Air to water phase change in fluidised bed example-Two phase euler foam |
Quebec
Rep Power: 0 ![]() |
I am using the fluidised bed tutorial example in Two Phase Euler Foam. In the tutorial example, air is blown into a column sand particles. I am trying to change the air to water. The sand is a dispersed phase while the air is not (and I am trying to replace the air with water). However, I am getting the following error which I do not understand. I think it may be a problem with setting the phase properties but I would appreciate any pointers as to which paramets need to be fixed. Foam::error: ![]() #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam: ![]() #5 Foam::dragModels::Ergun::CdRe() const at ??:? #6 Foam::dragModels::GidaspowErgunWenYu::CdRe() const at ??:? #7 Foam::dragModel::Ki() const at ??:? #8 Foam::dragModel::K() const at ??:? #9 Foam::BlendedInterfacialModel<Foam::dragModel>::K( ) const at ??:? #10 Foam::twoPhaseSystem::Kd() const at ??:? #11 ? at ??:? #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 ? at ??:? Thank you, |
Display Modes | |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
three phase modelling (air sand water ) | Gunjan kumar | FLUENT | 0 | December 29, 2004 07:55 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 07:04 |
