Thigh           2500.;
                invTemp         false;
            Ysoot
                Tcommon         300.;
                Tlow            300.;
                Thigh           2500.;
                invTemp         false;
What form of code can I modify to use the wideBandAbsorptionEmissionModel?
Thank you for replying in advance.
Best regards.
kane is offline   Reply With Quote
Old   April 2, 2018, 01:04
Post
Jung da yoon
Hello.
I have tried to use 'wideBandAbsorptionEmission' model.
But it is hard to use.
1. constant/radiationProperties
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
radiation on;
fvDOMCoeffs
solverFreq 1;
wideBandAbsorptionEmissionCoeffs
   emissivity      emissivity      [ 0 -1 0 0 0 0 0 ]  1;
   E               E   		   [ 1 -1 -3 0 0 0 0 ] 0;
band0
            bandLimits (1.0e-5 2.63e-5);
            EhrrCoeff       0.0;
            species
                CH4
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
                CO2
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
                H2O
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
                Ysoot
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
After applying , there was a problem.
|  \\    /   O peration     | Version:  5.0                                   |
Build  : 5.0
Exec   : radiationFoam
Date   : Apr 02 2018
Time   : 13:56:02
Host   : "master"
PID    : 8796
I/O    : uncollated
Case   : /home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/heatTransfer/Enclosure
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field "ILambda.*"    tolerance 1e-06
Reading Temperature field
Selecting radiationModel fvDOM
Selecting absorptionEmissionModel wideBandAbsorptionEmission
--> FOAM FATAL IO ERROR:
keyword lookUpTableFileName is undefined in dictionary "/home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/heatTransfer/Enclosure/constant/radiationProperties.wideBandAbsorptionEmissionCoeffs"
file: /home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/heatTransfer/Enclosure/constant/radiationProperties.wideBandAbsorptionEmissionCoeffs from line 37 to line 39.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 566.
FOAM exiting
What is the problem ??
I think some codes in radiationProperties file was wrong.
Best regards
Old   April 5, 2018, 09:42
Jung da yoon
hi all
Does anyone have 'widebandabsorptionemission' case??
Old   April 7, 2018, 09:37
Post
Jung da yoon
Hello all.
I have tried to run widebandabsorptionEmission model.
But I have failed. I don't know the problem.
This is radiationProperties file.
|  \\    /   O peration     | Version:  5                                     |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
radiation on;
fvDOMCoeffs
    tolerance   1e-6;   // convergence tolerance for radiation iteration
solverFreq 1;
    absorptivity    absorptivity    [ m^-1 ]       0.01;
    emissivity      emissivity      [ m^-1 ]       0.01;
    E               E               [ kg m^-1 s^-3 ]  0;
    lookUpTableFileName "thermophysicalProperties";
    band0
            EhrrCoeff       0.0;
            species
                CH4
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
                CO2
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
                H2O
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
                Ysoot
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
scatterModel    none;
sootModel       none;
Actually I don't know the lookuptable's function.
