Sean Gorry
Rep Power: 9 ![]() |
I am getting the following when I run my CHT case, what could be the source of the problem?
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1712 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1712 Arch : "LSB;label=32;scalar=64" Exec : chtMultiRegionSimpleFoam Date : Jun 10 2018 Time : 15:58:51 Host : "DESKTOP-EGDC4UU" PID : 1321 I/O : uncollated Case : /mnt/d/Microgen/OpenFOAM/CHT_Test_1_Copy nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region microgen_fpse-fluid_domain for time = 0 Create solid mesh for region microgen_fpse-head_can for time = 0 Create solid mesh for region microgen_fpse-heat_acceptors for time = 0 Create solid mesh for region microgen_fpse-refractory for time = 0 *** Reading fluid mesh thermophysical properties for region microgen_fpse-fluid_domain Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } AMI: Creating addressing and weights between 3694 source faces and 3694 target faces AMI: Patch source sum(weights) min/max/average = 0.999998, 1, 1 AMI: Patch target sum(weights) min/max/average = 0.999997, 1, 1 AMI: Creating addressing and weights between 92064 source faces and 92447 target faces AMI: Patch source sum(weights) min/max/average = 0.975461, 1, 0.999998 AMI: Patch target sum(weights) min/max/average = 0.970341, 1, 0.999998 AMI: Creating addressing and weights between 2953 source faces and 2901 target faces AMI: Patch source sum(weights) min/max/average = 0.9996, 1, 0.999999 AMI: Patch target sum(weights) min/max/average = 0.999441, 1, 0.999999 AMI: Creating addressing and weights between 3182 source faces and 3134 target faces AMI: Patch source sum(weights) min/max/average = 0.998369, 1, 0.999986 AMI: Patch target sum(weights) min/max/average = 0.998738, 1, 0.999987 Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulence Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 0.047633 average: 0.047633 RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } --> FOAM FATAL ERROR: LHS and RHS of - have different dimensions dimensions : [0 2 -2 0 0 0 0] - [1 -1 -2 0 0 0 0] From function Foam::dimensionSet Foam::operator-(const Foam::dimensionSet&, const Foam::dimensionSet&) in file dimensionSet/dimensionSet.C at line 517. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&)sh: 1: addr2line: not found addr2line failed #1 Foam::error::abort()sh: 1: addr2line: not found addr2line failed #2 Foam::operator-(Foam::dimensionSet const&, Foam::dimensionSet const&)sh: 1: addr2line: not found addr2line failed #3 Foam::tmp<Foam::GeometricField<Foam::typeOfSum<double, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::operator-<double, double, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&)sh: 1: addr2line: not found addr2line failed #4 ?sh: 1: addr2line: not found addr2line failed #5 __libc_start_mainsh: 1: addr2line: not found addr2line failed #6 ?sh: 1: addr2line: not found addr2line failed Aborted (core dumped) |
anonymous
Rep Power: 15 ![]() |
Your p or p_rgh has a bad dimensionin the 0 folder
It should be [1 -1 -2 0 0 0 0] |
Sean Gorry
Thanks that worked, the p file had the wrong dimensions, I must have forgotten to change it
Display Modes | |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
