Outlet pressure boundary condition in interFoam
Like Tree3Likes
Old   July 4, 2013, 18:25
Default Outlet pressure boundary condition in interFoam
arnau1985's Avatar
Arnau
arnau1985 is on a distinguished road
I am running an interFoam case with inlet and outlet and I don't know how to define the pressure (p_rgh) boundary condition in the outlet. I tried to use the same as the patch "sky" in the damBreak tutorial, but I got a physical no-sense (see attached screenshot).
I also tried several solutions, such as that of this link and several of CFD-online, but my simulations either didn't run or diverged after a few iterations. I know it's some tiny detail I'm missing, but I don't know what to do. I also tried a "zeroGradient" type of boundary condition for pressure and "fixedValue" of zero, but it didn't work.
Thank you very much!
@rijit and Kahnbein.Kai like this.
arnau1985 is offline   Reply With Quote
Old   July 9, 2013, 11:27
Artur's Avatar
Artur
Artur will become famous soon enough
You didn't say exactly what your simulation is and the picture didn't help me much.
I use LTSInterFoam for ship hydrodynamic calculations and typically go for zeroGradient or fixedValue uniform 0 for the dynamic pressure term at the outlet. I suppose you could also use something like inletOutlet too.
Artur is offline   Reply With Quote
Old   July 10, 2013, 04:19
Default Details on "Outlet pressure boundary condition in interFoam"
arnau1985's Avatar
Arnau
Hi Artur,
You're right, I gave very scarce information. I've attached a new picture with some more details on the pressure boundary conditions (henceforth B.C.) of my simulations.
As regards the outlet, as you suggested, I've used a zeroGradient as well as a fixedValue uniform 0 and it didn't work. I also copied the B.C. settings of the "atmosphere" patch in damBreak (inletOutlet type in "boundary" and totalPressure for "p_rgh") and I always get the same result.
However, I've recently observed that at higher inlet velocities, the jet leaves the domain though the right-hand outlet instead of through the bottom and everything works perfectly. I've also run the damBreak case changing one of the side walls to an outlet B.C. and this "spurious" bubbles didn't appear either. Is it possible that this problem only arises when the outlet is horizontal (i.e. perpendicular to the gravity direction)? Maybe it's due to the use of "p_rgh" (gravity corrected pressure) instead of "p".
Thank you very much for your help.
Regards,
Arnau.
Old   July 10, 2013, 04:30
Artur's Avatar
Artur
Ok, I see what you mean now. Unfortunately I don't know much about gravity driven flow simulations as I use interFoam only to calculate the free surface of moving ships so hopefully someone more experienced will have a look at your post. In the meantime, your mesh seems fairly coarse in the outlet region, have you tried refining it a bit to see if it makes a difference?
P.S. I don't think that the horizontal orientation of the outlet should make any difference because it seems like it should be (by enlarge) perpendicular to the flow of the jet.
Old   July 10, 2013, 04:43
Pablo Higuera
Phicau is on a distinguished road
Hi Arnau,
I think the problem may be caused by the bottom outlet, as I guess it is located below Z = 0 plane.
Try making all your outlet patchs be located in the first quadrant (x,y,z>0) and use the same BCs as for the atmosphere and let us know if it gets better.
Best,
Pablo
Phicau is offline   Reply With Quote
Old   July 10, 2013, 08:26
arnau1985's Avatar
Arnau
@Artur:
Maybe you're right about the mesh, I haven't had the time to try more refined meshes (I'm running some simulations as I write). However, the damBreak case run perfectly with a coarser mesh and with an outlet instead of one of the side walls, as I described in my previous post.
@Pablo:
You're right, the outlet was below the Z=0 plane. Indeed, in previous simulations I've observed that everything started going bad when the jet crossed this plane (that sounds kind of esoteric, doesn't it?). Nevertheless, I've run the same simulation as you said: in the first quadrant and with the same BC as the atmosphere but I still get the same result (I've attached a video). I'm trying finer meshes to see what happens, I'll let you know about the results.
Video: https://www.dropbox.com/s/corgjwhem1...let_as_sky.avi
BTW, these are the dictionaries of my outlet patch:
// boundary
        outlet
            type            wall;
// U
    outlet
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
// alpha1, k, epsilon
    outlet
        type            inletOutlet;
        inletValue      $internalField;
        value           $internalField;
// p_rgh
    outlet
        type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
Thank you very much for your help!
Best,
Arnau.
Old   July 10, 2013, 08:37
Artur's Avatar
Artur
I noticed you defined the outlet as a wall in your boundary file. Maybe try changing it to patch? On the video it appears as if the flow is not passing through the outlet so perhaps this is the reason.