So I set lookuptablefilename as "thermo.compressiblegas"
And this is thermo.compressiblegas
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      thermo.compressibleGas;
O2
    specie
        molWeight       31.9988;
    thermodynamics
        Tlow            200;
        Thigh           5000;
        Tcommon         1000;
        highCpCoeffs    ( 3.69758 0.00061352 -1.25884e-07 1.77528e-11 -1.13644e-15 -1233.93 3.18917 );
        lowCpCoeffs     ( 3.21294 0.00112749 -5.75615e-07 1.31388e-09 -8.76855e-13 -1005.25 6.03474 );
    transport
        As              1.67212e-06;
        Ts              170.672;
H2O
    specie
        molWeight       18.0153;
    thermodynamics
        Tlow            200;
        Thigh           5000;
        Tcommon         1000;
        highCpCoeffs    ( 2.67215 0.00305629 -8.73026e-07 1.201e-10 -6.39162e-15 -29899.2 6.86282 );
        lowCpCoeffs     ( 3.38684 0.00347498 -6.3547e-06 6.96858e-09 -2.50659e-12 -30208.1 2.59023 );
    transport
        As              1.67212e-06;
        Ts              170.672;
CH4
    specie
        molWeight       16.0428;
    thermodynamics
        Tlow            200;
        Thigh           6000;
        Tcommon         1000;
        highCpCoeffs    ( 1.63543 0.0100844 -3.36924e-06 5.34973e-10 -3.15528e-14 -10005.6 9.9937 );
        lowCpCoeffs     ( 5.14988 -0.013671 4.91801e-05 -4.84744e-08 1.66694e-11 -10246.6 -4.64132 );
    transport
        As              1.67212e-06;
        Ts              170.672;
CO2
    specie
        molWeight       44.01;
    thermodynamics
        Tlow            200;
        Thigh           5000;
        Tcommon         1000;
        highCpCoeffs    ( 4.45362 0.00314017 -1.27841e-06 2.394e-10 -1.66903e-14 -48967 -0.955396 );
        lowCpCoeffs     ( 2.27572 0.00992207 -1.04091e-05 6.86669e-09 -2.11728e-12 -48373.1 10.1885 );
    transport
        As              1.67212e-06;
        Ts              170.672;
N2
    specie
        molWeight       28.0134;
    thermodynamics
        Tlow            200;
        Thigh           5000;
        Tcommon         1000;
        highCpCoeffs    ( 2.92664 0.00148798 -5.68476e-07 1.0097e-10 -6.75335e-15 -922.798 5.98053 );
        lowCpCoeffs     ( 3.29868 0.00140824 -3.96322e-06 5.64152e-09 -2.44486e-12 -1020.9 3.95037 );
    transport
        As              1.67212e-06;
        Ts              170.672;
But errors occured. I don't know the problem.
Build  : 5.0
Date   : Apr 07 2018
Time   : 22:23:36
Host   : "master"
PID    : 28926
I/O    : uncollated
nProcs : 1
Create time
keyword fields is undefined in dictionary "/home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/heatTransfer/Enclosure/constant/thermophysicalProperties"
file: /home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/heatTransfer/Enclosure/constant/thermophysicalProperties from line 20 to line 37.
FOAM exiting
Any reply is okay.
Best regards.
Old   September 24, 2021, 03:35
Bushra Rasheed
B_R_Khan is on a distinguished road
Originally Posted by kane View Post
Hello all.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
radiation on;
fvDOMCoeffs
solverFreq 1;
    band0
            EhrrCoeff       0.0;
            species
                CH4
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
                CO2
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
                H2O
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
                Ysoot
                    Tcommon         300.;
                    Tlow            300.;
                    Thigh           2500.;
                    invTemp         false;
scatterModel    none;
sootModel       none;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
O2
    specie
        molWeight       31.9988;
    thermodynamics
        Tlow            200;
        Thigh           5000;
        Tcommon         1000;
    transport
        As              1.67212e-06;
        Ts              170.672;
H2O
    specie
        molWeight       18.0153;
    thermodynamics
        Tlow            200;
        Thigh           5000;
        Tcommon         1000;
    transport
        As              1.67212e-06;
        Ts              170.672;
CH4
    specie
        molWeight       16.0428;
    thermodynamics
        Tlow            200;
        Thigh           6000;
        Tcommon         1000;
    transport
        As              1.67212e-06;
        Ts              170.672;
CO2
    specie
        molWeight       44.01;
    thermodynamics
        Tlow            200;
        Thigh           5000;
        Tcommon         1000;
    transport
        As              1.67212e-06;
        Ts              170.672;
N2
    specie
        molWeight       28.0134;
    thermodynamics
        Tlow            200;
        Thigh           5000;
        Tcommon         1000;
    transport
        As              1.67212e-06;
        Ts              170.672;
Build  : 5.0
Date   : Apr 07 2018
Time   : 22:23:36
Host   : "master"
PID    : 28926
I/O    : uncollated
nProcs : 1
Create time
FOAM exiting
Any reply is okay.
Best regards.
I know I am a few years too late but just for anyone who is still struggling with lookUpTable, you have to write none in lookUp table:
lookUpTableFileName none;
then paste the band0 code written in radiation properties file inside constant folder as stated in Openfoam guide.
Regards,
Bushra.
B_R_Khan is offline   Reply With Quote
