Can we relate residuals to absolute error in velocity/pressure measurements? |
May 15, 2018, 09:36 |
Rep Power: 12 |
Hi all,
I have a steady simulation with a primary velocity component of around 1e-3 m/s, and secondary velocity components (which I need to resolve accurately) that are around 1e-8 m/s. I am using simpleFoam to solve the flow, and I am facing some uncertainty about what magnitude to set the residuals in order to properly resolve the flow. For example, if I need a precision of 1e-10 m/s on the y-component of velocity, does that mean I need to wait until the initial residual for Uy is less than 1e-10? I was just wondering if there is a simple way to estimate the needed residuals based on the needed precision in physical variables. Thanks so much |
May 16, 2018, 00:54 |
Uwe Pilz
Rep Power: 15 |
If you have velocities in different directions, you have to choose the residuals to the smallest one, as you guessed.
May be it is simpler to transform your problem with some kind of coordinate transformation, to get the velocities closer. This is possible only for a simple geometry and for laminar flow.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
May 16, 2018, 12:02 |
Rep Power: 12 |
Hi Uwe,
Thanks for the message and advice. Just so I understand, are you saying that the order of magnitude of the residual is comparable to the order of magnitude of uncertainty in the measurement? i.e. are the residuals relative errors or absolute errors? To say it another way, if your residual for Uz is 1.0e-3, does that mean the value for Uz is accurate to 3 significant digits, or that the value is accurate to 1.0e-3 m/s? Thanks again |
motorBike Residuals for SST k-omega... and mine | JR22 | OpenFOAM Running, Solving & CFD | 6 | August 1, 2013 09:08 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 12:18 |