Old   July 10, 2013, 08:48
Pablo Higuera
try this:
// alpha1
    outlet
        type            inletOutlet;
        inletValue      0;
Old   July 10, 2013, 10:28
arnau1985's Avatar
Arnau
@Artur:
I used "wall" as B.C. because is the type to which the patch "atmosphere" belongs. I also tried the generic "patch" and I got the same result.
@Pablo:
Since my alpha1 "internalField" is assigned "uniform 0", what you suggest is what I have been trying.
Any idea? This is exhausting... I'll let you know what happens with the finer-mesh simulations.
Best,
Arnau.
Old   July 11, 2013, 03:16
arnau1985's Avatar
Arnau
Here are the results with a finer mesh and the problem persists:
https://www.dropbox.com/s/t8ekfxdm20...resolution.avi
I've zipped the entire simulated case (before running), in case somebody wanted to check it out:
https://www.dropbox.com/s/fnc8nuu1iwp4h5e/dam.zip
I don't know what else I should try...
Old   July 11, 2013, 03:28
Pablo Higuera
Well, actually in this case you provided the bottom outlet is actually included in patch "wall" instead of being part of "outlet"...
Artur likes this.
Old   July 11, 2013, 03:46
arnau1985's Avatar
Arnau
Yes, Pablo, this is the last case I run, but as I told you I tried with "patch" as well. Anyway, the patch "atmosphere" in damBreak is defined as "wall", that's why this was my first option.
Old   July 11, 2013, 03:54
Pablo Higuera
What I mean is that the bottom portion you intend to use as an outlet is actually a part of the boundary called "wall" instead of the one called "outlet" (disregarding if they are either a patch or a wall type), so the boundary conditions of "wall" apply instead of the boundary conditions of "outlet". See the attached picture ("wall" in red and "outlet" in blue)
Old   July 11, 2013, 03:57
Default Random question
  #14
Bryan
Missileman is on a distinguished road
Hi, I'm new to this forum. I'm trying to create a new post but I can't find the "New Post" or "New Thread" button. Help?
Missileman is offline   Reply With Quote
Old   July 11, 2013, 04:02
arnau1985's Avatar
Arnau
Yes, since I thought the horizontal outlet may have been the cause of my troubles, I tried to define as outlet only the vertical patches (again, I tried both cases, but the one I uploaded was the last one). Anyway, the result is the same: the water keeps on blocking at the outlet.
Thanks for your time, Pablo!
Artur's Avatar
Artur
Here, below the sub-forum list:
http://www.cfd-online.com/Forums/openfoam/
Old   July 11, 2013, 04:05
Bryan
Many thanks!
Old   July 11, 2013, 04:12
Artur's Avatar
Artur
Have you tried pure zeroGradient BC at the outlet for alpha1? From the description given here:
http://www.cfd-online.com/Forums/ope...letoutlet.html
I thought that maybe if your outflow is not strong enough it will not actually leave the domain? This would tie in with what you said earlier that with increased inlet velocity the problem disappears. Just a thought...
Old   November 26, 2013, 08:57
Default BC located at z=0 => rho*g*h = 0
  #19
Thibault Pringuey
thibault_pringuey is on a distinguished road
Hello Arnau,
I am sort of looking at the similar issues. As you suggested, I believe that the issue related to the setting of a static pressure BC with p_rgh.
Have you tried setting your outlet BC to z=0 such that by setting fixed value of p_rgh = p_outlet_static + rho*g*0 = p_outlet_static?
Anyway, have you solved your problem?
Regards,
Thibault
thibault_pringuey is offline   Reply With Quote
Old   November 26, 2013, 10:00
arnau1985's Avatar
Arnau
Hi Thibault,
I solved the problem to a certain extent. What I did is the following: I realized that supercritical flow outlets in OpenFOAM behave as expected as long as there is no flow separation (I got the idea from this tutorial). So I replaced the spill of my model with a descending slope (see attached picture), set all the variables at the outlet to zeroGradient (except for pressure, which I set to buoyantPressure) and everything ran smoothly.
I am still trying to do all this in a more elegant way without spills, slopes and so on: just directly imposing a given water depth and a hydrostatic pressure profile at the outlet. I will try to keep you informed of my findings.
Good luck!
Arnau.
interfoam outlet p_rgh
Outlet boundary condition for wave flume with interFoam solver Arnoldinho OpenFOAM 9 July 10, 2018 05:15
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 14:32
Turbulent intensity for pressure Outlet Boundary condition Mohsin FLUENT 1 April 30, 2010 10:36
