overPimpleDyMFoam does not satisfy the mass conservation betwee inlet and outlet
Prev Previous Post   Next Post Next
Old   July 7, 2018, 05:23
Default overPimpleDyMFoam does not satisfy the mass conservation betwee inlet and outlet
Michael Alletto
mAlletto will become famous soon enough
Hello all,
I have a very simple test case. It is a 2D cylinder bounded by two fixed wall (top and bottom) and pressure inlet and outlet. The flow is laminar. When starting to move the cylinder periodically (the fluid is initially at rest) in direction of the inlet and outlet i realized by monitoring the mass fluxes at the inlet and the outlet that they are not equal in magnitude. So i was wondering if I have something wrong in the setup or there is an issue in the pressure equation (which should guarantee the mass conservation.
Please find attached the case. Maybe someone can give me a hint what's going wrong
File Type: gz OcilatingCylinderinFluidAtRestSend.tar.gz (14.1 KB, 5 views)
mAlletto is offline   Reply With Quote
buoyantBoussinesqSimpleFoam: Steady state: Mass Flow rate NOT EQUAL at inlet & outlet Struggle_Achieve OpenFOAM Running, Solving & CFD 6 October 3, 2016 05:46
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
Comparison Mass flow rate at the inlet and outlet??? vahid.najafi OpenFOAM Post-Processing 3 October 25, 2012 13:36
Mass flow inlet and outlet A.S. Main CFD Forum 0 December 21, 2002 04:16
