Adrien
Rep Power: 11 ![]() |
Hi all,
I've run the simpleRotor case using overPimpleFoam solver. Everything is fine during the calculation. However, I have an issue when I want to display the results in paraview (see attached picture). I think it's an issue in Paraview but I am not sure. Do you have idea? Thank you, |
Robin Kamenicky
Hi Adrien,
To me it seems, that more parts overlays each other. It seems that all meshparts were chosen to be shown in paraview menu on the left side (patches and also internalMesh) at once or some similar problem. If that is the case, chose just patches or internalMesh at once to be shown. Cheers, Robin |
Adrien
Hi Robin,
Thanks for your reply. I thought the same thing but only internalMesh is activated. You can find attached another view of the mesh. It seems that the background is still fully present, even in the "hole" region. Adrien |
#4 | |
Santiago Lopez Castano
Rep Power: 15 ![]() |
Adrien
Same result when I do a clip (see attachment).
You didnt remove the fringe region it seems to me, and tou need a hole in the background mesh. Have in mind that the background grid should also be clipped. Im not familiar with OF overset, but i have produced overset results and visualized with paraview. You should have a scalar field describing
Adrien
It's a tutorial from Openfoam library.
$FOAM_TUTORIALS/incompressible/overPimpleDyMFoam/simpleRotor I've just run the ./Allrun script. I don't know how to remove this region. The mesh region present are: - internalmesh - overset - walls - hole - frontAndback |
anonymous
Rep Power: 14 ![]() |
Hi!
Here you can find a brief explanation about the regions: https://www.openfoam.com/releases/op...merics-overset If you run the simulation, there will be a scalar field called cellTypes. This will tell you which cell is calculated, which is not, and which is interpolated of the background mesh. If you set a treshold for cellType between 0 and 1, you'll see only the calculated and the interpolated cells. |
#9 |
Adrien
Ok, got it.
Thanks for your help. |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
OF v1706: Problem with Overset | Flo_Ha | OpenFOAM Running, Solving & CFD | 20 | March 16, 2021 04:02 |
Overset mesh issiue | engineer_1993 | STAR-CCM+ | 3 | July 25, 2017 14:46 |
[OpenFOAM] Problem postprocessing decomposed case with 'paraFoam -builtin' | bentkj | ParaView | 4 | February 21, 2017 04:22 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
