rotatingMotion: omega too low
Old   August 23, 2018, 07:10
Default rotatingMotion: omega too low
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
In my dynamicMeshDict I have defined the following:
#include "variables"
motionSolver solidBody;
cellZone        impeller;
solidBodyMotionFunction  rotatingMotion;
rotatingMotionCoeffs
    origin        (0 0 0);
    axis          (1 0 0);
    omega         $vOmegaRotating; // rad/s
where vOmegaRotating is defined in constant/variables:
vRpm             3700.0; // revolutions per minute
vOmegaRotating   #calc "$vRpm * 2.0 * 3.14159 / 60.0";
Therefore, cellZone impeller should be rotating with 387.5 rad/s.
I chose a point on the edge of impeller and took its coordinates for the last 20 timesteps. Divided by timestep, I get 372 rad/s. The python script is below.
Does anyone have an idea what would be wrong with my setup?
Can I print out the value calculated with #calc "" function?
Thanks!
# -*- coding: utf-8 -*-
Created on Thu Aug 23 11:54:56 2018
@author: jnejc
import numpy as np
def unit_vector(vector):
    """ Returns the unit vector of the vector. """
    return vector / np.linalg.norm(vector)
def angle_between(v1, v2):
    """ Kudos: https://stackoverflow.com/questions/2827393/
    Returns the angle in radians between vectors 'v1' and 'v2':
    >>> angle_between((1, 0, 0), (0, 1, 0))
    1.5707963267948966
    >>> angle_between((1, 0, 0), (1, 0, 0))
    0.0
    >>> angle_between((1, 0, 0), (-1, 0, 0))
    3.141592653589793
    v1_u = unit_vector(v1)
    v2_u = unit_vector(v2)
    return np.arccos(np.clip(np.dot(v1_u, v2_u), -1.0, 1.0))
def vector(x, y, z):
    return np.array([x, y, z])
# point id = 52515
positions = [
        vector(-0.00611921, 0.00777754, -0.019457),
        vector(-0.00611921, 0.0137424, -0.0158181),
        vector(-0.00611921, 0.0145818, -0.0150478),
        vector(-0.00611921, 0.0153579, -0.0142548),
        vector(-0.00611921, 0.0160918, -0.0134208),
        vector(-0.00611921, 0.0174789, -0.0115565),
        vector(-0.00611921, 0.0189125, -0.00902112),
        vector(-0.00611921, 0.0199236, -0.00648966),
        vector(-0.00611921, 0.0205293, -0.00419667),
        vector(-0.00611921, 0.0208551, -0.00203244),
        vector(-0.00611921, 0.020952, 0.000283341),
        vector(-0.00611921, 0.0207245, 0.00309213),
        vector(-0.00611921, 0.0201434, 0.00577128),
        vector(-0.00611921, 0.0192372, 0.00830631),
        vector(-0.00611921, 0.0180004, 0.0107261),
        vector(-0.00611921, 0.0163262, 0.0131347),
        vector(-0.00611921, 0.0143235, 0.0152938),
        vector(-0.00611921, 0.0120302, 0.0171563),
        vector(-0.00611921, 0.00936239, 0.0187459),
        vector(-0.00611921, 0.00628985, 0.0199876),
        vector(-0.00611921, 0.0039477, 0.0205786)
times = [
        0.0162497,
        0.01711435,
        0.01725469,
        0.01739138,
        0.01752823,
        0.01781459,
        0.01817363,
        0.01850961,
        0.01880188,
        0.01907158,
        0.01935721,
        0.01970456,
        0.02004247,
        0.02037429,
        0.02070925,
        0.02107084,
        0.02143386,
        0.02179805,
        0.02218091,
        0.02258951,
        0.0228872,
omegas = []
rpms = []
for i in range(1, len(positions)):
    angle = angle_between(positions[i-1], positions[i])
    omega = angle/(times[i-1] - times[i])
    rpm = omega/(2*np.pi)*60
    omegas.append(omega)
    rpms.append(rpm)
kandelabr is offline   Reply With Quote
Behaviour of the kOmegaSST in a steady-state case Max1234 OpenFOAM Running, Solving & CFD 18 October 31, 2018 08:03
RSM low Re Stress - Omega convergence issues Jonathan FLUENT 1 April 20, 2016 05:33
Low Re stress Omega Reynolds stress model help ryancfd7 FLUENT 0 March 1, 2014 17:10
low reynolds k omega / wall functions stawrogin OpenFOAM 1 March 30, 2011 06:04
